JakeJoeBob
Jake
Tacoma
Anybody know the specs on the Toyota OEM transfer case skid plate PT228-35248? Specifically, material (aluminum vs steel), and weight? No useful info with the Toyota Parts Online listing, and I have not found any elsewhere either.
All Trailhunter skid plates are steel. The TRD skidplate is aluminum.
MrEdofSC
Ed.
Santa Cruz, Ca
2025 4 Runner TRD OffRoad Premium
Do you know the weight of these plates? & since the Trailhunter skid plate does not have any openings for oil, filter change or trans oil change is it easy to remove and replace these for fluid changes? I ask cause I'm looking for decent skid plates for my 2025 4runner t rd.
JR1
Joe
Missouri
I don’t know if this helps you but I have the TRD skid plate on my Sport premium. I was able to remove it easily by myself with the truck on ramps. Two of the bolt holes are slotted so you can loosen two bolts, remove the other two. Then you can just slide the skid plate over. Make sense?
2025 2026 4runner 6th gen All Trailhunter Skid Plates install on TRD Off-Road: Front Bash Plate, Diff Skid, Transmission Skid Plate IMG_1792
AdFour
Washington
Anyone know the part number for the transfer case skid plate? For the Non-Hybrid models.
Is there a steel and aluminum version?
I keep seeing PT228-35244 and PT228-35248.
They seem to be the same one but it only mentions Taco
kburrito
2025 TRD Off Road Hybrid
Toyota part website says the PT228-35248 fits a non hybrid TRD OR. Double check with your trim level. I assume its steel to be similar to the trailhunter front skid plate but could be wrong
AZTrail
Can. You change the rear diff oil without removing the skid plate?
HVLA
Lexus
Thank you for this! I installed all 3 trailhunter plates on my TRD OR this weekend following this
Can you list the part numbers you used, price you paid, and where you got them?
kburrito
Front Skid Plate - SteelPT228-35240
Transfer Case Skid platePT228-35247
Rear Diff Skid PlatePT228-89253
Note that this was for the hybrid version
I did mine local pickup at a dealership during memorial day weekend. A ton of discounts so i spent about $600-700 total
HVLA
Lexus
Thank you!!
Dealership actually sold me the non hybrid TCSP, then a hybrid version showed up at my door step before I even had a chance to try the one they sold me. (y) KELLY TOYOTA.
Heading out to the shop to see if it's gonna match up with my "Pro" TRD front skid.
kburrito
You can pair the TRD plates with the trailhunter transmission plate. Send pics on how it looks
Confirmed,
TH Tranny/Transfer skid plate matches up to the TRD Aluminum Front Skid. I'll take pics over the weeknd.
2025 2026 4runner 6th gen All Trailhunter Skid Plates install on TRD Off-Road: Front Bash Plate, Diff Skid, Transmission Skid Plate 4683795049836758462 (2)
Razor
Ron
Philadelphia
Trd Off Road non-premium
Trailhunter skid plate installed on my TRD Off-Road
Cory39744
Cory
Virginia, USA
I just got my rear diff skid in (PT228-89254) which I verified was for the hybrid but it didnt come with the rubber spacers that go on the left and right ends of the plate like the one posted in this thread. Anyone else install the rear diff skid on a hybrid yet?
