Widow Door rattle / vibration source when playing music and how to actually fix door rattle permanently
enginir
NY
4runner Sport Premium
Hi all, I replied to a previous thread (https://www.4runner6g.com/forum/thr...d-with-foam-insulation.5618/page-3#post-91950) saying that i found the source of the door rattle and how to actually fix it. I did it in my driver side door and as promised, I documented how to do it when I was fixing my passenger side door.
Here is a video of inside the door showing what part is actually causing the door rattle that seems like it is coming from the B pilar but is actually in the top right of the door (when looking from inside the car).
The rattle is coming from the window run bracket where it meets the top part of the car door as seen in the video, I was able to wiggle it with very light pressure to get a metal on metal noise. This is the exact spot where it rattles. (don't hate on me not knowing the actual name lol)
An easy way to check if this is the source of your door rattle is to turn up your music and base then listen for the rattle. If you roll down your window all the way and the rattle goes away or is less intense then this is the source of the rattle.
Here is a step by step guide on how to do it: (had to add images as share links on this thread due to size of images and videos)
1. You need to take apart the door trim (it is easy, I pretty much just used my hands and a screw driver to get the screws out. In some places I used a bicycle tub prying tool to get some of the clips on the white piece inside the door.) I used a guide on how to take the door trim off.
To avoid reinventing the wheel here is the youtube video ()
2. There are three bolts holding the door panel trim down you will have to take off. Here are photos with bolts circled: (upload stopped working so here are share links to the photos:
3. Door without panels looks like this ( 20251124_014244410_iOS ).
4. Then you will need to remove the two bolts holding the window run and remove the window run from the door to insulate it. I used amazon basics automotive butyl noise insulation. Here is a video of how to remove the window run ( Removing window run.mp4 )
5. Clean any surface you will be adding noise insulation too prior to application. I used a clean rag and 70% isopropyl alcohol.
6. Now we add noise insulation to the window run (you only have to add it to the top part shown here ( 20251124_014757859_iOS ). But with my OCD I covered the whole thing. here is what it looks like after being covered: ( window run insulated.mp4 )
  • It is important to get the whole bracket at the top insulated ( i went back to add some insulation as there was one spot in the video that I missed). Here is an image of the final insulation at the top ( 20251124_024401683_iOS ) it does not have to be pretty but pressing it down firmly is important to reduce the thickness of the insulation and to insure long term adhesion.
7. I also installed noise insulation (two layers) between the bracket mount and door panel interface (between the bolts). I did this before but it did not get the rattle to go away full but I did not remove it so it probably helps.
8. Install the bracket back on: Install window run braket back on..mp4
9. Put bolts back on the window run bracket and door back together.
10. you are done if all you want is get the door rattle to go away.
I also decided to added the sound insulation to the rest of the door but this took a long time and was very tedious but does improve sound quality. Since i already was working on the door I decided to do it. Here is what my door looks line insulated: 20251124_050733165_iOS.jpg
Hope this helps!
Tarekith
Upper Left US
4Runner ORP & ‘22 Tacoma OR
Thanks, mine just started this rattling today so this is very helpful and timely.
DrDripz
2025 Toyota 4 Runner Off-Road Premium
I don't even have 1000 miles yet and mines already rattling. It's driving me insane.😤 Glad I found a write up on this so I'm not trying to pull the door card off blind.
Tarekith
Upper Left US
Just wanted to say thanks again for posting this. Finally got some nice weather so I took a couple hours to pull my panels, fix the rattle, and add some more dampening sheet pieces to the doors while the inners were off. Rattle fixed, and the doors sound better now I added the sound dampening.
If anyone else does this, I’d also recommend checking all the screws holding the two halves of the inner door panel together once you pull it off. Some of mine were almost a full turn loose. Likewise the screws for the door speakers, mine were also almost a full turn loose. Might as well tighten everything up while it’s apart.
Lastly, remember that these sound dampening sheets are primarily to reduce the metal door panels resonating. You’ll get some minimal sound proofing in the cabin as a result, but you don;t need to completely cover the interior door panel for that. It can be a lot easier to just cut smaller strips and patches to cover the larger exposed sections of the doors, and not worry about meticulously cutting out each screw hole, cable mounting, and bolt location. You do you of course, just might not be all that much different for the extra work that requires. There’s thicker sheets than this Amazon stuff if you really want to reduce sound transmission through the door panels in a more meaningful way.
Just my $0.02.
horbit
DFW
I sound deadened my doors completely (inner, outer, and foam layer) and can hear this window run rattle with deep bass notes. Going to buy some closed cell foam tape and give it a shot. I don't think it needs to be fully covered due to all the bends in the metal. I will focus on the top and bottom and report back.
Tarekith
Upper Left US
You need to remove the window guide and cover the top of that with something, just adding sound deadening to the door panel won’t fix the rattle.
sstarrx2
Have over 3000 miles on mine so far, just a few days shy of 3 month owned. I cannot find a rattle anywhere on this truck!
FlaFlaFloFly
Chicago, IL
2025 Off-Road Premium
Has anyone else performed this fix and it has NOT gone away? I did this yesterday but used foam tape instead of the sheets as demonstrated. I’m afraid it appears worse than before… I ordered the Amazon basics insulation and plan to take it apart and re-do once the weather warms up a bit more. Just curious what I may have missed. I SO appreciated this write up though. Made it much easier to take on the project.
DrDripz
I actually did the fix and also experienced it not going away. it appears the rattle people are experiencing are all from different locations.
After I did mine and was still experiencing the rattle I decided to dig in further and really investigate where it was coming from.
In my case the rattle is coming from where the very top of the door card meets the door up near the window itself. Turn up your music and gently press the very top of the door card up against the door.
FlaFlaFloFly
Chicago, IL
I’ll take a look. I assume you haven’t found a fix? My car needs to go in soon for the oil change so I’m tempted to bring it up again, but think I prob should take out any evidence I was ever in the panel.
horbit
DFW
I still have not deadened the window run, I do hear something rattling in both front doors on specific bass notes. I doubt my door card is rattling given the amount of material I put on it, will try pushing on it next time.
2025 2026 4runner 6th gen Widow Door rattle / vibration source when playing music and how to actually fix door rattle permanently IMG_2196
2025 2026 4runner 6th gen Widow Door rattle / vibration source when playing music and how to actually fix door rattle permanently IMG_2200
2025 2026 4runner 6th gen Widow Door rattle / vibration source when playing music and how to actually fix door rattle permanently IMG_2199
2025 2026 4runner 6th gen Widow Door rattle / vibration source when playing music and how to actually fix door rattle permanently IMG_2198
DrDripz
@horbit I'm stealing your picture to show where I'm 99% sure the sound is coming from. I believe the door card sits into this groove and the rattle is coming from the bass causing the door card to bump up against this groove. I'm going to try placing some foam into this groove and see if it stops it for good.
If anyone tries this sooner I'd love to see the results as I'm not sure when I'll have the opportunity to try it myself.
2025 2026 4runner 6th gen Widow Door rattle / vibration source when playing music and how to actually fix door rattle permanently 5212
