EL616
Tennessee
2025 TRD ORP
ORP got new shoes:
Bronze Fuel Shoks 17x9 +20mm offset
Toyo AT3 285/70/17 SL
Added bronze badges and Toyota overlay to match the wheels. Very slightly more road noise and vibration, which is to be expected switching to true AT tires, but bumps, dips, and potholes now feel much softer and more pleasant to drive over than with the stock wheels and tires. There is a very, very slight amount of rub when turning + breaking or turning + hitting a bump from the OEM mudguards, but it's barely noticeable. Should be able to sand that bump down a bit and was planning to get the Rough Country 1.5" level kit in the front anyway, so no concerns there. Maybe a hair more poke than I was going for, but I'm not unhappy with it. I'd say +25 to +30 is the sweet spot for 285/70/17s.
Overall I'm thrilled with the look and ride quality.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! PXL_20251213_211146130.MP~2
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! PXL_20251213_211354066.MP
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! PXL_20251213_211342917.MP
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! PXL_20251213_211311681.MP
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! PXL_20251209_205138019.MP
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! PXL_20251213_211204255.MP-EDIT
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! PXL_20251209_205103512.MP
Desert_6Gen
Eric
Bronco
Joe Dirt
2025 4Runner TRD Sport Build on:
Eibach Pro Stage 2R lift kit (3" inch lift)
Wheels: Work Meisters S1 18x9 +18 Offset
Tires: Mickey Thompson Baja Boss AT 295/70/18
Prinsu Pro Roof Rack
LED Light Bar
Build by MJ Motorsports
Eibach Pro Stage 2R Lift Kit (3%22 Inch) + Work Meisters S1 +18 Offset + MT Baja Boss AT 295:...webp
Just wondering if those Rays wheels are the gunmetal matte color it's hard to tell. Thanks in advance.
Franco
Frank
San Clemente, CA
2025 4Runner TRD Off-Road
BoiseUte
scott
Boise, ID
2025 4Runner Off-Road Hybrid Premium
Completed the lift/level, new wheels, and tires. So much nicer with these mods. Before after the upgrades pics.
Mods List
LUGKIT6
STEMKIT
LUGKEY
WESTCOTT LIFT KIT INSTALLED
ICON FRONT DIFF DROP INSTALLED
METHOD 709 17X8.5 +25 MM OFFSET MATTE BLACK
285/75/17 FALKEN WILDPEAK AT4W TIRES INSTALLED
Before
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4859
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4858
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4860
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4861
After
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5888
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5892
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5889
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5891
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5890
MDD_TRD
orlando
2025 TRD off road premium
Before
After
Mods List
LUGKIT6
STEMKIT
LUGKEY
METHOD 709 17X8.5 +25MM OFFSET MATTE BLACK
Nice, any mods to fender liner or crash bracket etc? Could you have gone to 20 mm offset?
BoiseUte
scott
Boise, ID
No adjustment to the wheel wells all standard. Not sure on 22mm’s but I believe yes. The ride is so much smoother and even sounds better.
Jason
Pennsylvania
2025 4runner 2024 landcruiser
Jason
Pennsylvania
Order that same lift kit wondering if you used extended sway bar links or not
Franco
Frank
San Clemente, CA
JenningsESQ
Jon
2020 Tacoma TRD OR Premium
ryan
New Jersey
Here's what -10 offset wheels w/ 33" tires look like on the 2025 4Runner 6th gen. Way aggressive for my taste but interesting to see how -10 mm offset looks like on the 6th gen. I do like the white wheels on Ice Cap white look. This isn't my 4Runner btw, it's owned by Kevin K.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
Anyone know what wheels these are or the set up?
