justinmo4r
Justin
San Diego
2025 Toyota 4runner SR5
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 37004-87e8d5c6b23d553fb8434bcf6b50cb3d
Note: Still have stock wheels & tires with less then 1k miles
Sackgo
Kenneth
Sacramento, CA
2026 Toyota 4Runner SR5
Build Phase 1
KMC K552 IMS Wheels Gloss black w/ Matte black +25.
Falken Wildpeak AT4W 285/70/R17 116T
OME MT64 3” Front 2.5” Rear Spring Lift w/ OME UCAs.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 37124-655ce2574f2182c0fec748e3ef05a0a1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 37125-0b4dfbd68c54716b54e6adbfcbd46b96
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 37126-f12d12619f4775bdb75025b74ca62b1a
Houston
2026 4Runner Platinum
Put some beefy 285/60R20 Mickey Thompson Baja Boss tires on the rig. I believe it’s a hair over 33s.
No rubbing at all.
285:60r20 tires 2025 4runner TRD Sport factory wheels2.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels9.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels8.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels6.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels5.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels4.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels3.jpg
285:60r20 tires 2025 4runner TRD Sport factory wheels1.jpg
Update:
Just went in a trail called two towers loop in nj. No issues at all. Will definitely put westcott level kit in the future
So those pictures are without any leveling kit?
clk55r1d3h
los angeles
2026 4runner
Finally got my RRW RR7-H wheels (+25 offset) in yesterday had them on today with some 285/70/17 Terra Grappler G3 tires in SL load.
I think they look good. Truck is otherwise bone stuck with exception of skid plates.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1067
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1070
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1071
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1069
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1062
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1068
rgall927
Ryan
Charleston, SC
2026 Toyota 4Runner SR5 - Underground
My 2026 SR5:
- Westcott Preload Collar kit
- Method MR318 +25mm offset
- 285/70R17 Toyo Open Country ATIII's
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_8476
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_8477
Pupperunner
John Doe
25' TrailHunter 4R
Copied from full build thread at:
https://www.4runner6g.com/forum/threads/updated-pupperunner-rig-for-now-trailhunter-build.11602/
Suspension/wheels/tires mods:
Full Peak Suspension 2.5 DSC (kept the TH UCA)
Will be installing new Dobinsons springs once rear bumper is installed
Relation Race Wheels RR5-H in a 17x8.5 +15 offset
Nitto Tire Ridge grappler 35x12.5r17
For the pictures with the KTM on the back, The mount is called an Ultimate MX hauler. However I dont think they are in business. But there should be a few others that are similar on the market.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DSC03754
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DSC03083
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DSC03111
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DSC03125
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DSC03589
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 702570249_1735624654266624_2277791135513757187_n
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 702651787_1735624640933292_4480512214565602999_n
Walkaround video:
T4r_STUBS
Mikel
washington
2026 4runner SR5
Recently picked up this 2026 4Runner SR5 and started with wheels and tires and a lift.
-Lift is the Dobinsons 2.5” nitro lift kit
-Wheels are RockTrix RT107 17x8.5 +25
-Tires are Toyo OpenCountry AT3 285/70/17
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 5A77AEAA-1720-4D54-9CB6-C5BE113F6D28
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 002FCBD7-F08C-439A-A22E-053441EA7C00
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! D8B79327-CADC-4FA8-B6B3-182578F00346
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6601
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6602
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6506
PdlMnk
6G4R - TRD ORP Premium Hybrid
My new 2025 Toyota OFF ROAD PREMIUM.
See full details at original build thread:
https://www.4runner6g.com/forum/threads/big-blue-trd-off-road-beauty.10690/
Wheels/Tires/Lift:
315/70/17 Falken Wildpeak R/T Tires
Lock Off-Road -12 offset wheels
Westcott Perch collars in front
Dobinson heavy duty rear SPRINGS
Very nice 4runner! Do you have any rubbing? I have the same color and I'm about to install the 2.5" TRD Lift Kit. I was set on 285/75/17 (33.8"x11.2") but you have 305/70/17 (34.4" x 12.4"), which looks better, but I'm worried it'll rub.
Also, how do you like those Lock Off-Road wheels? What model and offset if you don't mind me asking? Thanks!
bphansen04
Brody
Kansas City
Hybrid Off Road Premium
Suspension Mods
Westcott Designs Preload Collar Lift Kit front and back
Wheels - Black Rhino 17" +25 Offset
Tires - Toyo Open Country AT III C load 285/75/17
No rubbing. Suspension a but stiffer than stock. MPG down a few miles so far. All the electronics seem to be working normal - lane assist, cruise, etc.
Stock:
With Lift & Wheels
How is the ride quality on this compared to stock? Thinking of going with this setup.
Mr. Wolfe
Greg
Pittsburgh
Picked up yesterday.
2026 ORP
Factory TRD 2.5" Lift
Trailerhunter Wheels
285/70 R18 Toyo Open Country ATIII's (34"~)
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9689
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9690
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9698
