Dario
Portland, OR
Land Rover LR3
Below is my report from oil analyzers. I expected the gas in the oil to be high due to direct injection, but most of the last 300 miles before testing were freeway miles. The aluminum is not too high, but the Silicon is quite high. Not sure why the silicon is high - maybe gasket sealant? Unfortunately I did not get analysis done on the oil from the first 700 miles.
In the notes they tell me to let them know that it's direct injection. I assume this so they won't call the amount of gas high. I see now way to do this on their equipment list.
Couple of complaints:
- I didn't get any email update about my sample getting received or tested by them
- Their online tools to set up equipment and submit samples is terrible. I do software for a living. This is right out of the early 2000s from a UI perspective
2025 2026 4runner 6th gen Oil analysis report - 2026 iForce Max Hybrid engine (~800 miles on oil, total miles ~1500) tem
rosnaby
alex
new jersey
4runner trd off road premium hybrid
How often is your plan to change oil? Are you going to start lengthening your oil change intervals more towards the 5k mark? does this data change any of that?
Dario
Portland, OR
Land Rover LR3
I plan to change it again at 5K and then probably every 4K. I'll get more analysis done and will change at 3K if it continues to have high gasoline percentage, but I'm hoping 4K works.
I forgot to mention that my oil was surprisingly dark, especially with only 800 miles on it.
ls3673
Luis
NYC
Does anyone know if the car both direct injection and Port Injection? If so, does that eliminate the carbon buildup issues on the intake manifold?
CMill4Runner
Craig
CO
Are you doing another analysis at those oil change intervals, if so should tell a better story?
toyota hasnt done DI only since the 1990s and 2000s with the old D-4 engines. they moved to D-4S afterwards (DI and Port)
these are the codes after the engine
Key 4Runner Engine Codes by Generation:
  • 6th Geb (2025+): T24A-FTS (2.4L I4)
  • 5th Gen (2010+): 1GR-FE (4.0L V6)
  • 4th Gen (2003–2009): 1GR-FE (4.0L V6), 2UZ-FE (4.7L V8)
  • 3rd Gen (1996–2002): 5VZ-FE (3.4L V6), 3RZ-FE (2.7L I4)
  • 2nd Gen (1990–1995): 3VZ-E (3.0L V6), 22R-E (2.4L I4)
  • 1st Gen (1984–1989): 22R/22R-E (2.4L I4), 3VZ-E (3.0L V6)
the codes after the "-"
  • A - Valvematic variable lift intake head
  • B - Twin SU-style side-draft carburetors (After 2000, 'B' indicates capability for E85 Ethanol)
  • C - Carburated / California Emissions Controlled
  • D - Twin Downdraft carburetors
  • E - Electronic Fuel injection
  • F - Economy narrow-angle valve DOHC
  • G - Performance wide-angle valve DOHC
  • H - High compression, High-pressure charged
  • I - Single-point fuel injection
  • J - Autochoke in early models, unknown pollution control later
  • L - Transverse
  • M - Philippines' market
  • N - CNG fuel
  • P - LPG fuel
  • R - Low Compression (uses 87 and below octane fuel)
  • S - Swirl intake
  • SE - D-4 Gasoline Direct Injection
  • T - Turbocharged
  • U - Japan-spec emissions w/ catalytic converter
  • V - Common Rail Diesel Injection (D-4D)
  • X - Atkinson cycle (most-used on hybrids)
  • Z - Supercharged
ls3673
Luis
NYC
  • L - Transverse
  • N - CNG fuel
  • P - LPG fuel
  • S - Swirl intake
  • T - Turbocharged
  • Z - Supercharged
Thus is good info. Thanks for sharing.
the codes after the dash is universal, not to just the 4R
in case anyone doesnt compute, "S" is swirl aka port injection
so D-4S = "D-4" is direct injection + "S" for swirl or port injection
but technically the fuel delivery system is coded out as ... (which doesnt show in the overall engine code of "T24A-FTS")
D-4ST direct/port injection
The T24A engine is a straight-four engine series that was first introduced in 2021 for the AZ20 series Lexus NX.
Dario
Portland, OR
Land Rover LR3
That is the plan. I'd also like to do one after a long drive (100+ miles) and pull some oil to see if most of the gasoline gets evaporated out. With the direct injection and constant re-starting of the hybrid engine, constant gas contamination is a concern.
from what i remember on the toyota D-4S systems,
DI is used for high loads and highway efficiency.
PFI is used for low load and low rpm efficiency
powder
seattle
2025 TuRDOR
I have other direct injection vehicles as well as some port injected, several of which are modified and run richer than most factory vehicles will at WOT and I still can’t get over how much worse the fuel smell is in the oil of the 4Runner at just 3000 miles. I can’t imagine the fuel dilution at 5-10k intervals
Dario
Portland, OR
Land Rover LR3
100% argee. I was thinking my oil was somehow overfilled. It's almost certainly gas in the oil. And I can smell it. This is a little concerning.
I took a sample of my oil with ~1500 miles on it and many short trips. I then took another sample after two long trips of ~120 and ~200 miles with no short trips between them. I'll get both of those analyzed and see if longer trips do anything to help get the gas out of the engine. I suspect those long trips do not.
I also assume it's made worse by the frequent stopping and re-starting of the hybrid engine.
