305 miles to empty with full tank ?
BDuane007
Brad
Florida
Well, it knows because of the sensor in the fuel tank that provides the information for the digital fuel gauge on the dash. But this does not explain having such a low DTE after your 100 miles at 24MPG. I thought for sure I had figured out the issue but .... now I'm stumped.
Well, I will post again after I drive to Tallahassee tomorrow for Turkey Day. Then, of course I will be driving back the same way, Interstate about 90% of the way, cruise on 75, no more. Hopefully we’ll learn something. Surely by then it will change.
JGR
Gabe
From what i’ve experienced, 17.26 MPG. However, my commute is mostly side streets with some highway driving on weekends.
The estimated mileage is definitely based on your driving habit, and not counting our reserve.
Reserve tank seems to be at 2-3 gallons, I’m tempted to run an experiment on what the reserve level is after the fuel bar disappears. Lol
Trying to make sense of things, quick math is take your current MPG and multiply that by 2.5 for your “safety net” miles. Add that to your estimated miles left and thats our actual total based on latest driving habits.
I record my fuel fill ups with “Road Trip” and like looking at the data trends.
2025 2026 4runner 6th gen 305 miles to empty with full tank ? IMG_1378
AdFour
Washington
You probably do not want to do that. That reserve is to cool the fuel pump.
funny mine always comes back at 305 after a fill up.
Interesting. My data below is based on recording (photo) the DTE before and after fill up over the last 27 fillups and almost 9K miles. When running with air dam and OEM TRD ORP tires I've seen the DTE value after fillup as high as 366 when tank milage was 24.4; with air dam off and 285/70R18 Load E tires on TRD PRO wheels I've seen as low 294 (when tank milage was 15.1 (which included a long off-road excursion). In table below the "blank rows" are where I swapped between wheels & tires.
I DO NOT know exactly how the 6G4R calculates DTE and am interested if anyone KNOWS. (I've checked all the theories and run the equations so I'm really only interested in accurate knowledge if there is a Toyota engineer out there. Thanks
Refuel DateOdometer ReadingAdjusted Odometer (+3.4%)Tank MilesAdj. MilesGallonsFuel OctaneDist. to go -Before fill"Actual" dist to go?Dist. to go -After fillMPG TankGallons (total)MPG TotalRange Est.
7(fuel added)(mileage)
5/24/202526225515.71987?53.2?16.215.7216.7308.2
6/6/202558632415.69989?68.1?20.631.4218.7392.1
6/14/202585426814.193?93.1?1945.5218.8361.1
6/27/2025121636216.073932865.934722.561.5919.7427.9
7/4/2025148727111.76793102166.63472373.3620.3437.6
7/20/2025184836116.83493646.435121.490.1920.5407.4
8/1/2025220735916.33393658.635122106.5320.7417.6
8/7/2025251931216.211932453.735119.2122.7420.5365.7
8/17/2025290738816.505931258.736123.5139.2420.9446.7
8/30/2025328637917.12792.5-241.436122.1156.3721420.4
8/31/2025365737116.81893148.136122.1173.1921.1419.1
9/6/2025400434717.06393-339.435520.3190.2521386.4
9/13/2025436636216.95493-143.735521.4207.221.1405.7
9/19/2025473737116.459931757.336322.5223.6621.2428.3
9/20/202549061696.93893214293.836624.4230.621.3462.8
285/70 no air dam
9/24/202552115221.4305315.416.35593105134819.3246.9621.1356
######54815501270279.415.547933162.133018262.521332.1
9/28/202557605789.7279288.715.345933568.832418.8277.8520.8347.8
######60656105.3305315.617.27793-831.531618.3295.1220.7336.5
10/10/202562606307.1195201.810.5593125161.631419.1305.6720.6356.6
10/11/202565576614.5297307.317.02493-935.730618.1322.720.5332.7
10/18/202568006865.9243251.514.602934675.730217.2337.320.4318.7
######69206990.1120124.28.23493167162.429415.1345.5320.2282.4
265/70 & Air Dam
10/31/202573077377.138738716.274931364.832423.8361.8120.4451.8
10/31/202576307700.132332316.52593748.432419.5378.3320.4371.4
11/2/202579167986.128628615.041937610133220.4393.3720.3387
11/7/202581338203.12172178.50993155267.533525.5401.8820.4484.5
11/8/202584438513.131031015.324933174.433420.2417.2120.4384.4
285/70 no air dam
11/14/202587718841.1328339.416.284931056.633520.8433.4920.4384.6
11/21/202589889058.1217224.611.75393106138.532919.1445.2420.3355.5
11/23/202592629332.1274283.516.99893-733.431116.7462.2420.2307.4
Currently I have the 285/70s on the TRD flat black option wheels (+45 offset). Will be moving back to the OEM 265/70 Michelins on TRD PRO wheels (+20 offset) for long trips - to get the range and avoid stops. I like the all black look of both wheels and this solution avoids some of the rubbing on the 285s which will be on for off-roading and when snow expected where I will be. (Handed down the OEM wheels to my son and now have his 2022 SR5 Premium 17x7 alloy wheels and tires available if anyone interested:>)
From message above this in thread - there is not really any ambiguity here:
"Check out this thread: https://www.4runner6g.com/forum/thr...gas-indicator-accurate.2652/page-2#post-65870
And note that the owners manual specifies that the "Low fuel level warning light ... Indicates that remaining fuel is approximately 2.8 gal. or less.""
The linked thread shows my data that proves for my TRD ORP that, in fact, the 2.8 gallons remaining when the low fuel indicator comes on (white to amber fuel tank symbol and warning indicator), and that there is 1.8 - 2.0 gallons left when you hit zero miles to empty ("REFUEL NOW" indicator)
FloridaPhotog
Jon
SW Florida USA
2026 4Runner
I'm at 6000 miles and my distance to empty after fillig up cotinues to increase, it's currenty 382.
