silver6thGen
Blake
Phoenix
2025 TRD Sport 4x4 4Runner
2025 TRD Sport 4x4 on Westcott Designs Lift, Baja Designs LP4 Ditch Lights, Westcott Designs Rock Sliders and a 16-Piece set of rock lights.
Wheel Specs - METHOD WHEELS MR703 BEADGRIP 17X8.5 +35MM OFFSET 6X5.5
Tire Specs - TOYO OPEN COUNTRY RT PRO 35X12.50R17
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9982
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_8627
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7525
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9614
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9973
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Nice pic with backdrop from Cow Pies TH parking.
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
Black TRD ORP on:
Vossen HF6-4 17x9 0 Offset Wheels
Mickey Thompson Baja Boss AT 295/70/17 Tires
ReadyLift 2.5 Inch lift kit
Alpharex Nova Headlights
OEM TRD Pro Grille
Ceramic Coating by ReeksRestoration
Build by MJ Motosports
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Black TRD ORP build: Vossen HF6-4 +0 Offset, ReadyLift 2.5 Inch, MT Baja Boss AT 295:70:17, Al
Keroppi
Hawaii
Wave Maker 2026 4Runner TRD Pro build with:
Lock Off-road Mojave 17x9 0 Offset wheels
BF Goodrich KO2 35" tires (LT315/70R17)
King Coilovers 3" inch Lift Kit
Icon Billet Upper Control Arms
Dr KDSS Bolton Trackbar Correction Kit (BOTCK)
Build by MJ Motorsports
See original build thread @ https://www.4runner6g.com/forum/thr...er-6th-gen-add-yours.2207/page-29#post-118206
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Wave Maker 2026 4Runner TRD Pro build: Lock Off-road Mojave 0 Offset, 35%22 BFG KO2 tires, Ki
viper2788
Daniel
PG County, MD
2026 TRD ORP
Falken 285/70/18 on TRD wheels on my TRD ORP.
I really love this set up and the ride is great.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
Are those wheels 7" wide? Looking for TRD wheels and they all seem to be 7", hoping to fit those same tires as you on stock suspension.
Meant to quote this:
The wheels in the photo you linked are TRD Flat Black option wheels. 18x8"
TRD PRO wheels are 18x8.5"
TRD OR stock wheels are 18x7.5"
The only 7" wheel is the SR5.
NO 6G4R "TRD" wheel is 7".
nice reference: Factory Wheels & Tires.
And lastly. Be attentive to offset if you are going to run those Falken 285/70. Best bet for fit is your stock TRD OR wheels or the TRD Flat Black option wheels (which is what I run my Toyo 285/75s on). The lesser offset of the PRO wheel may prove somewhat challenging - likely rub on front and back of front wheel requiring some removing of things (doable) AND the rear wheel will likely contact the fender flare at full upward articulation. This is what caused me to swap from TRD PRO +20 to TRD Flat Black +45.
Desert_6Gen
Bronco
From the 4 wheels I'm looking at none of them are hub centric. Not to mention there aren't any wheels with our hub size. Is everyone using hub centric rings for your wheels?
viper2788
Daniel
PG County, MD
2026 TRD ORP
2026 TRD ORP picked up a week ago! Nothing unique here but I'm so glad to have finally replaced the OEM wheels. I've been stalking this thread for awhile now and finally get to contribute =)
-Method 703 bronze w/ 35mm offset
-Toyo Open Country A/T3 in 285/70/R17
-Stock suspension
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4961
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4975
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4966
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4963
Desert_6Gen
Bronco
-Stock suspension
Now I know how bronze wheels will look on a HB. Glad I made the right choice even though the wheels I choosen are different.
rnys9
New York
2026 4Runner SR5
Changed out the shoes on the SR5. Went with Cooper Discoverer Road and Trail in 265/70/17 on the stock wheels. Looks better than the car tires it came with. Very quiet but think I need to adjust the psi lower to find the right feel.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6260
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4047
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6259
BillyG4Runner6G
Billy
Delaware
35” Toyo Open Country AT3’s w/ Westscott pre-collar lift.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7420
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_7421
2thless4R
Ethan
2026 4Runner SR5
Any change in MPG? What psi did you end up at?
Really curious what your experience is like with those, I was thinking about doing the same exact swap!
YanMik
Ian Escala
2025 TRD Offroad 4 Runner (Soon)
No Rub a Dubs even on Full lock. I plan to go to Santiago Peak tomorrow and will update yall.
RRW RR7-V +25 offset wheels
285/70r17 Wildpeak AT4W tires
Stock Suspension with 1.5: Readylift lift at front
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9192
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9191
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 33089-4b725c3b304269148f0c2190a51fa846
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 33090-65d970004cc01982b82a15474c3e7935
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 33091-4ec7ab6b8d408e34af51ee13dfc7cb86
RSPNDCO
Matthew
Kailua-Kona, Hawaii
2026 Underground 4Runner
+ Rough Country 3.5” lift with M1 shocks
+ 295/70/17 XComp Gladiator M/T
+ stock SR5 wheels
+ 1” TNA wheel spacer
+ Full body PPF with ceramic coating on wheels/plastic/glass
+ 20% tint all around over factory
no rubbing at full lock and at articulation off-roading.
no trimming
great clearance
Adaptive cruise control is a little less accurate but it’s probably because the cameras are thrown off by the different angles. Still does great on slight curves and straight highways
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9316
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9310
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9312
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9299
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9346
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9348
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9319
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_9320
3rdRunner
Bill
+ stock SR5 wheels
no trimming
great clearance
Looks great…and from the pics it’s taking care of business off road. Nice!
