RSPNDCO
Matthew
Kailua-Kona, Hawaii
2026 Underground 4Runner
Looks great…and from the pics it’s taking care of business off road. Nice!
Thanks boss. I really had no problems with it. The SR5 is so good. The built in limited slips are well enough for everything I need it for. I get the articulation I need out of this lift to maintain the wheels in contact with the ground. Wish I had a locker but haven’t needed it for anything yet. It just snow here in Hawaii so hopefully I’ll get some snow pics soon.
Bhoop
Minnesota
4runner SR5 6th gen
255/75r17 Firestone Destination XTs, C load. I had some wheels ordered but they haven't shown up yet so I just had Discount Tire mount the new tires. It looks pretty good as it sits now so I will probably skip the wheels for a while. Probably a small lift in the front when the Bilstein 5100s come out, and call it good for a season or two...
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7995
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7997
rnys9
New York
2026 4Runner SR5
Any change in MPG? What psi did you end up at?
Really curious what your experience is like with those, I was thinking about doing the same exact swap!
33 cold. Which I guess is where it should be anyway? Definitely improved the ride, they had it at 37 when I picked it up.
these are nice but as expected I’ve taken like a 1-2 mpg hit so far. Was getting 19-21 combined and now im firmly ~18. Still early though and air dam still on. they feel slightly sluggish compared to the stock car tires, but that should also be expected moving to a bigger AT, even if they are more road focused.
adrew3993
Eric
Clayton Ga
2025 trd off road premium 6gen toyota 4runner ( cutting edge
Cutting Edge 4Runner TRD Off-Road Premium on:
Front suspension: 6112 Bilstein coils and struts
Rear suspension: 6100 Bilstein
Westcott puck lift under the coils in the rear
Total lift ~2.5 inch lift
Icon Upper Control Arms UCA
Method Wheels 709HD 17" inch 0 offset
34" inch tires: Toyo AT3 (34x10.5xr17)
CBI front stealth bumper
Warren Winch
Baja Designs fog lights and ditch lights
Molle console panels
Victory 4x4 skid plates armor
Victory 4x4 shelf in cargo area
Map lights and dome lights switched to LED
See full mods list and photos at:
https://www.4runner6g.com/forum/thr...6100-bilstein-suspension-2-5-lift-more.10038/
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! TRD ORP build: 34%22 AT3 tires, 0 offset 17%22 Methods, CBI stealth front bumper, 6112 : 6100
zeja0331
Toronto
Toyota 4runner 2026 TRD Sport
Before & After on SR5:
Tires: Falken Wildpeak 285/70/17 A/T4W SL
Wheels: Icon Alloys Recon SLX Satin Black 17x8.5 +25mm Offset
No lift
No rub
The Wildpeak AT4W tires are great.. they ride smoother than stock with a very slight hum. Not noisy by any means though.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
looking to replicate this almost exactly. any issues at this point with rub or suspension?
acirrill
anthony
stony point ny
2026 4runner sr5
2026 sr5
17x8.5 +25mm offset RRW RR7-S in matte grey
285/75/17 Toyo open country AT3 load C
Westcott preload collar, upper spacer and rear spring spacer installed (for now)
pictures on the internet don’t prepare you for how large these tires really are. They’re gigantic. Especially coming from 30.5” tall tires on an sr5
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2018
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2017
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2015
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2019
nayelim47
Nayeli
2025 4 runner off road premium
Lock Off-Road Mojave 17x9 ET 0 offset wheels
Wrapped in 35s - BFG KO2 315/70/17
Westcott leveling kit
Lasfit white DRLs
TRD skid plate and some red tow hooks to tie it all in
Had pretty noticeable rubbing, had to trim about an inch from the front bumper and push the fender liner forward. Had to take a chunk off the rear metal fender as well, but would definitely do it again.
See original build thread at: https://www.4runner6g.com/forum/thr...tcott-leveling-kit-after-some-trimming.10061/
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! ORP Cutting Edge build: 35%22 KO2, 0 offset wheels with Westcott leveling kit after some trim
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DSC09115
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DSC09098
DigitalAudioGod
2026 Toyota 4Runner TRD Off-Road I-Max, 2020 Jeep Compass Trailhawk
2026 Toyota 4Runner TRD Off-Road IForceMAX
Prinx HiCountry RTs LT285-75-R18 (metric 35") on stock TRD Offroad Wheels (+55 offset)...setup is flush with fenders.
Ready Lift 2.5" front / 1" rear lift
No rubbing
No cutting
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! inbound2077622845082589300
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! inbound3602812257676540425
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! inbound8056653118280957647
brucejun444
Bruce
Seattle, WA
26 TRD Sport Premium
My first 4Runner. It's been exactly one month and this thing has been awesome.
Enkei 18x9s +42 offset bronze wheels and Nitto G3 tires 275/70R18 on stock suspension.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1759
CorvinoTRDPRO
Michael
Waverley, Nova scotia
2018 Jeep grand cherokee limited, 2025 4Runner Platinum
Pearl White platinum version build.
Wescott lift
18x9 Fuel wheels 19 offset
35 inch open country AT3
Ordered the AWE exhaust (month out) and Cobb Tune (Tuesday) which Havnt arrived yet.
Tint this week.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4086
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4094
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4080
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4083
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4075
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4082
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4084
Armbender
Will
halifax
2025 4Runner ORP
This has been my dream vehicle and finally picked it up last November. Been doing lots to it to make it perfect for me. My first 4Runner and it’s not disappointing. Still lots more to add.
Wheel & Tire Setup
Method MR 316 18x9 +18
Falken Wildpeak AT4Ws - 275/70/18
Westcott Collar Kit 2.5”/0.75” (to be installed)
Red TRD Pro UCAs
AOOP red Caliper covers
ARK Mud Flaps (to be installed)
See the full list of mods and full build thread at:
https://www.4runner6g.com/forum/threads/2025-orp-build.10167/
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 33959-689a26b73eed9af3194789dba711f846
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 33984-34a74ad1dec8bba11e9c9ace54dcf13b (1)
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1178
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1176
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1175
