bayrunner
Bay Area
2025 4runner trd offroad
2026 sr5
17x8.5 +25mm offset RRW RR7-S in matte grey
285/75/17 Toyo open country AT3 load C
Westcott preload collar, upper spacer and rear spring spacer installed (for now)
pictures on the internet don’t prepare you for how large these tires really are. They’re gigantic. Especially coming from 30.5” tall tires on an sr5
Looking to do the same setup with mine. Did you have to do any trimming to make the tires fit?
acirrill
anthony
stony point ny
2026 4runner sr5
They do rub in reverse and full lock. I haven’t had it off-road yet to see if they really rub. I did remove the factory mud guards and crash brackets in the front
Ltd.Herit.'26
Austin
Dallas
2026 4Runner Limited 4wd
Readylift level has it just about flat. No rubbing whatsoever at this point, have not been offroad though. +25 offset Fifteen52 Analog HD Wheels w/ 285/70/17 tires seems to be a smidge past fenders anywhere but straight above.
Have not been impressed w/ ride quality thus far, but don't think it got worse from stock with these changes. Gas definitely did, maybe 20 on the highway not using cruise control. Do love the look though lol, very fortunate to have started this with low expectations as far as mpg.
Thinking ASFIR skid next as they seem to be one of the only brands bridging the space to the bumper, hope to be done then.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70R17 tires and +25 offset wheels (Fifteen52 Analog HD) 2
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70R17 tires and +25 offset wheels (Fifteen52 Analog HD) 3
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70R17 tires and +25 offset wheels (Fifteen52 Analog HD) 1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5103
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5080
K&J
Kevin
2025 4Runner Platinum
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4 Runner rear
Used this forum to help me decide. Here's what I went with: Method Race Wheels MR703 Bead Grip MATTE BLACK 17x8.5 | 6x139.7. Toyo Open Country A/T III 285/70R17 (117T) . Method Wheels LUG KIT EXTENDED THREAD SPLINE M14X1.5 6 LUG KIT BLACK 24 PCS LK-S1415ET-40-24B. TPMS Added. Fits well on Stock 2025 4Runner Platinum (Black) with very slight modification to front wheel wells (trimming of plastic on mud flap, slight relocation of fastener for front fabric)
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4Runner Front wheel and tir
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4 Runner Method Wheel and Toyo Tir
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4runner Front wheel well relocated fastener for clearanc
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4 runner Front mud flap modification cutdown
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4 Runner front vi
romik
Romik
2025 Toyota 4runer
Hey everyone, just wanted to share my truck! Upgraded to Bilstein 5100 front and rear shocks, and I’m really happy with the height and the ride.
2.2 inch front and 0.8 rear lift. Sweet spot considering my tire size (275/70/17) and overall level stance!
Part numbers:
Front: 24-347464
Rear: 24-347433
Feel free to chime in on the alignment numbers if you know your stuff.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 35118-44b76f4a522fb51b47044e4a2e586943
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Alignment Specs
Joestac
Well, they say you need to dance with who bring you. The Trailhunter is back on Toyo rubber after going through BFG KO3 and Falken Wildpeak AT4W. Spent 6 trips at different Discount Tires, replaced a bad KO3 and AT4W, still wouldn't road force and not have some vibration. 35+ on more than 1 tire. The highest here was 22 and 3 ounces of weight. So far they seem much better.
Swapped in 275/70/18 Open Country AT3s, E load at 50 pounds each. 11 pounds over stock SL but 10 pounds lighter than the KO3's and 7 pounds lighter than the AT4Ws. Louder than SL Toyo and the KO3's, but about on par with the AT4Ws. You hear them, but it isn't bad. Seems to have much better roll and don't feel as sluggish as the KO3's.
Hopefully I'm done thinking about tires for a bit. Forgot to mention, I went with 275 over the factory 265 because this is a true 33.19" diameter tire over 32.64" in the 265.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260523_111030
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260523_111039
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260523_111051
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260523_111058
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260523_111119
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260523_111122
ross808
las vegas
2025 Toyota 4runner Trd Sport
Hi Everyone,
I just got me this 2025 TRD Sport - got it used with a leveling kit. Just got this set of TE37’s
Level kit
TE37 17x8 -10
Toyo tires 285/75/17
anyone out in Vegas? 🤙🏽
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2328
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2348
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2344
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2345
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_2342
blassy
Niagara Ontario
2025 Platinum
Looking at the same tire specs on my 2025 Platinum.
17x8.5 and 285/70/17.
Offsets are going to be +25. What are the offsets here?
Administrator
Administrator
Administrator
Staff member
Jay
From original build thread here :
https://www.4runner6g.com/forum/thr...kings-coilovers-3-lift-0-offset-wheels.10620/
Wheels / tires / suspension lift
Vossen HFX-4 17x9 0 Offset
Mickey Thompson Baja Boss AT 295/70/17
Lock Off-road Combat 17x9 0 Offset (second set of wheels below)
BF Goodrich KO3 35x12.5R17 (second set of tires below)
Kings Coilovers 3" inch lift
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
BlueFinTunaGuy
Greg
Long Island, NY
2026 4Runner SR5
From original build thread:
https://www.4runner6g.com/forum/thr...method-703-35-offset-285-75r17-bfg-ko3.10631/
- Bilstein 6112's at circlip setting (#3) for a 2" lift in the front
- Bilstein 6100's in the rear
- Matte Black Method 703s (17"x8.5" w/ 35mm offset)
- BFG All-Terrain KO3s 285/75R17
I have no rubbing, no trimming needed, no need to remove crash brackets. Everything just worked out perfectly, but oh is it close haha
The Bilstein 6112's at circlip setting (#3) for a 2" lift in the front paired with the 1" (~0.8") Westcott Designs rear coil spacers and a factory rake of ~1.6", retains a slight rake after lifting which makes it look super mean.
IMO the amount of rubber on the 285/75R17 fills out the wheel well perfectly and pairs really nicely with the (2" front + 2.4" final rear height).
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 35436-3cfc0283a01aba8a7f4558119bbec841
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 35437-577b4b07abf24361db28eafd3fafa88
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4002
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 35439-b73b5ca514d961d47a33b27e109e8566
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3972
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3962
Bilstein 6112- installed
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3961
Bilstein 6100- installed
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3968
BonRunner
2026 TRD Sport Premium / WCP
275/70/18 Falken Wildpeaks AT4W E-load tires on 18" Pro wheels. No lift.
Removed front stock flaps due to rubbing. Waiting on Pro flaps that are slimmer & wider.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260529_123922
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260528_175443
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260529_092851
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260528_180027
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260528_180155
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260528_180359
