Weight of OEM wheel for 6th Gen 4R TRD PRO?
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Anybody know the weight? I am trying to compare net net weight differences on new tires and possibly new rims. Want to compare to my OEM setup. AI google search says 34-37 pounds. Found some threads on other sites that say 28.75.
js_panda_rnr
Sorry in advance, this is not a definitive answer. I bought the Pro wheels to put on my Off Road and moved them a few times before getting them installed. There's no way they are 34+ lbs, just based on how easily I was able to handle them. if I had to guess I'd estimate they're 25–27 lbs each.
Maybe someone who's yet to install them can weigh them for the community. I'd like to know definitively as well.
TRD PRO Wheel is about 30#
Turns out I did weigh the tire plus wheel combo. I don't claim this is a particularly accurate weight measurement - its on a Garmin bathroom scale. The tire just fits and balances. this is TRD Pro wheels with Toyo 285/70/18 E-load tires. They are specified to be 57# by Toyo. This would make the wheel 40# (less the weight of the air??) - which seems high but you make the call on my measurement technique. (CORRECTION: I ORDERED 285/70 BUT RECEIVED 285/75 - SPECED BY TOYO AT 67#. THIS MAKES MORE SENSE: WHEELS ARE ~30#)
For comparison, the TRD Flat Black option wheel measured at 28#. Its 8" vs 8.5" width of the TRD Pro wheel.
Note that I've switched the Toyo 285/70 tires to these wheels because I was getting rear wheel rub on fenders off-road and the change in offset (+45 vs +20) made the difference. It also eliminated the very slight front tire rub on the felt & air dam screw tab. Bottom line: For TRD Off-road there is no question in my mind that the closer to stock offset is better choice for fitting larger tires. (I've seen folks suggest that less offset is better but my data says they are wrong.)
And, although I don't trust my measurement technique, it would appear/seem that the TRD Pro wheels are heavier than the TRD Flat Black option wheels - consistent with the slightly smaller width.
TRD PRO Wheel with Toyo 285/70 E-load (CORRECTION 285/75):
TRD Flat Black Option wheel:
mcd_ovrlnd
mcd_ovrlnd
SE PA
Thanks for this. Found another guy on this thread who said he weighed them at had 28.75. So sounds like 28.75-30 roughly.
mcd_ovrlnd
mcd_ovrlnd
SE PA
Love that you guys found these. I spent 30 mins looking on internet and didn’t come up with either of these resources. Thanks!
gtr022001
PW
hah ive been doing the same, what new wheels were you thinking of to reduce the weight gain with bigger tires? ive been researching 34" toyo at3 load c's but just dont know what rim to pair it with :D
mcd_ovrlnd
mcd_ovrlnd
SE PA
I was excited about a Load C Toyo but from everything I can tell, the ones I was looking at only have 2 ply sidewall. That’s what my OEM has and looking to upgrade. I’ve got a whole excel spreadsheet built around the tire choices.
Re rims been looking at Method, RRW, Black Rhino and KMC. Trying to stick with rims that are forged or flow forged.
That video and web site table are gold.
Hey Administrator Jay - I think this web link and video belong on the first page of Factory Wheels & Tires.
Note that the linked table is missing the Flat Black Option wheels - which I weighed to be 28.5 # (no tire mounted so straight accuracy of scale). AND I rechecked my data on the TRD PRO wheel: I weighed the wheel with a Toyo A/T III 285/75R18 mounted. Toyo's web site says this tire is 65# (not 67# as I incorrectly said in linked thread above). I weighed the combo to be 97.6#. So... my indirect weight of TRD PRO wheel: 97.5-65= 32.5#. A bit less than the 34# from the edmartin site. But relatively close.
mfoga
r4unner
There is the option wheels at the bottom.
TRD 18" wheel (4Runner / Tacoma)W0 (PPO)PTR56-35242-F118" x 8"Black (satin) 45 28
gtr022001
PW
Mind sharing the spreadsheet once you got it narrowed down to your top 5?
