Unit38
Joseph
IL
2025 Toyota 4runner Trailhunter
Finally finished the Westcott front preload collar lift, OME rear spring, and 35x12.5x18 Baja Boss AT tires.
Very surprised how well this rides compared to my 5th gen, even with the D-rated tires, it's very smooth.
2025 2026 4runner 6th gen Trailhunter Build: Lift & Tires Are On!  Westcott front preload collar lift, OME rear spring, 35x12.5x18 Baja Boss AT tires 4Runner Trailhunter Westcott front preload collar lift, OME rear spring, 35x12.5x18 Baja Boss
2025 2026 4runner 6th gen Trailhunter Build: Lift & Tires Are On!  Westcott front preload collar lift, OME rear spring, 35x12.5x18 Baja Boss AT tires 6
2025 2026 4runner 6th gen Trailhunter Build: Lift & Tires Are On!  Westcott front preload collar lift, OME rear spring, 35x12.5x18 Baja Boss AT tires 5
2025 2026 4runner 6th gen Trailhunter Build: Lift & Tires Are On!  Westcott front preload collar lift, OME rear spring, 35x12.5x18 Baja Boss AT tires 3
TurnerXC
Brad
Richmond, VA
2025 4Runner TRD Pro
Looks amazing! So you did you just install the Pre Collar kit up front? Which spring did you use in the rear? Was that to level it or was it for additional weight?
grey
california
2025 4 Runner Trailhunter
How is your gas mileage now? Also did you trim anything so there’s no rub?
jcash25
jason
Houston
2025 TRDO Premium
Why the preload collar? Is it suppose to level the front with rear?
Unit38
Unit38
Joseph
IL
I tow a little trailer, so I wanted the springs instead of the puck. OME med. rate spring.
Unit38
Unit38
Joseph
IL
No trimming at all, at the moment I didn't even remove the "crash bar"... I'll remove them this weekend, so far they're not even rubbing them.
Gas mileage is hanging around 15.5.
Unit38
Unit38
Joseph
IL
Preload gives 2.5 front lift and 1.5 -2" lift in the rear with the OME springs.
jcash25
jason
Houston
2025 TRDO Premium
ok so this is a more for looks and tire clearance.
Aside from cost or lack of... why use a collars wouldn't this eventually prevent some travel limits of suspension? It would make more sense if it wasn't a trail hunter this seem like kind of limiting the trail hunters suspension...I'm genuinely curious not just poking holes in your build.
NotApplicable
WA, USA
4Runner, IONIQ 9, Sprinter
In some shots the rear window on the 6g looks comically small, I really notice when it’s rolled down like this!
3rdRunner
Bill
4Runner Trailhunter Westcott front preload collar lift, OME rear spring, 35x12.5x18 Baja Boss...webp
Like it a lot! Which OME spring did you use in the rear?
IRFAN0922
irfan
2026 Toyota 4Runner SR5
Sorry, but I do not agree. I tested it myself by making these adjustments.
Compressing the spring gives you more ride height, but it makes the ride comfort much harder (stiffer). This is not true,people lie on the internet. The ride gets worse; that is the truth.
I have experience with this. A stiff spring will make your tires wear badly because the hard bouncing response will hit the tires against the ground harder, which can cause tire cupping.
Anyone who installs spacers or a lift and compresses the spring to gain lift will 100% make the ride harder.
Second, tire cupping, as I mentioned above.
Third, never go more than 2 inches in the front and 1.5 inches in the rear for ride height. Going higher than that can cause your vehicle’s suspension, braking system, and other components to wear out or get damaged within a year.
Robb_D
2025 TRDOR DCSB IFM 1L7
Compressing the spring does not increase the spring rate, so no, the ride does not get stiffer in this due to preload. Increasing spring rate moving from a 400 to 500 lbs spring will absolutely stiffen the ride.
Where ride quality deteriorates on a lift is in the loss of down (droop) travel... As you lift higher into the stroke, the wheel has less available down travel, thus when you hit a bump and the tire rebounds down it has less room to droop so you feel the effect of the missing stroke.
To call a subjective feeling truth is a stretch. Some people notice immediately, some people never notice. It's subjective there for the truth is that you do loose down travel full stop. Subjectively the ride quality is determined by the end user.
Stiff springs don't have anywhere near the impact on worn tires, bushings ball joints... as much as bad alignment. Tire cupping will happen over time as a function of wear, this is a part of a regular rotation with balance.
FoRunna
Atlanta, GA
Looks really solid man
This is almost completely untrue. Your braking system doesn't care how much taller your vehicle rides, so long as it isn't tugging on brake lines at full droop. (That doesn't really happen on these.)
The only thing it can affect at higher lift heights is CV's, but that is entirely dependent on how it's driven as well. If you're never cycling the suspension at 2.5-3" of lift height, your CV axles don't care.
get.outside.75
Brian
Charlotte
Limited iForce max
You are 100% certain on all your facts...yet...I have the pre-load lift and the ride is not harsher at all. Or maybe I am just a liar.
And all those people that have 2.5+ lifts on their 5th gens for a decade must have had spent a lot of money replacing all those parts every year LOL.
