noodles4u
Salt Lake City, UT
2025 4Runner SR5, 2003 Celica GT-S
Instead of trying to find a set of takeoffs, I decided to head to my local dealership and order a set of TRD Off Road shocks (red Bilsteins with remote reservoirs).
Front shock
48510-8Z696
Rear shock
48530-8Z321
List price for the front is $213.09 each and $123.85 each. for the rear. I paid $193.72 each for the front and $82.39 each for the rear, bringing the total to $552.22. The fronts will come with a spring isolator and a new nut. Rears will come with a new nut and boots already installed. You'll have to use the the existing mount for the front and existing bushings for the rear.
If you want to build up the fronts and not deal with spring compressors, you'll need two 48609-60120s, which are the upper shock mounts. List price for those are $232.86 each.
So, there you have it! I'll be ordering the @alldogsoffroad Alldogs Spacer Eraser kit to pair with this soon.
EDIT: I checked the parts on Lakeland Toyota's online parts catalog. You can get the fronts for $137.42, the rears for $58.98, and the front mounts for $165.19.
What is your goal or need for this change? Based on your tag, it looks like you are installing on an SR5, correct?
stock everything else including wheels or lots of mods?
porkyfly
Mid atlantic
2025 4runner TRD Offroad
Please let us know if they make your ride quality extremely stiff.
noodles4u
noodles4u
Salt Lake City, UT
What are you doing for springs?
Going with the Alldogs Offroad Spacer Eraser kit.
That's correct. The stock SR5 shocks are a little lacking; they're kind of harsh. It feels like they can't handle square-edged hits very welI and rebound feels a bit sluggish. I have about 2k miles with ~300 of those being off-road.
I also went camping with a friend. With our bikes, bike rack, and enough gear and supplies for the two of us, there was a noticeable amount of sag, to where it was about level.
I'm building this out to be used as an adventure/overland vehicle. I already have the Trailhunter rock rails installed. Probably going to go with LC/Trailhunter skids. Still thinking about a wheel/tire combo, but leaning towards a 285/70r17 all-terrain on a +25 offset wheel at the most. Probably going to go with a Prinsu rack.
So, yeah. Pretty mild.
I think it should be fine since it ultimately will be under some weight.
AZGOLD
AH
Prescott
2025 ORP 4runner
I have a 25 ORP, and can honestly say that the ride quality on road is jarring & rough. In my opinion, that price you quoted is about all those bilsteins are worth.
Off road ( slow speed ) they arent to bad.
alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
Good prices on the OE Bilsteins. I honestly think this is more of an upgrade in shocks than Bilstein 5100's when they release. The pricepoint will be about the same but you will get the added oil volume with reservoirs.
JGR
Gabe
I had takeoffs installed on my SR5, and love it. Way less “sway” when turning, speeding or braking. To me, it feels more comfortable and not as floaty as stock SR5.
Good idea for those who want a more affordable upgrade than aftermarket, and also want to stay OEM.
JR_Ontario
Ontario
Lexus NX
JGR, what did they charge you to replace the shocks? Just curious. I might get an ORP but would need to replace the shocks with something a little softer, I am often on bad roads and need something less jarring.
JGR
Gabe
I ended up paying ~$1200 for install with the dealership… Got a quote from third party mechanic for $1000, but they replied a week later. I was too excited to wait lol
Good luck!
xp0nex
2025 4Runner ORP
May look into grabbing the fronts. Do we just order two of the fronts? Assuming same part for driver and passenger side?
Tim
South Dakota
2025 Hybrid OR
I just removed the rear Red Bilsteins from my hybrid OR and put on Fox 2.5 shocks. I think Bilsteins are great, but for whatever reason the damping behavior of the factory rear Bilsteins (and perhaps other 6th gen trim rear shocks) is very, very wrong. The car is totally different with the Fox's. To me the 6th Gen OEM Bilsteins aren't worth the cost of the red paint that they are covered with.
