Cranberry
Manitoba Canada
I recently fitted and towed with the airlift kit for the 5th gen in the 6th gen in case anyone is waiting on a kit. Firestone recently shared the same part number for their bags from 5 gen to 6th gen.
Loaded with a camaro and aired up to 35psi it raised the rear about 1 inch and lowered the front a bit evening the weight across the truck more and prevented bottoming out.
Install is probably 15-30 min if youre good mechanically, you dont even need to take the wheels off, just slip the bag thru the springs, route the lines, use the clamps. The right side bag can be a pain to get a clamp on because of the pan hard rod so I used a small ziptie and ran the schrader to one of the premade square openings near the rear bumper.
https://amzn.to/4ntipU1
im about to i stall the same kit. Curious where you ran the actual valve to?
Joey_Midnight
Joey_Midnight
NJ
4runner ORP, GT4, BRZ
To the bottom back right side of the bumper opposite of the tail pipe. There are a bunch of little square openings under there, just double nutted the valve there. Super easy to air up
T4RAZ
2026 4Runner ORP 2026 4Runner ORP
Has anyone else installed these yet? I just got mine delivered this morning. Ive seen some people install with the tubing up and others with the tubing down
Cranberry
Manitoba Canada
I am having mine installed monday next week. I can post an update then!
stansmith7777
Utah
Thanks for the help Joey, I installed mine today however mine didn’t go on in 30 minutes 🫣. My brain couldn’t get over the nipple and hose clamp getting bound up inside of the coil so I ended up removing the springs and drilling out the top hole to allow adequate space for the nipple and clamp. Installation was fairly straightforward even though the directions were for a generation 5 4 Runner, the differences are obvious and they work great.
How's this set-up working for you over the course of the year? Any issues? I emailed Air lift and still are saying these aren't compatible?
Cranberry
Manitoba Canada
i have installed this identical system in my 2026 and it has been flawless. Roughly 4000 km of towing about a 6000 lb load with 420 lb tongue weight and they have completely made towing a breeze.
You wont regret this upgrade if you tow often and regardless of them saying its for a gen 5 and not a gen 6, they do fit and work flawless on my gen 6
Joey_Midnight
Joey_Midnight
NJ
Its been perfect, zero issues. Actually just accidentally towed 9500lb with a loaded dump trailer while remodeling my kitchen. I pumped the bags up to 30psi and kept pushing, it was only a couple miles to the dump but the truck did great. Typical trips are 200 miles with the car trailer with the bags at 15psi
bobholthaus
Bob
St. Louis MO
Jeep JL-370 AEV Diesel
I had mine installed this week at eTrailer and they're working great. I towed my boat with them this weekend. I had them put the valve stem on the left side, right above the exhaust pipe, and I am already regretting that (exhaust blowing on me while inflating). I will likely move it over to the passenger side.
2025 2026 4runner 6th gen Air Lift Air Bags Suspension installed (5th gen version fits 6th gen) IMG_1955