Cool. Better than my best which I thought was decent. You could easily go 450 miles on a tank with that and still have a bit left (assuming ~25 mpgs with that number).
Dr_Al
Alex
Rav4, Tundra
My last two daily drivers were Rav4s (2013 and 2016). Both of them acted the same way. With 30 to 20 miles left the fuel warning light would come one. When down to 0 miles left they say "refuel". Both of them had well over 160k on them. Once the words "refuel" appeared I figured i had 50 miles at most to fill it up (unless towing). Never replaced a fuel pump. I usually go at least 30.
The manual says the fuel tank is almost 16 gallons. It also said that the light would come on when it had 2.5 gallons in the tank. I've never ran out of gas and only a couple of times, when I pushed how far I could go, did I ever put more than 15 gallons into it.
I'm not worried about the fuel pump over heating (I think Toyota is just doing the usual "we must be extra safe"). When driving on my local roads where I know just how far and which stations have the best prices I can easily figure out how far each one is from me.
Do an experiment. When the gas light comes on go an extra 30 miles and see how much gas it takes to fill the tank. How close is it to the tank's capacity? Keep increasing the distance until you feel like you've gotten close to the maximum distance/ minimum fuel level you feel comfortable driving.
BTW, the idea that fuel on the outside of the fuel pump is going to cool the pump down a lot more than the same fuel going through the pump seems questionable. Most fuel tanks are long and shallow. Anything less than a 1/3 of a tank and the gas level starts to no longer submerge the electric motor. I deal with a lot of electric motors at work. I have plenty that have burnt the paint off of them yet still run just fine. Some have been in service continuously for over 20 years. There's no way the pump in a fuel tank could ever get hot enough to actually damage itself. That would be like using a match to check the fuel level.
The pumping part of it is right at the bottom of the tank. Using good quality fuel so it can properly lubricate the pump is more important than fuel level. Unless forced to I only buy from name brand stations that I know do a lot of business selling gas.
zgreen
Zach
I have a stock Pro and constantly get between 350-365 a tank on 91 Octane, at around 3,500 elevation.
ColoradoRoz
Roz
Parker, CO
2025 trd orp 4runner
This might not be the right thread for this as it's just an observation strictly on MPG that I was kind of surprised by. I wanted to share it though.
My previous vehicle prior to my TRD ORP Hybrid was a 2017 Volvo V90 CC. It was a turbocharged 4 cylinder. According to the spec sheets it was about 1000 lbs lighter than the 4runner.
In general driving around town I would get around 24-25 mpg in the volvo vs. 22-23 mpg in the Toyota, for just about a 2mpg difference between the 2. This gap changed dramatically on some highway driving. We live just outside Denver in Colorado, and frequently take trips up to the mountains along I-70. The trip we usually take is just around 100 miles. The net elevation change is around 3200ft (though there is a lot of up and down, so total ascent/descent is probably much different).
There are a ton of factors that can play into mpg on this trip, so I am just going to speak of the difference between the two vehicles generally and particularly for coming down the hill, which surprised me the most. In the Volvo, coming down the hill, I would always easily get over 30mpg. More often than not I would average around 32, though I have maxed out around 35. I've made the trip in the 4runner twice and both times topped out at 25mpg.
So in the Volvo my mpg was 7-10 higher than normal driving, while the 4Runner only was around 2-3 mpg higher.
Going up the hill, the delta is much closer (around 20mpg in the volvo, 18 in the 4Runner, both approximately 5mpg less than normal driving).
I know the estimated mpg city/hwy in the 4Runner is approximately the same. What I'm missing though is why with the extra weight and gravity assist coming downhill there isn't a larger benefit to mpg. I thought perhaps there was just that much more penalty in going uphill, but then I would have thought the mpg going uphill would have been hit harder.
In any case, I just thought it was interesting. I love the vehicle, and driving it on the highway is a really great experience. I thought I would miss my Volvo A LOT more in that regard, but the 4Runner is very comfortable.
for me DTE is a moot point. i go by what the fuel gauge reads. once it gets to 1/2 (winter time) to around 1/4 summer time, i fill up.
winter time 1/2 lasts about 1 week (from remote starts and my daily 32 mile round trip work trip).
during the summer 1/4 tank left will last about 10 days give or take 1-2 days. its enough for me and i dont really track how many miles it is per tank. i just fill at the respective fuel tank reading.
i do track the mpg but its mostly gee whiz stats. personally i dont have to worry about mpg or distance. if i was worry about mpg, i would get a unibody vehicle like a grand highlander, camry or rav4.
and on long trips, i have time at my age to stop and smell the roses so to speak. 1700 miles to visit my mom takes 3 days now, it use to take 2 days but i cant do those 900 miles a day runs anymore.
now i stretch it out to 3 days and only drive sun up to down. i actually enjoy taking the slow route now instead of rushing to my destination. and i like playing the road game and see how many times certain vehicles pass me every time doing over the speed limit and having to refuel 2x as many times vs my 1 fill up. give me a good chuckle watching them pass me again and again cause they like to run 10-15 mph over the speed limit in brick suv.
but hey each their own i guess.
Undefeatable
Kevin
Southern California
I think mine usually displays 320 miles right after a fill up.
I am on larger tires (285/70R17's).
I pretty much always just go to Costco once a week to fill up, and I work from home most of the time, so not super concerned about MPG's.
I can see how I would be more invested in it if I commuted to work though.
I’ve had mine for 6 months. Right now it’s telling me 285!
zgreen
Zach
Do you drive a lot of stop and go? Aggressively? 285 seems pretty low and translates to 15 mpg...
