Vibration while sitting idle with AC turned on
Steveg203
Steve
Connecticut
2026 4 Runner limited
My 26 stumbles as well if you idle with the air conditioning on, not sure if this is a problem or if this is the way it is
Mine does an intermittent stumble while idling. I thought that was strange and I was ready to address this when I bring it in.
Minnesota4Runner
Woodbury, MN
2025 TRD Sport
What's that sound that slowly climbs in pitch shortly after you begin driving? :unsure: Hard to explain but funny and obviously normal.
Yeah, very high-pitch whine is probably the turbo (at least it does sound like that). I usually only hear it briefly as it spins up on acceleration, but I also have a high-pitch hearing loss so maybe it is blowing everyone else's ear drums ;-).
@Gumpus I think you are spot on, although one thing...4lo torque is after the transmission, so I would not expect that to affect a/c.
I checked with Google Gemini, and it does verify my suspicion that the a/c compressor uses an electric motor for the hybrid version, but a traditional mechanical pump for the gas models. So, that would explain differences as well as the sounds. Definitely one of the less-known advantages of the hybrid versions--I suspect there are quite a few that may not be obvious.
VIRDOC
Ohio
2025 4runner TRD ORP
I have the non hybrid and was stuck in a traffic jam yesterday due to an accident.
It was the first time I noticed the "stumble" idling. In fact, I am here tonight on this forum researching if this is normal or not. Did not associate it with the AC compressor at the time, but I did have the AC on.
I was trying to investigate all the different sounds and vibrations with this vehicle today.
My engine has the AC stumble.
It has this strange sound from this youtube video. No clue what this noise is.
I swear I hear some weird chirping like noise from my exhaust or from under the vehicle somewhere. Have not gotten under to look.
I am at 2500 miles.
:unsure:
milsuper
VA
2026 TRD Off-Road Premiun
On February 26, 2026, Toyota released T-SB-0016-26 for '24-'26 4G Tacoma for A/C magnetic clutch "chirp" noise upon engagement of A/C compressor. Apparently, the replacement parts/assembly are on backorder. I have yet to hear anything regarding 4Runner's A/C compressor.
OnePunchPan
Tristate area
Checking back in here today. Wife drove the car and said "i just noticed how much this car vibrates at idle"
Turned off AC and the vibration was reduced quite a bit. Looks like this is definitely a thing
6thGen1419
Peter
New Mexico
I've never felt anything like that on my '25 ORP.
paresthesia
NJ
n/a
I have the hybrid and notice this as well. It is worst when kicking the engine on and off, as there’s no good reliable way that I found to keep the engine on when idling. Try sitting in a parking lot for an hour killing time with the air on - the constant engine on/off cycles will drive you crazy
Joe Dirt
25 orp gas version. No vibrations or shakes other than the typical AC starting and stopping sound.
I did have a Mercedes for the most part every time it would sit idle I would get engine error codes on the dashboard, I just had to take it into dealership! :) sometimes I even had it towed!
Until Mercedes corporate bought it back Lock Stock and Barrel penny for Penny.
but I digress.
watchbuzz
Buzz
East Coast, USA
'25 4runner SR5, '19 Golf R
I am at 2500 miles.
:unsure:
My SR5 sounds identical to this.
my understanding was that the TSB on tacomas was for a hard chirp when the Ac engages.
I am guessing that the consensus is that this is normal.
For what it’s worth, in my SR5 it is by far most pronounced when the temperature AND fan are set to their lowest setting. So Max cold and low fan.
If I run it with three bars of cold, and two or three bars of fan… it tends to be much more normal.
