Battery went dead - now check engine light on
bobholthaus
Bob
St. Louis MO
Jeep JL-370 AEV Diesel
I accidentally left my Starlink on last night and it took my battery all the way down to the point that I had to jumpstart the vehicle. Now I've got a check engine, system malfunction, and drive start control malfunction that are not going away after I've got the battery charged. Is this going to take a visit to the dealer, or is there someway for me to reset all of this? Thanks in advance. I travel in this car on Friday.
jcash25
jason
Houston
2025 TRDO Premium
I ended up killing the battery while at the beach a while back. Interesting way to jump a hybrid to say the least. So i was approx 100 miles from home, drove it back with 3-4 warning lights on. I searched and searched when i got home and they will go away on their own.
If not take it to dealership but they should reset or go away.
I think i drove it more that night and then parked it for the night got in the next afternoon and no warning lights on.
bobholthaus
bobholthaus
Bob
St. Louis MO
I am headed to Sam's Club right now to buy this Duracell AGM battery. I know why it died last night but I don't think that OEM battery is very powerful. I just went by the dealer and he said they would charge me $175 to clear the codes since the battery went dead on my watch. So much for being honest with these people. He did say that if I pull the OEM battery right now and replace it, by having the cables unhooked, it should clear the codes.
2025 2026 4runner 6th gen Battery went dead - now check engine light on IMG_3459
jcash25
jason
Houston
2025 TRDO Premium
tbh they clear themselves. Like they are designed to do
bobholthaus
bobholthaus
Bob
St. Louis MO
New battery installed. Had the leads off for at least 30 minutes. Codes did not reset. Had to use my Bluetooth OBD2 tool and Carista to clear the codes.
I'm glad this lead to me replacing the battery! I'll be happier with an AGM.
SteveS
Steve
Puyallup, WA
Did you ever get the OEM battery tested before replacing?
also, using a cheap Duracell AGM, will the charging management in the 4R charge it appropriately?
If vehicle is still under warranty, how will Toyota react to an non-OEM battery?
seems you made a lot of assumptions unless I am missing something.
bobholthaus
bobholthaus
Bob
St. Louis MO
I have one of these Duracell's in my diesel Wrangler; have also used them in my old camper (pre-lithium). And while they are no odyssey, they are way better than the OEM lead acid battery.
My battery wasn't dead; I just wanted an AGM, so I don't need to have the OEM tested. The 4Runner will have no issue charging it and managing it. Changing battery composition (other than to Lithium) should have no effect on the charging system.
Yes, still fully under warranty. I don't foresee any warranty issues by upgrading the lead acid battery to AGM. Why would you think there may be an issue?
the only issue might be the start/stop system. if you have a non hybrid, they have a specific battery for those start/stop system that is different than the regular batteries.
shine
Seattle
Conventional wisdom has been that AGM batteries need a higher charging voltage to fully charge. Is that not the case for the Duracell?
Allan
Napa
4runner, Tacoma
My battery was drained when it was being wrapped and I had warning lights when I picked it up. Freaked out and went to the dealer who said it would clear after it had been driven a few times....it did clear in a couple of days.
bobholthaus
bobholthaus
Bob
St. Louis MO
From Chat: Some AGM designs have charging requirements that differ from flooded batteries, but the Duracell/East Penn AGM does not require an unusually high vehicle charging voltage. East Penn specifically approves it for conventional automotive charging systems operating around 13.8–14.4 V.
From me: I think I can use my OBD2 reader and my Carista app to see what charging voltage the vehicle is delivering
MTN Dew
Dave
DE
You could probably clear codes after 2 key cycles. Some vehicles opening and closing door between cycles helps.
shine
Seattle
That voltage requirement should work with a regular alternator based system. Not sure what our dc-to-dc charging hybrids charge at.
I'll see if I can convince someone to sit in the back with a multimeter on the battery while I drive around :)
bobholthaus
bobholthaus
Bob
St. Louis MO
Real time data from the Carista app.
2025 2026 4runner 6th gen Battery went dead - now check engine light on IMG_3503
2025 2026 4runner 6th gen Battery went dead - now check engine light on IMG_3504
