CO/ZA
Denver
25 4R ORP
This is true. What makes me wonder is whether a high quialit aftermarket filter with a better micron filtering rating is better to use than the OE Toyota filters. The aftermarket filters may filter better but what if the bypass valves aren't really calibrated to what Toyota specifies & are allowing unfiltered oil to bypass due to the much more efficient filtering of the media.
I'm sure a Wix or something will be better on micron rating, but it seems pointless really.
People stick with Denso-Toyota filters and there aren't any problems, ever.
pmedicj
MA
Checked out his other videos and oil comparison test with Amsoil (which I have been using in all my vehicles) I was glad to see that for turbo charged engines Amsoil came out strong along with other added benefits. Would be interesting to see how Toyota factory oil stacks up to it.
SouthCoast
Houston
2025 4runner TRD ORP
I figure any oil is sufficient as long as it’s changed regularly. If you’re using the factory rating 0w20, it won’t make much difference to the turbo if you use the super expensive stuff versus the cheaper stuff. Frequency trumps price as additives will almost always be present at high ratios given a 3-5k oci. Personally, I use the Mobil 1 Hybrid 0w20 and don’t see any value in going to anything more expensive. To each their own though!
drNick
drNick
Nick
Ft. Myers, FL
Mobil 1 is a good oil. The word is that the Toyota OEM oil is made in North America by Exxon Mobil.
CO/ZA
Denver
25 4R ORP
Amsoil is an MLM scheme, there is no reason to buy it over anything sold at Walmart.
Toyota OEM oil is Mobil 1, with Toyota's own dose of additives.
Euro spec 0w-20 is better than either option in these turbo engines.
morsk
NY
2026 SR5
Interesting video, thanks for sharing. I will definitely be following this advice and changing my oil at 500, 2,000, and 5,000, which is pretty similar to what I had planned anyway.
Interesting how he doesn't change the oil filter until 5,000 - didn't know that.
SouthCoast
Houston
I wouldn't follow the oil filter advise... He was basing his opinion on air filters. Cheap insurance to simply replace the filters.
the main thing about the proper 0-20 engine oil is that...under pressure, the correct additives change their physical state and provide protection only realized under pressure
The protection is pressure and temperature-activated.
Under normal hydrodynamic lubrication (full oil film),
these additives mostly just sit in solution.
It's only when the oil film breaks down under extreme pressure that the additives:
Are squeezed into direct contact with the metal
Experience enough heat and pressure to trigger the chemical reaction
Transform from liquid-phase molecules into solid-phase protective films
So yes — it's a genuine liquid-to-solid phase transition driven by
tribochemical reactions. The additives are essentially "programmed" to
sacrifice themselves at exactly the moment protection is most needed.
Oil consumption actually depletes EP additive reserves (not just base oil)
Oil change intervals exist partly because these additives get used up
High-performance oils (racing, heavy diesel) have higher concentrations of these additives
Mixing oils can sometimes cause EP additive chemistries to compete or interfere with each other
Oh and 'does a slightly dirty oil filter work better than a brand new clean one ?'
Yes — to a point. This is a well-established principle in filtration science, and it applies to oil filters, air filters, and many industrial filters.
The "Filter Seasoning" Effect
🆕 A Brand New Filter
  • The filter media (usually pleated cellulose, synthetic fiber, or a blend) has large, relatively open pores
  • Very fine particles — smaller than the pore size — pass straight through
  • A new filter actually has lower efficiency for catching the smallest particles
  • It has low flow restriction (pressure drop across it is minimal)
🟡 A Slightly Used Filter
  • Captured particles begin to bridge across pores, effectively making the filtration mesh finer
  • This is called a filter cake or depth loading
  • The filter now catches smaller particles than it could when new
  • This is the sweet spot — improved efficiency with still-acceptable flow
đź”´ A Heavily Clogged Filter
  • Flow restriction becomes too high
  • The bypass valve opens (most filters have one at ~10–15 PSI differential)
  • When bypass is open, completely unfiltered oil goes straight to the engine
  • This is worse than a new filter — it's essentially no filtration at all
SouthCoast
Houston
nice chatgpt response
MikeK
Southern Nevada
These are turbo motors. Change the oil often and use the best, most expensive oil. Too poor to afford good and frequent oil changes? Don't buy a $50,000+ turbo truck.
You don't need to use the best, most expensive oil based on the fact it's a turbo engine. That's flawed logic, but if you have money burning a hole in your pocket then go ahead.
Avendel
Max
Boston
Toyota 4Runner SR5
I’ve been following a similar early oil change plan on my g4nb kia engine and it’s held up really well. Lake Speed’s advice makes sense for any turbo, so I’d stick with it if you plan to keep the car long term.
drNick
drNick
Nick
Ft. Myers, FL
New engine always has metal debris. Even a Toyota. I never been able to understand these 5000-10000 miles initial intervals. The carmakers want us to buy new cars more often I guess.
sstarrx2
Hogwash...i got my oil changed at 1700 miles and the guy said it looked like brand new engie oil. I just did it to be safe but he said it was clean as a whistle. No car maker is goiing to want to damge their reputation by purposely having you undermaintain your vehicle. This is the most asinine statement I have read in quite awhile.
