Keith B
Keith
PA
26 4Runner
Just added 275/60R20 Bridgestone Dueler tires on OEM wheels. Average mpg has been 16.5 around town here in hilly Pa. Have the factory lift as well. No rubbing and clears the upper control arm by about an inch.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260804_164312
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260804_164221
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20260804_164204
CrashNowhere
Jean
2026 Toyota 4Runner TRD Off-road Premium
Hi there!
Here is my '26 4Runner TRD Off-road Premium.
So far, it has;
> Prinsu Pro Roof Rack
> 270deg Awning / a privacy tent\
> ROAM cases
> 3in lift kit (ReadyLift),
> rock sliders from CBI,
> and recently added 35in tires (35x12.50xR18) A/T tire; BFGoodrich All-Terrain T/A KO3.
I had Impulse Offroad work on the lift kit, and tires set up. They added a spacer to keep the OEM wheels, and did some light trimming inside. Ride feels good on city, and on highway. Obviously, heavy tires, so acceleration feels heavy, but once you get speed, is smooth sailing. A/T tires are very quiet on the highway. It seems there is a slight +2 mph variation while above 65ish mph range. I haven't gone offroading with these new tires, so we will see what is the real feel.
Any questions feel free to reply. I am new to this since March-2026. I've been to Moab, Uinta/Wasatch/Ashley National Forest, some Utah trails, and soon to Colorado.
Thanks FAM!
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 761909762_1406402394711654_7734970981345720932_n
PdlMnk
6G4R - TRD ORP Premium Hybrid
Yes E load. No big change. It's still shit MPG lol apparently it takes a while for the car to show its true efficiency. Have you heard this? I drive mostly highway and I'm only getting about 230ish miles out of a tank. Haven't calculated mpg per tank tho. And the little calculated on dash just shows current mpg. Cruise and lane sensing works great still. The only issues are these KMCs. They don't balance well and have vibrations. Ill be swapping back to a Method Wheel soon. Don't like the feeling of these rims. My Discount Tire had to return one of the wheels cause the balancing machine kept asking for more weight. They figured its a faulty wheel. I think they're all shitty tho cause they rebalanced all of them and they still have a vibration to them that my previous Method rims didn't. Sorry for the rant.
Last thing I'll leave you with is these K03s look skinny at 295 lol I wish they were wider. But by design they kind of taper into the tread pattern which is narrower than the full width.
Noooo! I was about to order these wheels. Did you end up changing them out?
SunnyOffroad
David
Scottsdale AZ
2026 4Runner
17x8 +35 black rhino stadium wheels
285/70r17 nitto terra grappler tires
Only a bit of sidewall poke.
No rubbing anywhere.
Stock suspension.
I'm looking at this specific wheel and tire size combo, most likely will go with Open Country M/T Trails. How is this working for you? Thanks. David.
Henry
Henry
CT
rgall927
Ryan
Charleston, SC
2026 Toyota 4Runner SR5 - Underground
PdlMnk
Donmega87
Ryan
AB
2026 Toyota 4 runner Limited
Hey everyone, I'm new to the forum.
Just got the huge 20s off my limited.
Went with some work meister S1 s with some Toyo open country AT3 tires (285/70/17).
What do you think? So far no rubbing with 285/70/R17
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 39001-27f312154565c37da23de16df9791071
PdlMnk
abejoharold
h4r.ltd_
bc canada
See full build details at: https://www.4runner6g.com/forum/thr...ted-build-daily-driver-weekend-warrior.12162/
Wheels / Tires / Lift
  • Method 709HD Wheels 0 offset
  • 285/70R17 Mickey Thompson Baja Boss MT Tires
  • Baja Designs Squadron Pro A-Pillar Kit
  • Van44 Roof Rack + Exterior Panels
  • Lexland raptor lights
  • Auxbeam 8gang switch panel RA80
  • Wolfbox G900 Pro Dash Cam
Next week..
  • Westcott Designs Preload Collar Lift
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 0688C563-E1A8-4C43-88CC-3B5302933203
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5798
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! f698e3b7-e3e0-4ff2-82ca-42dc987e9e5
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5758
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5455
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5706
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_1326
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5712
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5491
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5489
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_5505
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6892
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_8431
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! aa6a3db4-1353-40b2-86f2-c1b7f17913b6
trenz24$
Tenille
Nestle24$
Got her 3 weeks ago and have the tint, wheels and tires finally done.
Fuel Flux Gloss Black 20" wheels (+20 offset)
Toyo Open Country AT3 tires 275/55/20
Stock height, with no rub
5% tint on back windows, 20% tint on front doors and 5% strip on windshield
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
Hi! Would you mind sharing the full wheel specs when you get a chance? Thanks, I really appreciate it!
Unit38
Joseph
IL
2025 Toyota 4runner Trailhunter
Finally finished the Westcott front preload collar lift, OME rear spring, and 35x12.5x18 Baja Boss AT tires.
Very surprised how well this rides compared to my 5th gen, even with the D-rated tires, it's very smooth.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 4Runner Trailhunter Westcott front preload collar lift, OME rear spring, 35x12.5x18 Baja Boss
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 6
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 5
