zeja0331
Toronto
Toyota 4runner 2026 TRD Sport
Hopefully this helps someone. I know I wasted a lot of time worrying about tire size, offset and the potential for rubbing without a lift.
Faliken Wildpeak AT4W C rated 285/70/17
Method 703, +35 offset
No rub, no issues everything stock.
Thrilled with how it turned out. Exactly the look I wanted. Aggressive, thick look and minimal poke.
Just won’t pay attention to fuel economy 😏
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7598
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7599
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:17 Wildpeak AT4W, +35 offset, no lift, no rub (photos)
Joestac
275/70/18 BFG KO3 +20 Offset No Rub
Stopped by Discount Tire today to look at the KO3 versus the AT4W. They had 5 of the KO3's, they were dead slow and could fit me in so I pulled the trigger.
So far I am quite impressed. People aren't kidding these tires are quiet. I don't even notice any more noise than the stock Toyo. Drove home with the windows down and all I heard was air noise.
You can feel there is more weight for sure since these are E load, but it still drives and rides great. I'll update with some MPG calculations over the next couple of fill ups. Averaging about 20 combined right now.
No rub at full lock forward and reverse. Full spare snugged up no issue.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260502_123506
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260502_123519
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260502_123542
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260502_123629
Beartooth85
New Jersey
2025 Toyota 4runner
Since I have yet to see a build like this I decided to take the plunge. Absolutely worth it. No rubbing at all with minimal trimming.
Build so far:
3" Readylift SST 2.1 lift
35x12.50r17 Toyo RT trail tires
17x9 0 offset Lock Offroad Baja wheels
Baja Design squadron pro Amber fog lights
Trimming/ work needed
1. Back of front bumper small cut on inside.
2. Push front fender liner forward about an inch and repinned.
3.back of front fender near crash pad trimmed with some rear fender liner.
4. Remove crash pad
5. Good advanced alignment
All in all worth every penny! Feel free to inquire on anything I may have forgot. Hope this helps anyone looking to go big or go home 🏆
See full original build thread at: https://www.4runner6g.com/forum/thr...st-2-1-lift-17x9-0mm-offset-wheels-35s.10254/
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260420_173920
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260420_180749
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260423_132515
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260421_174541
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260423_132441
More pics
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 34248-920abd0a4c2a8917a6babcdb9057eb35
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260427_171704
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260421_174431
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260421_174454
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260421_192857
Chris4R
2026 4Runner Limited
Suspension / Wheels / Tires
  • Wescott Preload Collar Lift Kit (2.5” Front and 0.75” rear)
  • Rough Country Extended Flares - Gloss Black
  • Custom installed fender markers on front and rear flares
  • 18x9 Fuel Rebel 6 D681 Bronze/Black Wheel Fuel Rebel 6 D681 +1 Offset
  • 1” spacers - Rear wheels only
  • LT275/70R18 Kumho Road Venture AT52 All Terrain Tires
See full mods list and photos at build thread:
https://www.4runner6g.com/forum/threads/black-2026-4runner-limited-build.10304/
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2786
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2775
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2797
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2798
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2795
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2794
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2778
Furrypanda1121
Los Angeles
2025 4Rrunner
Im getting the 6112/6100 kit installed with dobinson C59-885V springs soon. The fronts will be set at ~2", are extended sway bar end links required for about 1.5in-2in of rear lift? I don't see anyone mentioning they installed them with their lifts
clarkdot7
Las Vegas
2025 4runner sr5
ARB OME MT64 Suspension Lift Kit (2.5 inches front / 2 inches rear) on 2025 4runner SR5
Finally got around to installing the MT64 lift on the car. A whole day install ordeal but very worth it in the end.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 34766-1ed6694e5149365dd8cf830a4e4ec
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 34764-1aba8ac2746e4316b5155323ed7b1710
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 34765-a4cadeea39259c670b053343217e54ad
Joestac
Because I am insane and don't mind spending hours at Discount Tire. I swapped from the KO3s to the Falken AT4Ws. They had to swap out a bad BFG and they still had some slight wobble. Both E load. So figured I'd try something new while able.
The AT4Ws are definitely louder than stock and the KO3's, but even though they are only 3 pounds lighter than the KO3's, the feel like they roll better.
I am still getting a little jitter on the road at random times but I'm thinking that might be just life with an E load tire and this vehicle and suspension.
I went back to the 265 in the AT4Ws when I went up to the 275 in the KO3 because the 265 AT4W is a 33.4" diameter tire. The 275 BFG was 33.1". If I did 265 in the BFG it was like 32.6". Interestingly, the 275 in the AT4W is slightly shorter at like 33.2". I also saved 3 pounds.
Ramble over.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260513_164532
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260513_164522
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260513_164119
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260513_164126
travis
Travis
NW NC
2026 Limited Hybrid
Got new wheels and tires:
SCS F5 17x8.5 +20 offset
Nitto Terra Grappler G3 285/70/R17
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5557
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5555
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5546
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5561
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5562
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5566
TexasDirtFarmer
Ryan
Dallas
2026 Toyota 4 Runner TRD Sport
2.75" front lift with Bilstein 5100 + 6100 rear shocks + 285 AT3 tires + Fuel Off-Road Spur 17” wheels +25 offset
The team at 4 Wheel Parts handled the build — they’ve been my go-to shop for the last three trucks I’ve owned. The setup includes new Fuel Off-Road Spur 17” wheels with a +25 offset, wrapped in Toyo Tires 285 AT3s. Suspension is a 2.75” front lift only using Bilstein 5100 B8 adj. front struts (highest level) and 6100 rears shocks.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5150
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5151
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5152
