FloridaPhotog
Jon
SW Florida USA
2026 4Runner
I don't know why they stopped installing this on vehicles, but you'll still find it on Lexus and other higher end car. It was a simple install that only took a few minutes. There is a noticable exterior sound dampening differece with wind/air noise. Totol cost of the mod was $11.99 on Amazon. 2 pc 2.62 Ft is all you'll need. You will have to trim a few inches off. Start from the top of the door and install moving downward. Note- the link below says "does not fit 2025-2026 4Runner". But it worked perfectly. Link for Amazon below photo
2025 2026 4runner 6th gen Door Seal Rubber Edge Trim - cheap mod to reduce wind / air noise IMG_0590
https://www.amazon.com/dp/B0G33X396H?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
I seem to notice wind noise near the A-pillar. Have you tried this there ?
horbit
DFW
It's probably worth a shot for 12 bucks. I was imagining what could be making the b pillar wind noise earlier today and it's either where the OEM roof rack starts or the unsealed gap in the top corners where the doors meet.
Joestac
Doesn't water drain out down and out of that channel from the top of the door?
IsGon26
Israel
Chicago Metro
2026 4Runner TRD ORP HV
Yes, it’s just a wind noise reducer, I’m sure some road sound too but it’s a small gap between the doors.
KD2MYW
Phil
NYC
I ordered this too and will try.
HVLA
Lexus
The seal clips onto the pinch weld like part of the rear door. Wont affect any type of drain. Go take a look.
mick
mick
Utah
2025 6th gen 4Runner Off Road Premium, 2016 5th gen 4Runner SR5 Premium.
I want to order this seal, but the picture shows it on the leading edge of a sliding side door on a van. Any pictures with this seal installed on your SR5 FloridaPhotog?
HVLA
Lexus
It would install exactly the same way on your rear door.
horbit
DFW
Push it on the groove and cut the excess off the bottom.
2025 2026 4runner 6th gen Door Seal Rubber Edge Trim - cheap mod to reduce wind / air noise IMG_2625
2025 2026 4runner 6th gen Door Seal Rubber Edge Trim - cheap mod to reduce wind / air noise IMG_2624
mick
mick
Utah
They included a photo in their first post. The seal is the rubber on the leading edge of the rear door in the photo.
Jade4rTx
Bob
Just did the door seal as soon as it stops raining I’m off to check it out. Also upgraded my horn to Toyota premium found on Amazon, sounds much better
