Hybrid system failed - "System Malfunction Visit Your Dealer"
That doesn't sound too hard?
go watch AMD on care car nut youtube channel. he recently did a video on replacing every fluid in a toyota engine
donayre21
Subaru
I would suggest not to do it while the vehicle is under warranty since it might void your warranty.
Just use it and if it breaks you are covered.
22peaks
2026 4R TRD Pro
Alrighty closing out the loop of my issue, and short version is they made a software update, cleared the codes and tested. They kept it 2 days and put about 30mi on it and never triggered the issue again so I picked it up today.
Far reach from replacing the transmission but if that’s all it was and it never happens again I’ll be happy. Felt normal driving home so fingers crossed it was just a bug.
Hey there - have you experienced any other issues since you picked up the car?
I just had the same thing happen to me with the same 3 errors. However, I did hear a loud thunk noise and the car went into limp mode. Dealer cleared codes and haven't been able to reproduce it after a short test drive so they are asking me to pick it up and keep an eye on it.
ggrant20
Colorado Springs, CO
Thankfully have not had anything happen since, working perfectly and I just crossed 5k miles!
sorry you had that happen, I know it’s a terrible feeling but hoping yours turns out the same
a_double
NV
5th & 6th Gen 4Runner
Is transmission oil temperature an indicator of this problem?
22peaks
2026 4R TRD Pro
Codes pulled for mine were transmission related to "pressure control solenoid actuator stuck". Don't know if its a fluke or if its bound to happen again. Only 500 miles on the car.
a_double
NV
I have a 26 Platinum with a 12/25 build date and currently at 1000 miles. Fingers crossed Toyota resolved the issue by then.
I've experienced, for lack of better explanation, not smooth shifting at low speeds, when coming to a stop. Also, some not so smooth shifting accelerating from a stop, but not jarring.
This is my first hybrid so I assumed it was just hybrid vehicle behavior but this thread has me worried.
TrdProGirl84
I'm at 6k miles on TRD Pro and no issues so far. Knock on wood.
You shouldn’t have any issues. I wouldn’t worry. I’m in a Pro as well. And my Hybrid speaker under my back bumper went out. Toyota replaced it under warranty.
a_double
NV
Fell victim to this at 1364 miles :cry:
a_double
NV
It just happened, 2 blocks from getting home. I'll reach out to the dealer tomorrow.
It pretty much happened as described here. Clunk then rev spike, tapped the gas and another rev spike, noticed the hybrid power meter go up more than I'm used to on that subsequent pedal push. I let off the pedal, coasted for a bit, then gave it a little gas. It felt normal, but the dash was lit up. I was able to make it home 🙏
Cranberry
Dan
Manitoba Canada
How many KM do you have right now and how ling have you had it?
Cranberry
Dan
Manitoba Canada
22peaks
2026 4R TRD Pro
Glad you made it home safe. It may be stuck in limp mode (which is what happened to my Pro) and won’t shift out of 1st gear. I was only able to go 15-20mph max when taking it to the dealer.
They didn’t do anything but clear my codes and test drove it a couple miles then released it back to me. They essentially said go drive it til it breaks again before they could do anything more. Problem is, I lost power mid turn and I’m worried next time it’ll be on the highway or unsafe traffic situation.
Toyota dealer and corporate didn’t care even though there is a known issue with these hybrids (there was a service bulletin for our same transmissions on the Tacoma with the same issues that required full transmission replacement.). Make sure dealer pulls your codes and provides freeze frame data for your own records.
Good luck tomorrow, keep us posted.
