kburrito
2025 TRD Off Road Hybrid
I too also caved. I blame you all lol
I did check the rear tow hook. It seems like the front opening is only big enough for a d-shackle (not sure if 3/4 inch as I dont own a d-shackle)? I foresee only using the front opening as a tie down point for a rachet strap if i hang something through the rear window
The soft shackle I have doesn't fit through the first smaller opening but only the bigger one further in.
2025 2026 4runner 6th gen Toyota OEM Rear Recovery Hook (Part number # PT974-89251-03 and PT974-89251-AA) 1767139202849-jt
ScoMay
Tennessee
2022 Ram 1500 Rebel
Just ordered as well, $83.09 shipped with tax. Thank you for the link!
You are welcome! FWIW I have not heard anything from Hoover (yet) on when it will ship. You may have to be patient.
Hopefully we can just enjoy the good looks and not worry about getting dragged out of a ravine someday by that brand new shiny hook!
Do the front really come with a recovery strap or is that just a marketing image?
kburrito
All marketing since you can opt get ARB recovery straps from Toyota for a premium markup.
With the front hooks, you'll only be able to get soft shackles on them. Even with that, you'll be right up against the plastic trim above it
DannyvanDelft
Danny
Strongsville
2026 4Runner TRD ORP
My skid plate and front tow hooks arrived yesterday, the rear hook is on the way, just need the car to be delivered 🤣 was supposed to be here day after Christmas, but the weather had other ideas.
mush
Q
Houston, TX
2025 4Runner 2007 Tacoma
whats the torque spec on the rear tow hook?
828findadventure
Tacoma & Tundra
Soft shackle and kinetic rope is the only way to go if you aren't winching.
828findadventure
Tacoma & Tundra
Any rec on a good kinetic rope brand?
I don't have any name brands that I use, because they are too expensive. But, I do make sure I get one that is an inch at the minimum wide by thirty feet. Anything shorter or thinner is better for mid size SUVs.
I've got a TRD ORP with the standard black recovery points (2 front, 1 back). Photos below. My question: is there a functional improvement going with the red Toyota recovery points (or something like this sxth-element prototype)? Or is it mostly about looks? The alternate recovery points all seem to provide maybe a bit more access but its not clear to me that there is a real functional benefit. But I don't know which is why I'm asking. (And to other question above, I am not recommending this but was gifted it for xmas and look forward to using it to help someone ELSE out of being stuck: Hokinety Recovery rope)
TRD OR recovery point rear:
2025 2026 4runner 6th gen Toyota OEM Rear Recovery Hook (Part number # PT974-89251-03 and PT974-89251-AA) 20250610_194728
TRD OR recovery points front (black in front of shock to either side of skid pad):
2025 2026 4runner 6th gen Toyota OEM Rear Recovery Hook (Part number # PT974-89251-03 and PT974-89251-AA) 20251002_221821-EDIT
828findadventure
Tacoma & Tundra
A quick google images search of that part number shows this
if it really is this then it looks good. Also being right hand (and in the picture) implies there's a left hand too. Probably good to distribute a pulling load across two mounting points
2024-26 Tacoma Left or right recovery hook
rear wise ...
only the tacoma has a right and left oem hook.
the 4runner only has a mounting point for the right side oem hook
normally shipping tie downs are removed from most non BoF vehicles. BoF vehicles they leave the oem tie down points on since they are used for off roading.
the red oem ones are just fancy replacements for the oem tie down points. they just charge you for a fancy red one and keep the oem one, so toyota saves money keeping the originals.
unless you buy them afterwards and you keep the originals
