jjb07
Jairon
Norwalk, CA
2025 4runner trd off road
Updated with install video:
Hey guys!
Fox has released their 2.0 Performance Series shocks for the 2025 4Runner and we picked up a few of their first sets. We recently installed them on our SR5 and will be posting an install video on youtube in the near future.
If you're familiar with the Fox 2.0's, not too much has changed. They're still an impact extruded aluminum body IFP shock with 5/8" shafts. They redesigned the tophats in a similar manner to what is found in the 24+ Tacoma / 25+ 4Runner where they are using a captive bonded bushing which runs longitudinally rather than the loose horizontal sandwiched poly bushings with washers at top and bottom which they've used historically. The coils are now a 3.75" ID coilover coil, rather than 3" ID like used previously in other applications.
I'm a big fan of this series of shocks and have used them in a number of different applications. The fit and finish is really nice, and they use o-rings at the lower coilover mount to seal the spherical bearing from dirt and grime. They are rebuildable and revalveable (as long as you or your local shock builder have the specialty tools to do so). I really like the internals on these shocks, everything is clean and really well machined. They use a bleed shim rather than ports drilled into the piston. I also like that they use poly bushings to isolate NVH from being transmitted to the chassis vs the bigger race-inspired shocks like Fox 2.5 Performance Elites, King, Icon, ADS, etc. I do a lot of highway miles for tradeshows and expos and from experience NVH definitely adds to driver fatigue over long distances.
I've put about 4k miles on them already and they are a significant improvement in ride quality over the factory SR5 shocks, which felt too firm on compression and too light on rebound. They'll be my primary shocks over the next couple years. I may play with the valving at some point as my build progresses, but at the moment I don't feel like any changes need to be made.
Out of the box, they lift a hair over 2" in the front. If you installed them as-is, you'd be dead level if not a hair nose-high. If you wanted to upgrade and keep factory height in front, you'd want to move the preload collar down about 1" from where it sits. Otherwise, you can add a lift coil or spacer to the rear to keep a little rake.
Are new aftermarket UCAs needed?
PierceVonCloud
Tim
South Dakota
2025 Hybrid OR
Uhhh the OE Bilsteins on the Tacoma 4G OR felt way softer (better) iirc than the OE bilsteins on my 4runner 6G OR. They didn’t have the deadful jitter/harshness over broken pavement.
I'm glad I'm not alone thinking the 6G OR ride is horrible on anything but smooth roads. I would buy the Fox 2.0's in heart beat if some other red Bilstein 6G OR owner would confirm that they calm down the ride. I really don't want to be disappointed with aftermarket shocks after spending $54k on a 6G (and trading in my 5G, which I thought had a very nice ride on broken pavement). The powertrain and torque of the new OR is soo much better than the 5G. If I could just get it to ride decent, it would be perfect.
Ivan Aquino
Ivan
Peru
4runner SR5
Hey guys!
Very nice! ... Do you think fox 2.0 with Upper control arms (UCA) could have 3" lift in the front and 1.5"? would in that produce the same comfort on and off road? I am planning this lift because I want to put 35" tires on my 4runner and it is needed a higher lift in both front and rear. Thanks
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
You should be able to clear 35's with 2" of lift on these vehicles. I do not think you can push the 2.0's to 3" lift due to limitations of the shock.
Ivan Aquino
Ivan
Peru
4runner SR5
Totally agree!! the rides of the new 4runner is not good, I feel it rigid/stiff... So far, I am evaluating to install either OME MT64 for the new 4runner or Fox 2.0 but I am not sure if Fox 2.0 can be set to have 3" front lift and 1.5" in rear, I need this lift cause I would like to use 35" tires.
Ivan Aquino
Ivan
Peru
4runner SR5
I understand. So it ts not possible to lift 3" even with upper control arms? or other parts? Thanks
Wsspitz
Scot
San Diego, CA
6 gen 4 runner
I am new to 4 runners so I apologize if this is a dumb question but, i went to off-road warehouse to get 2.5 fox coil overs installed. They said they couldn't do it because my 2025 4 runner platinum had electronic suspension. How did everyone get around this. Please educate this newbe.
jjb07
Jairon
Norwalk, CA
Hey guys!
Sorry, I’m new to suspension upgrades. I got a 25 4Runner OR, and I would like to lift it exactly like yours without buying new UCAs. I really like how yours look like. I currently have a Westcott lift preload collar, but the ride is too harsh. I’d like to try this since everyone is saying this is very comfortable.
Did you install the front coil overs at it it’s preset height at 2”? Also, you mentioned putting a spacer in the rear springs, if I have a 0.75 “ already installed there (springs are stock) , would setting the coilovers at 2” achieve level or even slight rake in the front? Thank you.
alldogsoffroad
alldogsoffroad
Chad
Lincoln, NE
Yes, I installed them as they came out of the box with no adjustment made.
I think you'd end up pretty close to level with your spacer. If you wanted rake you would probably want to slightly reduce the preload.
