RedRaiderATX
Westcott Lift and 33's (285/70/17) on my SR5.
It’s a night and day difference! Westcott Designs is incredible as always. I paired the lift with a set of 33" 285/70/17 Falken AT4 tires (E rated). So far the ride quality has improved greatly coming from the stock 245’s. I haven’t had the tires long enough to figure out MPG loss yet, but I haven’t noticed a significant loss in power. I replaced the center caps with the Landcruiser caps which I thought paired with cutting edge really well.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28230-0c54c52bcc45bdb465b9aa72817d1685
Before:
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28231-3f181ebf1507b7667ed7b0343df5ac87
page09
Edward
california
4runnertrdor
4RNerAndScrubs
Ice Cap SR5+ 4wd
We love these fender flares from @NYTOP. The flares are 1" wider than OEM flares excluding PRO and Trail Hunter models, and It fit our wheel and tire setup perfectly with the +10 offset 295/70/17 wheel & tire setup. Our tire poke only comes from the sidewall tire thread, and is flush from the top tire threads on our BAJA Boss ATs. Exactly where we wanted it!!
Wheels / tires / suspension mods:
- Mickey Thompson Baja Boss AT LT295/70/17 Load E (33.7 x12.1 exact specs from website)
- Fuel Off-Road FC860 HYPE wheels 17x8.5 +10 Offset Machined Finish
- Husky Liners Low Profile Ventvisors/Rain Guards
- Rough Country 1.5"-2" Front Spacer Leveling Kit
See more details at thread about the @NYTOP carbon fiber fender flares : https://www.4runner6g.com/forum/thr...on-10-offset-wheels-and-295-70-17-tires.8650/
And see original build thread at: https://www.4runner6g.com/forum/thr...-offset-wheels-katzkin-leather-interior.7704/
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28358-67fa9bcafe0e0f2063b4274d25da039
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageYmjcrP
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImagepXpSik
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImagehjrHzW
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImage5eEPK
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageY6E0FS
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageepoUjN
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageKb1xu3
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageGKHEsh
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImagezW41zI
Jason
Pennsylvania
2025 4runner 2024 landcruiser
Iron Man 3" lift kit
Raceline 958mc 17x8.5 +0 offset wheels
285/70/17 tires (Rocky Mountain All Terrain A/T)
Crash bracket delete
ARK mudflaps
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260120_122825(1)
ECK
Evans
Idaho
2025 4Runner TRD ORP
BFG KO3 (C-load) 285/70/17 on Method 703 17 x 8.5” (+35mm offset)
No lift yet, but no rubbing detected either
If you’re looking at 17 x 8.5” wheels and want the tires flush with the fender flares, IMO the +35mm offset is the way to go. +25mm would have a little more poke (10mm worth…)
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9314
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9313
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9312
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9310
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9308
n1comedes
San Diego
Toyota 4Runner
SR5 build on :
SSW Dakar 17x9 0 offset wheels
Mickey Thompson Baja Boss AT 285/70/17 tires
Ready Lift 2.5 Inch Kit
OEM Predator Steps
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
Any rubbing at full lock? Do you think there will be issues when offroading with the 0 offset? Thanks
n1comedes
San Diego
Toyota 4Runner
ARK mudflaps
elecfuyu
6G Platinum
Model: Platinum (debadged)
Tire: Continental TerrianContact A/T 275/65/18
Wheel: Volk Racing TE37SB Tourer SR 18x8.5 +22 offset Shining Bronze
Stock suspension no lift or leveling kit.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28747-184dba46986f66499a921ac7cc567be0
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28741-15b9104eb6fa1df11429e75f66826950
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28744-2665feb969cc6b3017f7a497ff8cb399
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28743-9cb2921dd1a049d84e20e2bd1880a7e4
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28740-ae02d6fd45135067dda1fa822f6907cf
NaeS
2025 SR5 4runner and 2000 SR5 Tacoma 3.4l
2025 SR5
Suspension Front- Fox Performance 2.0 coil-overs for a 2'' lift out of the box.
Suspension Rear- Fox Performance 2.0 shocks with ICON 0.75" Dual Rate Rear Coil Springs. These springs gave a 1.5" lift once installed over stock. This is a little more then what I wanted, but I think they have settled a little over the last few weeks. Currently sitting with the rear about .75" higher then front.
Tires- KO3's LT285/70 R17 116S C1
Wheels- Method MR316 17X8 +25
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! front
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! back
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 45 back
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 1000008680
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 1000008679
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 1000008682
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 1000008681
Desert_6Gen
Bronco
2" Rough Country Level kit + Nitto Terra Grappler 33s 275/70r18 tires installed on 18" TRD Wheels.
Finally got around to throwing the Leveling kit on the 4 runner. Super easy took me about an hour and now she's in the shop for alignment today. This is exactly the look I was going for, now just waiting on the trail hunter grille and the wife will be happy.?
I'm considering this RC level kit as well. Do you have to remove the top of the spring to recenter the spacer bolts or is it as single as bolting the spacer to the top of the strut and bolting everything back together?
NYTOP
Walnut, CA
Website
nytop.com
See all photos & details at the original full build thread
https://www.4runner6g.com/forum/thr...-nytop-full-armor-adv-classic-beadlocks.8799/
Wheel Specs:
  • 17x8.5 +25mm
  • When mounted with the beadlock ring, the effective spec is equivalent to 17x9.5 +11.5mm
Suspension – Dobinsons USA
Suspension duties are handled by a full Dobinsons system, including:
  • Dobinsons front and rear suspension components
  • Billet upper control arms
  • Billet rear links
The Dobinsons setup complements the added armor and wheel/tire package extremely well—excellent ride quality on-road with controlled articulation and stability off-road. The billet control arms and rear links also add strength, adjustability, and long-term durability compared to factory components.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 14 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 19 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 20 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 21 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 22 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 15 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 17 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 16 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 1 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 2 1x1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 11
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 12
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Dobinson USA 4Runner Build 13
