AZTrail
Take note, the Toyota CCN explains in the video above that he does not recommend using a thicker oil weight than the 0W-20. This is due to differences in programming the variable oil pump for US car use with the 0W-20 oil vs different programming for use with thicker oil in other countries.
Going to do my 500 mi oil change this weekend per this vid’s recommendation: pouring a fresh quart through and leaving the existing oil filter on!
I’m going to install the Valvomax in the process
sstarrx2
I had my oil replaced, oil only at 1300 miles. First time ever in all my years, doing it sooner than manufacturers recommendation. Technician said the oil was as clean as it could be, almost like was poured it from the bottle. Feel a tad foolish now...but peace of mind is worth it I guess.
SouthCoast
Houston
2025 4runner TRD ORP
Does it void any warranties?
I am guessing we do the oil changes ourselves or will the dealership switch to synthetic 5W-30 if requested?
Depends. If you have an issue where Toyota has to inspect the motor, and can validate a viscosity change outside the technical specs allowed, they can/may deny/void warranty service. So, it depends on your risk tolerance.
Only if they prove the change in viscosity caused the issue.
ROBERT18452
Robert
Scranton, Pennsyltuckey
RAV4 w/ 4Runner on the way
When I buy a new car on the first oil change, I always replace the oil drain bolt with a Fumoto valve. This makes all subsequent oil changes so much easier and cleaner, so I don’t have to spend any effort to do it. The only major thing is replacing the filter. On the 4Runner the skid plate which comes with the TRD ORP is completely useless. I replaced it with Rival4x4 aluminum plate, which has service ports for both the oil and the filter. All this makes the oil changes a breeze.
please share a link for the correct Fumoto valve.
ROBERT18452
Robert
Another Motor Oil Geek video that specifically addresses the firts oil change in a toyota:
AVOID the ONE MISTAKE Almost EVERYONE Makes With A Brand New Car
4runnerguy
2026 Toyota 4Runner TRD Off-Road Premium
My '26 ORP is currently at ~1000 miles, and I am trying to figure out whether or not to change the filter with my oil change.
Based off The Motor Oil Geek's videos:
In his 4th gen Tacoma oil change video (timestamped):
At ~487 miles, he does an early oil change but explicitly says “we are not going to change the filter.” He explains this by saying that newer/partially loaded filters (up to ~5k miles) actually trap finer particles better once they’ve developed some filter media loading.
Later in that same video, he does another oil change around ~1,598 miles (UNSURE if he replaces the filter, but I imagine he didn't and will change it at 5k miles).
In this second video, he changes the oil in his daughter's 2023 Corolla (timestamped):
At ~722 miles, he does replace the oil filter during the oil change.
Is his general recommendation to leave the original filter on through the first early oil change and replace it closer to ~5k miles? Or is he just showing different acceptable approaches rather than a strict rule (maybe he changed the filter since it's a different engine?!)
My assumption was oil early, filter at ~5k, but I’m curious how others here are interpreting this and what you’re planning to do on your 6th gen.
cheers
sstarrx2
cheers
He is some guy on the internet that makes videos for money...I would not assume he make the rules. I did not change my filter on the first oil change at 1300. It will get changed on my second oil change at 10000 miles like the manual recommends.
Joestac
cheers
My first two at about 500 and 1500, I didn't change the filter. I'm at 2700 now and at 5000 I'm going to change the oil and filter. Then probably take it to the dealer at the 10000 mark. Maybe.
The_Dark_Knight_Forever
J.
Houston, TX
cheers
I'm familiar with those videos as I also follow the motor oil geek. However not changing the oil filter early on is something that I disagree with. The video clip & justification for not changing it is from what an expert from an air filter manufacturer says based on their studies. I personally don't think it applies so well to oil filters. The thing is that when an oil filter become overloaded or too restricted the bypass valve with it activates to prevent oil starvation of the engine by allowing unfiltered oil through. You don't know when that's happening. It's potentially damaging to your internal components. I personally believe it's best to change the filter during every oil change most especially in the early life of the engine when the used oil will contain particulates from new engine break-in.
CO/ZA
Denver
25 4R ORP
You'll also find that on oil sites like BITOG, the Toyota filters are considered to be "rock catchers" due to the relatively low micron rating that they employ in the filter media.
Toyota seems mostly concerned with maintaining oil pressure/flow and less so with filtration of said oil.
J.
Houston, TX
This is true. What makes me wonder is whether a high quality aftermarket filter with a better micron filtering rating is better to use than the OE Toyota filters. The aftermarket filters may filter better but what if the bypass valves aren't really calibrated to what Toyota specifies & are allowing unfiltered oil to bypass due to the much more efficient filtering of the media.
