Rock Doc
Joshua
Alexandria
2025 TRD Pro and 2002 Tundra
Haha agree but not in a Prius that would be more embarrassing at least I look cool while overheating.
Joey_Midnight
NJ
4runner ORP, GT4, BRZ
I havent been up any trails but i have used 4hi in my ORP on highway up hill in a straight line of course and didnt see any any temp changes while pulling a car trailer. Not sure if that helps your data collection
timelapse
ATL
2025 ORP
This is helpful. At higher speeds it doesn't seem to be an issue.
jarussll4
San Diego, CA
2025 Land Cruiser
Mine is a Land Cruiser 250 with the same drivetrain. Could not find a thread there so here is my info
  • Transfer Case: All wheel drive
  • Transmission Shifter Position: “D”
  • Drive Mode: Normal then sport as I saw the temp climb
  • Vehicle Speed: 15-40mph Regular twisty road non gravel, slow/go due to curves.
  • Duration: 30 minutes.
  • Additional Weight: Just 4 passangers and luggage..
  • Tire Size: OE
  • Transmission Cooler: Just the Stock mini tiny cooler
  • Other Details: Mine went off on a regular asphalt road from the bottom of the Hwy going up to Idylwild, CA. My wife was driving her Prius and she had to pass me as I had to stop for over 15 minutes for tranny to cool back down. The Altitude gain was about 3500ft.
  • Temp Outside: 75 F
    Gravel hilly roads takes about 10 minutes for the tranny temp to get to240F (OBD measured) if not switched to manual or Low.
time2playandy
Utah
I drove up a steep FS road today. About 20 minute climb. Tire size 265/70/17. Slow going at times. In 4H. 150 lbs. cargo. 60 degrees F out. I watched the trans temp gauge start to climb pretty quickly. Got to about 3/4, then I switched to manual and kept it in 2. 4 Lo was way too slow for the road. Ridiculous for an off-road vehicle (that I otherwise love).
bax767
Bill
Washington
2025 4Runner TRD Pro
Happened to me in my TRD Pro on a recent trip up a hill in Nevada.
4 Hi
Shifter in D
ECO mode
5-10 mph, at fairly heavy throttle
2 Pax, mostly empty in back
Stock tires & wheels, aired down to 18 PSI
Overheated approx 3 minutes after starting the climb
Outside air temp = 70 degrees F
Trans Cooler: No
Other details: Dealer checked it out, took oil sample - no metal, no apparent damage. Said that they are seeing lots of complaints from their customers about this, and are expecting Toyota to issue a service bulletin.
I’m now running hills in 4 Lo, and not seeing any more overheats.
AdFour
Washington
Skip to 7min mark
Here a 3rd gen tundra, granted its over GVWR as well as modified
But interesting
Gunnison
Sorry I'm a little late to this, I've taken a hiatus on a mountaintop that my Accord got me to cuz my 4Runner had these issues. Instances of overheating have happened both off-road (switched to 4L) and on-road (switched to manual 2S).
  • Transmission Shifter Position: "4HI" (off-road) and “D” (on-road)
  • Vehicle Speed: 10-25 mph (regular twisty roads, slow go due to curves and narrowness, rocks off-road)
  • Duration: 15 minutes.
  • Additional Weight: 1 passenger, no luggage
  • Tire Size: 265 /70 R18 116T SL BSW
  • Transmission Cooler: Stock
  • Other Details: Altitude gain was minimal, on road case maybe 500 feet.
  • Temp Outside: 70's F
Like everyone has said there are obvious workarounds but it's still an annoyance, particularly on-road having to switch into sport mode to go up something my Honda can get up no problem, and off-road when I have to keep switching it back and forth from 4LO to 4HI just based on speed.
kehyler
Northeast
NA
I'm not sure whether the 4runner has one, but anyone try pinning the transmission cooling thermostat open temporarily and repeating a climb known to cause an overheat event?
ropdykex11
Rich
Portland, OR
2025 4Runner TRD Off-Road
have been ripping off-road with a very heavily loaded roof and cargo area, constantly in 4hi and using 4lo when necessary. over 12k miles now, with at least 1000 of those in heavy off-road situations. no issues for me, and i keep an eye on it constantly.
T4RAZ
2026 4Runner ORP 2026 4Runner ORP
Has anything new happened with this? I recently saw my temps getting pretty hot in 4hi
  • Drive Mode: Tow/Haul
  • Vehicle Speed: 5-10 mph ( twisty roads, slow going due to rocks off-road)
  • Duration: 20-30 minutes.
  • Additional Weight: 1 passenger. Towing 2600lb trailer
  • Other Details: 235-240 degrees on scan guage 3
  • Temp Outside: 70's F, the next day was 90s and had similar temps quickly
JustDSM
JustDSM
Justin
Ogden, UT
2024 Tacoma TRD Offroad
We’ve actually been continuing to work on this quietly behind the scenes.
One of the biggest limitations up to this point has been the ability to consistently reproduce these exact operating conditions in a controlled environment. Traditional inertia dynos aren’t particularly useful for this kind of investigation because they struggle to replicate the prolonged low-speed/high-load conditions these vehicles see in 4HI while crawling, towing, or traversing loose terrain.
That’s a big part of why our recent R&D facility upgrade was important to us. (https://www.4runner6g.com/forum/thr...ne-3200ccs-awd-prohub-dyno.10447/#post-127365)
We recently brought a Mainline ProHub AWD 3200CCS dyno online, which gives us a massive step up in capability, specifically for this type of testing. Unlike a traditional inertia dyno, the Mainline allows us to apply and hold very precise steady-state loads for extended periods of time. In other words, we can now simulate trail-like conditions much more accurately. Applying low vehicle speed, high drivetrain load, sustained converter activity, towing loads, etc. It's a big step up without relying solely on field testing.
We’re still gathering data and validating theories before making broad claims or recommendations publicly. Still, the new dyno capability should significantly accelerate both our understanding of the issue and potential solutions moving forward.
