RedRaiderATX
Westcott Lift and 33's (285/70/17) on my SR5.
It’s a night and day difference! Westcott Designs is incredible as always. I paired the lift with a set of 33" 285/70/17 Falken AT4 tires (E rated). So far the ride quality has improved greatly coming from the stock 245’s. I haven’t had the tires long enough to figure out MPG loss yet, but I haven’t noticed a significant loss in power. I replaced the center caps with the Landcruiser caps which I thought paired with cutting edge really well.
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28230-0c54c52bcc45bdb465b9aa72817d1685
Before:
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28231-3f181ebf1507b7667ed7b0343df5ac87
page09
Edward
california
4runnertrdor
4RNerAndScrubs
Ice Cap SR5+ 4wd
We love these fender flares from @NYTOP. The flares are 1" wider than OEM flares excluding PRO and Trail Hunter models, and It fit our wheel and tire setup perfectly with the +10 offset 295/70/17 wheel & tire setup. Our tire poke only comes from the sidewall tire thread, and is flush from the top tire threads on our BAJA Boss ATs. Exactly where we wanted it!!
Wheels / tires / suspension mods:
- Mickey Thompson Baja Boss AT LT295/70/17 Load E (33.7 x12.1 exact specs from website)
- Fuel Off-Road FC860 HYPE wheels 17x8.5 +10 Offset Machined Finish
- Husky Liners Low Profile Ventvisors/Rain Guards
- Rough Country 1.5"-2" Front Spacer Leveling Kit
See more details at thread about the @NYTOP carbon fiber fender flares : https://www.4runner6g.com/forum/thr...on-10-offset-wheels-and-295-70-17-tires.8650/
And see original build thread at: https://www.4runner6g.com/forum/thr...-offset-wheels-katzkin-leather-interior.7704/
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 28358-67fa9bcafe0e0f2063b4274d25da039
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageYmjcrP
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImagepXpSik
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImagehjrHzW
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImage5eEPK
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageY6E0FS
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageepoUjN
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageKb1xu3
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImageGKHEsh
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! tempImagezW41zI
Jason
Pennsylvania
2025 4runner 2024 landcruiser
Iron Man 3" lift kit
Raceline 958mc 17x8.5 +0 offset wheels
285/70/17 tires (Rocky Mountain All Terrain A/T)
Crash bracket delete
ARK mudflaps
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260120_122825(1)
ECK
Evans
Idaho
2025 4Runner TRD ORP
BFG KO3 (C-load) 285/70/17 on Method 703 17 x 8.5” (+35mm offset)
No lift yet, but no rubbing detected either
If you’re looking at 17 x 8.5” wheels and want the tires flush with the fender flares, IMO the +35mm offset is the way to go. +25mm would have a little more poke (10mm worth…)
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9314
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9313
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9312
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9310
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9308
n1comedes
San Diego
Toyota 4Runner
SR5 build on :
SSW Dakar 17x9 0 offset wheels
Mickey Thompson Baja Boss AT 285/70/17 tires
Ready Lift 2.5 Inch Kit
OEM Predator Steps
2025 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
Any rubbing at full lock? Do you think there will be issues when offroading with the 0 offset? Thanks
