Djshush
Edgar
Camarillo Ca
2025 4Runner TRD ORP
Just installed a group 27 agm battery yesterday it fit with the stock clap downs I just had to add a 3/4 on the strap and 2 - 1/2 inch rubber bushings as spacers on the battery tray. The bolts are long enough to work but I will get longer ones soon just in case.
2025 2026 4runner 6th gen Group 27 AGM Battery Upgrade Installed IMG_5358
2025 2026 4runner 6th gen Group 27 AGM Battery Upgrade Installed IMG_5357
2025 2026 4runner 6th gen Group 27 AGM Battery Upgrade Installed IMG_5356
Josalbrec6G
joe
cincy
2025 4Runner 6G
I had an Odyssey AGM battery in my previous car and it lasted approx 3 years. My wife’s Honda has a flooded and it lasted 7. I’m stickin with stock.
Djshush
Djshush
Edgar
Camarillo Ca
@Djshush, did you have to do any kind of calibration switching from flooded to AGM?
Thought I saw a video on you tube that required doing a calibration of some sort.
This video is what I was referring to.
Flooded to AGM
I’m adding a 300 amp alternator soon and the overland Torque tune has an option to adjust the voltage to 14.8. I have always had high end car audio and accessories that need more power. If you off road a lot I seen rigs with multiple and bigger agm batteries.
Djshush
Djshush
Edgar
Camarillo Ca
That’s unfortunate I’ve had these last just at long as regular batteries. But I also run 300 amp alternators and get it tuned to charge at 14.8. I have always ran high end car audio and have had accessories that need more power. For regular use it is overkill. I have seen overland rigs with 2-3 bigger AGMs than these.
Djshush
Djshush
Edgar
Camarillo Ca
What was your purpose for upgrading, did you have any issues with the stock battery?
No issues at all. I kind of felt silly giving the battery as a core charge being so new. But I run a lot of car audio and need the extra power. I’m adding a 300 amp alternator soon and tuning it to charge to 14.8 volts. A lot of overland rigs with winches and accessories that demand high power use AGM batteries they sometimes run multiples. I will have a lithium secondary battery in the back.
CO/ZA
Denver
25 4R ORP
The AGM battery in my 2017 3 series was original to the car when I sold it in April of this year.
Survived Texas summers, Colorado winters.
AGM is better than flooded, all else being equal.
How much did it run you if you don’t mind me asking?
danimaldaisy
San Bernardino
6th gen trd sport
In both my last 2 5th gen 4Runners I swapped out the alt-s fuse for a GM diode fuse that cost 10 bucks. This bumped up the voltage. It Would be cool if it worked in the 6th gen. I have a spare fuse but someone else can experiment because I’m not lol.
jimbo285
Jim
Fairbanks
I noticed the stock battery on my 25 SR5 is smaller than the tray it sits on, and wondered if a larger battery with more CCA could fit. I don’t know what size would fit so can’t compare the CCAs to my stock one. -50f and colder here in the winter does warrant as many COLD Cranking Amps as possible
Typhoon1512
Darren
south texas
26 ORP
cant wait for high amp alternators to come out for the 26 models.
Brian Day
Brian
Empire MI
I have one and will check Tuesday to see if it fits and works .
