Cranberry
Manitoba Canada
I recently fitted and towed with the airlift kit for the 5th gen in the 6th gen in case anyone is waiting on a kit. Firestone recently shared the same part number for their bags from 5 gen to 6th gen.
Loaded with a camaro and aired up to 35psi it raised the rear about 1 inch and lowered the front a bit evening the weight across the truck more and prevented bottoming out.
Install is probably 15-30 min if youre good mechanically, you dont even need to take the wheels off, just slip the bag thru the springs, route the lines, use the clamps. The right side bag can be a pain to get a clamp on because of the pan hard rod so I used a small ziptie and ran the schrader to one of the premade square openings near the rear bumper.
https://amzn.to/4ntipU1
im about to i stall the same kit. Curious where you ran the actual valve to?
Joey_Midnight
Joey_Midnight
NJ
4runner ORP, GT4, BRZ
To the bottom back right side of the bumper opposite of the tail pipe. There are a bunch of little square openings under there, just double nutted the valve there. Super easy to air up
T4RAZ
2026 4Runner ORP 2026 4Runner ORP
Has anyone else installed these yet? I just got mine delivered this morning. Ive seen some people install with the tubing up and others with the tubing down
Cranberry
Manitoba Canada
I am having mine installed monday next week. I can post an update then!
