Hard transmission shift on initial startup under 1k Miles
Speefk
Rob
Illinois
2025 4Runner TRD Off-Road Premium, 2021 RAV4 AWD hybrid
Same issue. First shift of the day from 1st to 2nd. Fine once warms up. 700 miles. Did it from day one.
jrenzag
Raleigh NC
2012 Jeep Grand Cherokee Overland
Well dealer says it's normal.. We believe 'em right? :/
hard shift only when cold. warm it up via keyfob and give it 5 mins... never happens.
... I think it is getting better, been driving it immediately after start and it seems* to
be behaving. 3045 miles SR5 4wd
*I always expect it to thump when cold so I am driving the first 1/2 mile super light
Ok so now based on this thread, I stopped babying it.
and it's gone.
It has learned and it doesn't thump anymore. the first shift is smooth now and behaves
6thGen1419
Peter
New Mexico
I noticed a hard shift when first accelerating in the first drive in the morning when mine was new (86 to 700 miles). Isn’t noticeable anymore. Is it me or did the trans learn?​
and it's gone.
same for me
jrenzag
Raleigh NC
same for me
I am at 4700, mi and it still does it to me every single cold start. And I don't baby it. It is what it is and I'm not going to worry about it anymore.
mars001
2003 4Runner SR5 4.7 V8
I really doubt that the transmission 'learns' anything. What does it try to learn? Shifting is based on rpm/speed. What if the truck is shared by 2 people everyday like husband and wife? Is it going to learn and relearn from each driver overwriting one another? I really doubt it but of course I may be wrong. It may have built-in AI, who knows? 🙂
6thGen1419
Peter
New Mexico
I never thought it was something to worry about. My theory still is that it's not the transmission but something to do with the hybrid engaging? Does it happen to non-hybrid folk?
Hobb3s
yes… i have the non hybrid limited
it does learn and Toyota (and other mfr) transmissions have been learning for decades
There are default setting on everything.
The engine fueling, ignition mappings, transmission shift points/pressure etc
are at a basic pre programmed level.
When we say the "ECU learns", it means that these basic maps are fine tuned automatically by the computer, since it will be running in open loop mode (getting data from sensors).
For example, after an ECU reset, the duty cycle of the injectors may be ... 60%. After a little bit of driving, in a certain style, this value may increase to 62% (slighty richer), or if you drive sedate, 59%.
There only minor adjustments being made by ECU.
Same goes with the transmission. Electronic soldenoid triggering times, pressure sensors, pattern selection can be fine adjusted by the ECU itself to correct for different conditions. If it didn't do this, the car may be harsh in certain circumstances. Harsh as in, with default factory settings.
hiho silver
New Jersey
I also have a non-hybrid (SR5) at just under 2000 miles and have noticed the 1st to 2nd gear thump when starting up from the cold. I wonder if it's because the transmission fluid needs to warm up more, but not sure if that makes sense since there are no problems with the other shifts. I should add that this has been the coldest stretch of temps that we have had in NJ in a long time...the high has not even made it above 32 F during the day for like 3 weeks now, and the lows overnight are in the single digits a lot of the time. I'm hoping this will get better with warmer weather, but it seems like many people are experiencing this in other parts of the country too.
ATX
2026 4Runner SR5
Howdy all - new member with a new 2026 4R SR5 with now about 1200 miles in central Tx. I'm having similar issues as some other members are describing on this thread about hard shifting. I'm teeter tottering on waiting it out seeing if it will eventually learn its way thru or if I should schedule appt with my Toyota dealership?
All in all, somewhat happy with the purchase but it's hard to not be disappointed and harder to admit as an avid Toyota fan with an 04 Tacoma and 94 Land Cruiser both well over 250k miles and growing. Aside from hard shifts I'm also experiencing vibrations not sure whether driveline or suspension related but it's hard to believe already fresh out the door I'm experiencing these issues.
MikeUtah
Utah
Toyota 4Runner Trailhunter
There are numerous threads discussing this issue. You might read the posts at: https://www.4runner6g.com/forum/threads/6th-4runner-trd-pro-1st-2nd-gear-shift-issue.6503/
RAD4RNR
Ray
SO CAL
2025 4Runner ORP Hybrid
I have a TRP ORP IFORCE and I have 5,000 miles already and it still has a hard shit first thing in the morning going from 1st gear to 2nd gear only. After that never happens again the rest of the day. I will ask the dealer whenever I take it to the dealer in the future.
The_Dark_Knight_Forever
J.
Houston, TX
'25 TRD Sport Premium here. Currently 2,403 miles & mine has the rough shifts in the lower gears until thoroughly warmed up. Coming to a slow stop sometimes results in a little thump as it downshifts. It' s worrisome as mine is intended to be driven for the next 15-20 years. I wonder what damage is being done in there. I also hate the idea of some incompetent technician tearing into my brand new transmission to do exploratory surgery. They sure don't make them like my '03 Tundra anymore. 😔
FoRunna
Atlanta, GA
Nice to see this thread is back. I had/have this same issue. Asked the dealer to address it, and they told me they couldn't replicate it. Hasn't really been a problem past being a very minor annoyance, but something tells me this is fairly normal.
