Joey_Midnight
NJ
4runner ORP, GT4, BRZ
I recently fitted and towed with the airlift kit for the 5th gen in the 6th gen in case anyone is waiting on a kit. Firestone recently shared the same part number for their bags from 5 gen to 6th gen.
Loaded with a camaro and aired up to 35psi it raised the rear about 1 inch and lowered the front a bit evening the weight across the truck more and prevented bottoming out.
Install is probably 15-30 min if youre good mechanically, you dont even need to take the wheels off, just slip the bag thru the springs, route the lines, use the clamps. The right side bag can be a pain to get a clamp on because of the pan hard rod so I used a small ziptie and ran the schrader to one of the premade square openings near the rear bumper.
https://amzn.to/4ntipU1
2025 2026 4runner 6th gen Air Lift Air Bags Suspension installed (5th gen version fits 6th gen) Air Lift Air Bags installed 2025 4runner 6th gen 2
2025 2026 4runner 6th gen Air Lift Air Bags Suspension installed (5th gen version fits 6th gen) Air Lift Air Bags installed 2025 4runner 6th gen 1
2025 2026 4runner 6th gen Air Lift Air Bags Suspension installed (5th gen version fits 6th gen) Air Lift Air Bags installed 2025 4runner 6th gen 3
Is this airbag upgrade purely for leveling and towing or can it be used to “soften” the suspension over road ruts and potholes?
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
I think this is the first air suspension kit I've seen installed on a 6th gen. And I'm curious about the ride quality improvement with the Airlift air bags - same as factory or better?
Joey_Midnight
Joey_Midnight
NJ
This is purely for leveling and stiffening the rear springs for carrying heavier weight. Its not an air suspension that you would find in a luxury suv, that would replace the spring entirely instead of supplementing it.
with out the trailer i drop it to 5psi and it rides the same as stock, while loaded with a trailer its up to 25-35psi and is better because i dont hit the bump stops anymore, but the Bilstein shocks do great at controlling the trailer or any bouncing.
CMill4Runner
Craig
CO
Got a part # by chance?
CMill4Runner
Craig
CO
Joey_Midnight
Joey_Midnight
NJ
Thanks those are the ones I was looking at but wasn't sure they'd fit!
I wasn't sure either but i couldn't keep hitting bump stops with the trailer haha so far im sitting around 15-20 psi with the car loaded to balance the ride height and ride quality with the bags
CMill4Runner
Craig
CO
Just got mine from Amazon today now just need to install them. Did you have to take the spring out to get them in or wedge them in between the coils?
Joey_Midnight
Joey_Midnight
NJ
Just wedge them thru with the car lifted of course, since we dont have the bump stops to cut out its easy, don't even have to pull the wheels off
Wilburcat
Tacoma, WA
2026 4 Runner
Thanks for the help Joey, I installed mine today however mine didn’t go on in 30 minutes 🫣. My brain couldn’t get over the nipple and hose clamp getting bound up inside of the coil so I ended up removing the springs and drilling out the top hole to allow adequate space for the nipple and clamp. Installation was fairly straightforward even though the directions were for a generation 5 4 Runner, the differences are obvious and they work great.
Vincenzo
Southeast
I don’t know what the instructions say, but, it looks like the OP installed his with the schrader pointing down. My brain tells me to point it down so it can be drained if need be due to moisture that is inherent in compressing air
bobholthaus
Bob
St. Louis MO
Jeep JL-370 AEV Diesel
I have had airlift airbags in the last three or four vehicles and most of them installed with the Schrader valve up.
By the way, will this set up work on a Trailhunter? Maybe I need to read this again. I literally sent this to my contact at eTrailer this morning here in St. Louis Missouri to see if they will now install these in my new Trailhunter that’s supposed to show up in a few weeks. Thank you for this post. I love airlift airbags and I will need them on this vehicle to tow my camper.
EDIT: I just talked to eTrailer and they are going to install these for me for free (I pay for parts only). They will make a video of it and post it to their website. They do this on any vehicle that is their "first one"; such a deal for me. I strongly suggest you buy from eTrailer (the eTrailer part number is AL94VJ which is the 60804 in this post)
CMill4Runner
Craig
CO
Nice and yes great for you, let us know when the video is out as I still haven't installed mine. I decided to wait until after winter not that we really had one here in CO.
bobholthaus
Bob
St. Louis MO
The truck is held up in "inspection", so it may be 2-4 weeks. Then I have to schedule it. So you may have to be patient but I will indeed post here when that video is up. eTrailer does a great job with those!
