Sleepy808
Hawaii
2025 Underground Pro
Tires: Falken AT4W 285/70r18 C-rated
Wheels: Volks TE37SB 18x8.5 +22 in Black Shadow LTD finish (translucent matte)
Lift: Peak suspension 1 inch spacer lift in front
Slider is Greenlane offroad’s aluminium slider (25 lbs each). I don’t offroad so I didn’t want the weight but I did want the shopping cart protection lol.
Install by Autocustoms in Honolulu, HI.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1670
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1673
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1676
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1672
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1679
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1674
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1671
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1680
Kjsturgeon
Kyle
illinois
2025 4runner SR5
Looking at putting new tires on my 6th gen SR5 when it gets here…what would be the biggest tire I can go without rubbing or lifting?
What recommendations on tires would be good for the sr5
KTRAN
Kevin
Bay Area CA
4R
You can fit up to 33" tires on a stock SR5. Here's some threads on the biggest tires you can fit on SR5 without lifting or rubbing:
285/70/17 Tires (33's) biggest tires that fit on stock SR5. No lift & no rub (photos)
Do SR5 wheels fit 33" tire (i.e. 285/70R17) or what's largest size? Do 2025 TRD Pro wheels fit without modifications?
SR5 - What tire size will go on stock wheels without offsets or other changes
Gastan
Tacoma TRD Pro
Saw this stock 6th gen TRD Pro posted with Falken Wildpeak AT4W 285/70/18 tires (no lift). The owner Christopher M. said:
285/70/18 are just right on the 6th. No removing of the "crash bar" nonsense to fit tires that don't fit. All fender liners intact. The faintest of rub on the fender liner if turning and hitting a dip at line 5-10mph - but so minor it's not even worth adjusting (removing or cutting) the liner. (y)
The spare tire is still OEM tire, however.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 2
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 8
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 3
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 7
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 4
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 6
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 285:70:18 on TRD Pro (stock, no lift) looks perfect 5
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
Ice Cap TRD ORP
Westcott 2.5/.75 lift
KMC IMS 17x8.5 +25 offset bronze wheels
35" Toyo Open Country RT Trail 35x12.5r17 (35's)
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! ail-35x12-5r17-kmc-25-offset-westcott-2-5-22-0-jpg
Vildhjarta
2025 4Runner Off-Road Premium
Westcott Designs pre-collar lift 2.5" /0.75"
Method 703 Double Black 17" +35mm offset
Falken Wildpeak 285/75/17 (C load rating)
No trimming or rubbing with this tire setup, only had to remove the crash bracket, mudguards and moved the front lining forward a little.
Other mods:
0 degree rock sliders
Rigid Industries Yellow SAE Fog Lights
Beatsonic Amplifier
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! _A1M8832
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! _A1M8831
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! _A1M8827
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! _A1M8825
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! _A1M8821
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! _A1M8817
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! _A1M8816
Franco
Frank
San Clemente, CA
2025 4Runner TRD Off-Road
Got the suspension, wheels and tires installed yesterday Baja HQ
Ready Lift SST 3 inch front, 2 inch rear lift kit
Fuel Fortress Wheels 17x8.5 25ET (+25mm offset)
285/75/17 Toyota AT3
Looks perfectly level to me which was what I wanted. Rides and drives great! Plus it still fits in the garage!
Super Stoked!
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3432
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 538029431_2327956197657393_5524884208759956776_n
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3435
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3443
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3434
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3427
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3440
Franco
Frank
San Clemente, CA
Super Stoked!
bkw777
Brian
NJ
25 SR5, 96 SR5
Continental TERRAIN CONTACT A/T LT265/70-17E 121S
LT type, E sidewalls. Has deeper tread depth than the next best available size.
255/75 R17 tread depth 12/32"
LT265/70 R17 tread depth 16/32"
Original SR5 17 inch wheels & stock suspension, no lift, spacers, offset, nothing. Mudflaps still on.
I just wanted a little bigger for looks and better snow & mud tread because the factory geolander were like car tires. And Continental are excellent in rain.
I didn't want to change anything else, no new wheels with a different offset, no lift or spacers etc, and didn't want them actually oversized for the wheel wells, just a bit bigger and more tread.
Completely happy with them, looks and performance.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20250824_113106006
perryj101
Joe
St. Peters, MO
2013 Toyota Venza XLE
TRD Sport Premium with TRD Pro wheels and BFG Trail Terrain T/A tires (265/65/18). No leveling or lift kits.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6974
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6973
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6972
