Why did Toyota mount the oil filter housing in this location?
IRFAN0922
irfan
2026 Toyota 4Runner SR5
I attached a picture of the 2026 4Runner's oil filter housing. From what I can see, it's a completely separate housing mounted away from the engine block. It connects through two hoses—one for the oil supply and the other for the return.
This made me wonder: why did Toyota choose this location?
To me, this seems like a missed engineering opportunity. Many manufacturers, including BMW, Jeep, GM, and even Subaru, mount the oil filter on top of the engine. That design makes oil changes much cleaner, faster, and easier since there's less mess and better access.
The 2026 4Runner has a large engine bay, so it seems like Toyota had plenty of room to place the oil filter on top as well. Instead, they mounted it lower and separately, which appears to make servicing more complicated.
Is there an engineering reason for this design, such as cooling, oil pressure, packaging, or crash safety? Or do you think Toyota simply missed an opportunity to make routine maintenance easier?
I'd be interested to hear what others think, especially anyone with an engineering or Toyota service background.
2025 2026 4runner 6th gen Why did Toyota mount the oil filter housing in this location? Oil
6thGen1419
Peter
New Mexico
Here is what AI said about that:
The biggest reason is probably packaging. The 2.4-liter turbo engine has a turbocharger, exhaust plumbing, intake plumbing, emissions equipment, and (on the i-FORCE MAX) hybrid components competing for space on top of the engine. Even though the engine bay is physically large, the top of the engine is actually quite crowded.
Second, the filter is integrated with a water-to-oil heat exchanger (the stacked aluminum cooler beneath the filter). Mounting the filter directly on the cooler creates a compact module with very short internal oil passages. That’s simpler to manufacture and makes it easier to share the same assembly across multiple TNGA-F vehicles like the Tacoma, Land Cruiser, Lexus GX, and 4Runner.
I don’t think oil pressure was a major factor. Once the engine is running, the extra few inches of hose or internal passages have essentially no meaningful effect on lubrication performance. Likewise, cooling isn’t improved simply because the filter is mounted remotely—the cooling comes from the heat exchanger itself, not its location.
As for why Toyota didn’t put it on top like BMW, Subaru, or GM have done on some engines, there are tradeoffs there as well. Top-mounted filters are certainly cleaner and more convenient for service, but they require room directly above the engine and can complicate intake, turbo, and emissions packaging. Every manufacturer makes different compromises depending on the engine layout.
mfoga
Socal
r4unner
Remember this base engine is used in a number of vehicles. I am going to guess it has a lot to do something that works for more vehicles than optimized for each vehicle.
Turbo8
Las Vegas
Those hoses are the supply and return line for coolant, not oil.
if i remember correctly the turbo center housing is water cooled, rest is oil cooled
there is a video by cc nut on the 4R engine
emerson
Emerson
Las Vegas
4Runner Trailhunter
Most of those manufacturers also have engine issues.
4Everest
Michigan
'04 Acura TSX, '25 4Runner
A couple things to consider:
  • This engine was used in other vehicles before the Taco/4Runner; it could be a packaging issue there, even though there isn't one here. Our engine bay is big, but maybe the Grand Highlander's isn't (prioritizing interior space there), or the Lexus NX (just a small vehicle in general).
  • The stack of plates "under" the base of the filter is an oil cooler. They may not have been able to put that in another place on the block (I guess this is also a packaging consideration).
  • I don't think Toyota's engineers "missed" anything with this (and here I'm speaking as a mechanical engineer myself), but I also don't think it makes maintenance any harder because the drain plug is also *right there*, and you'd have to go to this area and fiddle with that no matter where the filter is.
6thGen1419
Peter
New Mexico
  • I also don't think it makes maintenance any harder because the drain plug is also *right there*, and you'd have to go to this area and fiddle with that no matter where the filter is.
Good point.
Vincenzo
Southeast
  • The stack of plates "under" base of the filter is an oil cooler. They may not have been able to put that in another place on the block (I guess this is also a packaging consideration).
The filter and the drain plug should have been put at the top. Heck, Toyota should have done their due diligence and create an app that does the oil change
sjm.esem
Stephen
ONTARIO CANADA
2027 Toyota Land Cruiser, 2020 Polaris Slingshot SL Autodrive, 2004 Honda GL1800
Good point.
I just changed oil on my 27 LC and found it simple and straightforward Prefer this style filter over filter on my bronco 2.6 mounted on top of block.
all I care about is I have, or have had, 6 toyotas (I have 4 now)
and they've all had the simple metal spin-on filter.
I've avoided (by chance, not decision) the cartridge and o-ring filter malarkey
talk about messy....dang
Joe Dirt
Coming off of a 5th gen which was a pain to have to deal with that element style filter; going back to the canister style is welcomed for me.
I can literally do an oil change on this in 25 or less minutes. That filter is also shared with the RAV4 4th gen.
I think Toyota knows what they're doing by streamlining the automotive building process, that was part of the plan.
You can see this in lots of plastic, interchangeable parts Etc.
Car industry is definitely changing across all brands.
onlywayman
MARC
usa
2017 TOYOTA RAV4
I went from the 2001 Toyota Camry spin on filter 4967 to the RAV 4 O ring cartridge👎
4 runner
Easy Peezy it’s harder to take off the skid plate lol fram 4967? AGAIN
