dbrock34
Dean
Indiana
2025 4RUNNER Limited
I received and installed the Bilstein 5100 suspension on our 2025 4Runner Limited this weekend. The Limited had a rough ride from the start. You could feel every bump in the road. I had installed the Westcott preload lift front and rear and that didn't make it worse but it sure didn't get any better. So, I left the .75 inch spacer in the rear and installed the 5100s there. I removed the front collars and spacer and installed the 5100s set at 2.2 inches. Install was overall pretty easy. Hardest part was disconnecting the darn AVS connectors. I was concerned I would get warning lights on the dash but we've driven it about 75 miles and still no issues.
The ride is sooo much better. An added bonus was that we had always had a rattle in the rear every time we hit a bump. Now, it's so much smoother it got rid of the rattle. I forgot to add that we had already ditched the stock 20s and switched to the 17"methods with 265-70-17 BFG KO3s. That didn't help the harsh ride either. With this setup it is almost dead level. From floor to front fender is about 37.25 front and 37.5 in the rear. Was 37.5 all around with Westcott. I like the very slight rake better.
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 1000010325
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 1000010322
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 1000010323
4running
TX
2020 4Runner SR5
Thanks for the measurements and review. I've been reading that the 5100 improves ride quality so it's tempting...
Any photos before and after install?
dbrock34
Dean
Indiana
They are worth it. $600 well spent.
I meant to take pictures but got sidetracked. I'll try to remember to get photos tonight when the wife gets home from work.
aj negi
Ajay
Calgary
Thanks for sharing your experience
I am going to install 5100 tomorrow on trd sport
Will update you guys soon About my experience
romik
Romik
2025 Toyota 4runer
I received and installed the 5100s on our 2025 4Runner Limited this weekend. The Limited had a rough ride from the start. You could feel every bump in the road. I had installed the Westcott preload lift front and rear and that didn't make it worse but it sure didn't get any better. So, I left the .75 inch spacer in the rear and installed the 5100s there. I removed the front collars and spacer and installed the 5100s set at 2.2 inches. Install was overall pretty easy. Hardest part was disconnecting the darn AVS connectors. I was concerned I would get warning lights on the dash but we've driven it about 75 miles and still no issues.
Could you share your alignment specs, especially since you haven’t changed your UCA?
Ltd.Herit.'26
Austin
Dallas
2026 4Runner Limited 4wd
Really appreciate the details here. Curious what went wrong w/ limited ride. It's the harshest riding vehicle I've ever purchased. Which I bought this trim expecting the exact opposite. I've heard they "wear in" some, but really curious how it landed so far from expectations. To confirm you no longer have avs functionality? Better rides a better ride, may do the same and skip the readylift level.
js_panda_rnr
What brand/type of strut does the limited come with from factory? I've seen discussion around the 5100 possibly being a lateral move (maybe even a downgrade?) in terms of ride compared to the factory Off Road Bilsteins, which imo are also stiff for an "off road" tailored trim. It's hard for me to imagine the Limited is even more stiff. I've been looking at the 6112 but my wallet would love it if I could improve the ride quality and level the front with 5100s.
dbrock34
Dean
Indiana
If I end up getting an alignment I'll share the specs. I'm debating on whether I need to since it's only .25 inches different than with the westcott lift.
dbrock34
Dean
Indiana
Correct, I no longer have AVS functions but I have 1 setting right now that hopefully rides great everywhere versus 4 that weren't good anywhere.
dbrock34
Dean
Indiana
I didn't take the time to look over the stock shocks. I was just super happy to get them off. When I get a chance I'll take a look at them and see if I see a label.
romik
Romik
2025 Toyota 4runer
You definitely need an alignment. Remember, Bilstein shocks are longer, and the way they change the suspension geometry is more significant than the Westcott design. It’s not just about that small height difference.
HVLA
Lexus
You should always get an alignment any time you take the suspension apart.
aj negi
Ajay
Calgary
I installed bilstein 5100 on my trd sport yesterday with stock coils
Lifted up to the 5th ring that is 2.2"
It rides better then the stock suspension now
No lift at the rear
Now my front sits .25 higher then the rear my next plan is to install 5100 rear suspension to level up the truck
It looks pretty much leveled right now but when you sit inside you can feel the rear sag
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260508_112337
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260504_120948
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260508_112347
2025 2026 4runner 6th gen Bilstein 5100 suspension lift kit installed on a Limited with AVS - review (ride quality improved) 20260504_121009
