Rusty Rattler
Rustyrattler
Bullhead City Az
2025 Toyota 4runner ORP
It looks great. Did you have stock 20” wheels? What is the width of those wheels?
J4Runner1
James
Hybrid Off Road Premium
Suspension Mods
Westcott Designs Preload Collar Lift Kit front and back
Wheels - Black Rhino 17" +25 Offset
Tires - Toyo Open Country AT III C load 285/75/17
No rubbing. Suspension a but stiffer than stock. MPG down a few miles so far. All the electronics seem to be working normal - lane assist, cruise, etc.
Stock:
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 5C1A4313-48FB-4513-B135-C26EDA3A6E1A_4_5005_c
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! A7895141-95EF-4BE6-8CFF-FF0C45A61C82_4_5005_c
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! BC01E033-BEB9-4C5D-AA43-2FC11F4168AF_1_105_c
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! D93371DD-DD95-4100-A9F3-6FB44818AC2F_1_105_c
With Lift & Wheels
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 42800F31-5256-4B5D-942E-56A7917B7B0F_1_105_c
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 1D2FE400-B2DA-4000-AEE6-3CCAA7CA484D_1_105_c
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4AFD6B10-7C7D-45E0-92C4-09EA5830F565_1_105_c
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! DB034ABE-8367-4E94-804D-F22C44DFC403_1_105_c
DarthBaeza
Phillip
Visalia
Mercedes GLB250
Underground TRD Sport on:
Westcott level kit - 2.5" front lift / 2" rear lift
+25 offset Method 305 wheels
Toyo Open Country R/T tires (295/70/17) - 33's
Barely any trimming required
2025 4runner Underground TRD Sport on 2.5%22 : 2%22 lift, +25 offset Method 305 wheels, Toyo O...jpg
they are only 33.3" tall right? Why would they rub at all at that size in a +25?...or did I read that size wrong? Just considering that 35"s need minimal trim.
Trailhunter4R
Not my build but sharing for anyone looking for an aggressive wheel and tire fitment.
17x9 RockTrix - 12mm offset bronze wheels (Style RT107)
295/70/17 Mickey Thompson Baja tires (33")
Westcott lift kit
According to the owner: Had to give her a trim a little to make it all work, slight rub against the safety bar, easily removed only three bolts, but pretty decent rub against the bumper. Gonna dremel it tomorrow, won't even notice honestly.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Supersonic Red TRD Off-Road build: 17x9 RockTrix 12mm offset wheels, 295:70:17 Mickey Thompso
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Supersonic Red TRD Off-Road build: 17x9 RockTrix 12mm offset wheels, 295:70:17 Mickey Thompson
kzrman
Maine
2025 Trailhunter
18x9 Method MR701 BLK PAINT rims
LT265/70R-18 BFGoodrich All-Terrain T/A KO3 E
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4runner trailhunter build
Old Spice
Bay Area
2025 4R TRD ORP
Stock 2025 4Runner SR5 on 265/70/17 Goodyear DuraTrac tires. No lift, no rub according to owner.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 2025 4runner sr5 on 265:70:17 Goodyear DuraTrac tires
Claw832
Houston
2025 4runner
Stock suspension
RRW RS7-H MonoForged +25 wheel
Toyo Open Country A/T 285/75/17
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2307
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2310
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2306
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2309
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2308
After Westcott lift kit installed:
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
Trd Off Road Premium took off the airdam, got it tinted 5% on all the back windows and 20% on the front two. Added wheels 18x8.5 with a +25mm offset stock tires.
Dark bronze wheels looking great on black 4Runner. The +25 offset looking nicely flush too.
What wheels are they?
Marc33
Marc
Escondido
2025 4Runner Limited, 2023 Porsche GT3 Touring, 2024 GMC Sierra 2500 Denali
Hey there, just got my Wescott lift installed on the 2025 Limited. I found some used Trailrunner wheels and had them powder coated gloss black and installed BFG KO3s.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6282
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6281
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6283
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6284
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6286
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6285
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6287
dawestbrook
Adam
Raleigh, MS
2025 TRD Sport Premium, 2025 GLS 450, 2024 Chevrolet 2500 ZR2, 2013 Toyota Tacom
Full Articulation, less than a 1/16" to the crash bar at full stuff and turned. No rub...
I also noticed that my rims didn't get knicked like they did with the Toyo's on my first run. Tire sits a little bit further from the edge of the rim which seemed to help.
P.S. OEM Toyo's once unmounted could be pushed to fold in half. Very weak sidewall.
Great to hear that 285/70/R18 fits, just bought a set and was hoping to not lift mine, technically the tires I bought are 33.7'' Thanks for the update on fitment
pauleighty
2025 4Runner Off Road Premium
UPDATE JULY 2:
Here’s the full breakdown of everything I’ve done so far—I think I’m finally done (for now).
• TRD Pro Wheels – $875 (currently 20% off for the 4th)
• TRD Skid Plate – $415 (currently 20% off for the 4th)
• OEM Red Tow Hooks – $120 (currently 20% off for the 4th)
• Westcott Lo-Pro Roof Rack – $1,000
• Westcott Side MOLLE Panels (Driver & Passenger) – $600
• Window Tint – $330
• Peak 1.25” Spacer Lift – $130
• Nitto Terra Grappler G3 (265/70/18) – $1,060 (mounted & balanced)
• Install for Peak Lift + Westcott Rack & Panels – $650
• Alignment – $120
All in, very happy with how it turned out. The 1.25” lift levels it out perfectly, the rack and panels look super clean, and the tires are a nice balance of looks, comfort, and capability.
Here’s a little comparison of the before and after showing the lift from the Peak 1.25” spacer.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_7579-jpeg
Installed the Rotopax mount and 1.75gal fuel container
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_7738-jpeg
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! img_7721-jpe
chrissurfr
Houston
21 Lunar Rock Pro, 25 Mudbath Pro
looks great - what size tire?
