shine
Seattle
Installed DV8 trailing arms skids. Never had any after market skids on my 4th gen and this never seemed to cause damage, but protecting the trailing arms seems like it's worthwhile. Looked at multiple brands, these seem to have the right amount of coverage while hopefully not accumulating too much dirt.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  IMG_7985
3rdRunner
Bill
Sure, here is the rear seat delete platforms. This includes the rear section and the rear-seat delete section.
And here is the full rear hitch swing out from Westcott.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  {filename}
Nice! What’s the impact on your rear camera? Still trying to do decide best solution for spare. Really don’t want to lose the rear view capabilities.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
3rdRunner
Bill
Yeah - there are a couple out there. Just curious if the Westcott preserved the view, or at least partially preserved it.
LostInAZ
Carlos
2026 Toyota 4Runner ORP
I use a Wolfbox G900TriPro and you can see the rear view camera mounted on the rear spare tire at the bottom of the license plate. I am going to mount the front bumper one under the truck facing forward (probably behind the driver's wheel somewhere near the transfer case or trans case) to see obstacles better. The 360 camera system works pretty well so no need to add another one on the front end or bumper.
Mike N
Rochester, NY
Mike N
Rochester, NY
Small mod worth doing available on Amazon. Door Stop Protective Cover for 2024 2025 2026 Toyota 4Runner & Tacoma Waterproof Anti-Rust Decorative Cover Car Door Bracket Cover Interior Modification Accessories. Clean door stop, lubricate with white lithium grease, wipe excess, and snap cover on. Repeat lubricating every so often.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  20260721_070647
Right now the knob just spins. No clicks. You think that part would fix that?
Take the screw out and see if the splines on the inside of the knob are stripped, if so, then yes, a new knob will fix it. Even comes with the sticker to replace.
3rdRunner
Bill
Ok - so you’re still using the 360 on your main monitor…correct? The Wolfbox looks like it’s providing a lot of good info though. When you select reverse, does it still display the view on the main monitor… just obscured by the tire?
LostInAZ
Carlos
Yeah the stock rear view camera (on main display) is completely blocked by the spare tire and the floor jack mount but the WolfBox shows their camera on the rearview mirror and if you attach the brake light wire it will give you a full uncropped view with adjustable guide lines, although they are not 100% exact as the stock ones but they work really well and has a very wide FOV.
I'll take a few picture of the difference when I go out today (I have my 10,000 mile service scheduled).
3rdRunner
Bill
Nice - appreciate it!
LostInAZ
Carlos
Here is the rear view camera blocked by the rear hitch swing out. Pretty much worthless.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  IMG_1374
The Wolfbox G900 Tri Pro rear view camera on the rear spare tire in backup mode. Added some cones to show the FOV area, sorry I could not get them right on the edge but next photo should help with the scale.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  IMG_1377
And here you can see where those cones were so you can see that there is a substantial distance from the rear hitch mount to the point where the lower edge of the camera is. I actually don't mind it since there is no way for me to run into anything since I use the red line to stop and that still leaves me like 2-3 feet of clearance.
2025 2026 4runner 6th gen What did you do to your 6th Gen 4Runner today?? πŸ‘¨πŸ»β€πŸ”§ 🧰 πŸ›  IMG_1380
mcd_ovrlnd
SE PA
You getting any of that auto braking because you oem rear view sensor sees that tire swing?
LostInAZ
Carlos
Oh yeah!!! I had to turn it off in the center console settings. First time it happened it scared the living daylights out of me.
3rdRunner
Bill
Ok - there is plenty of info w/ the Wolfbox and like you said there is a lot of room between the redline and the rear of the truck. Good clarity as well. It would be pretty easy to adjust to the new view. Really appreciate the info! Any sag on the rear with the added weight?
