Starlink Roam? Mounting Options
mjssss
NM
Trailhunter on-order
Hi all,
Anyone have a Starlink Roam plan? I’m curious on how you mounted the antenna and routed power. Would love a way to have it powered from the hybrid battery and available while driving.
if you get the Roam 100GB plan, you can place it it Standby mode for $5/month. In this mode, unlimited data at 500kbps anywhere in the US.
Thanks!
Twisted
5th Gen TRD -> 6th Gen TRDORP
I just use the Veritas Vans mount with magnets. I have the ARB rack with one of the rear bars missing which makes a great spot for the starling. I PPF'd a section of my roof and when I need it I just throw it up there. I have the battery pack on it so I've got 4 hours or so of battery. I rarely need it more than an hour or two at a time in dead areas. If I need more I'd just run a USB C cable up there and keep it running. Plus with the battery it stays on even when I turn off the 4runner.
Added bonus, I keep it in the rig when not using it and when riding in someone else's rig I can just throw it on their roof and have a connection no matter what.
John2112
Austin Texas
Hi all,
Thanks!
I'm using the starlink mini mounted in the veritas vans mount with the magnetic feet. I have a trail hunter and it fits exactly between two of the roof rails and can't be seen from the ground. The power cable I have running by the roof rack through the molding down to the power outlet in the back of the Trail Hunter. I do run it through a jackery battery so that when I stop to get gas the whole thing doesn't have to reboot. It works well, although on my trips I do take it off of pause and get the unlimited plan since we seem to go over the 100 gig constantly this from the non-stop live streaming from my passengers. This setup also lets me make phone calls and have internet and all those no cell phone areas but I travel through.
2025 2026 4runner 6th gen Starlink Roam? Mounting Options Screenshot_20260210-094948
2025 2026 4runner 6th gen Starlink Roam? Mounting Options PXL_20260210_154855873
2025 2026 4runner 6th gen Starlink Roam? Mounting Options PXL_20260210_154904984
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
Hi all,
Thanks!
If you are referring to the Starlink mini? I use these mounts, mounted toward the rear of the my roof rack and run the cable through the rear hatch door. This method Is secure and is less likely to deter theft vs magnets.
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_6984
VB4Runner
Mitesh
2025 TRD ORP
I have mine mounted inside one of my Roam cases. They sell a mount (quite overpriced at $95, IMO) that includes a grommet and plug in case you need to drill a hole to route the power cord out of the box.
For now, I just keep a small portable battery that keeps the starlink running over a full day right inside the case so it’s all sealed up and secure.
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_7370
T_Pomp
Anthony
Illinois
Do you remove it when you need to use it or how is it getting direct exposure to the sky?
VB4Runner
Mitesh
2025 TRD ORP
Nope, it works as it is shown mounted inside the case. No need to remove the starlink. We can be driving down the road and have a strong signal, or can be in our tent and also have a strong signal.
Peppoh
Gigi
4Runner 6th
I have it mounted on the roof rack. Enclosure is custom made 3D printed. I designed it so it stays flush to the rack frames. It’s very inconspicuous unless you watch with attention. I’m experimenting with a new fully enclosed top design so it doesn’t shine all white. It has 1/4 threads in case I need to remove from the vehicle and use with rentals/turo, in which case I use suction cups similar to Veritas Vans or magnet mounts, depending on the vehicle roof shape/material. In my 4Runner I get power from a pre-wired aux in the front. The only annoying thing is it goes off when you switch off the vehicle. For my use case, it’s still ok. Hope this helps with your project
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_0322
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_0323
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_0325
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_0326
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_0318
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_0329
2025 2026 4runner 6th gen Starlink Roam? Mounting Options IMG_0328
Joestac
@John2112 I know this is old, but I ordered the mini to use on my trips. Was going to try the same spot on my TH. Did you run the cable through the rear hatch? Any issues? I was also going to use my Jackery.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
And it works through the Roam case? [edit] Never mind just finished reading your other answer.
I'm lost in the tech world, my question, is there a way to use the starlink mini through the infotainment system for using apps like OnX offroad? I've been to many a spot where I lose signal and my map goes dead, not fun in back country when there's more than one route to choose from.
I think it will help with the cell signal but what about the infotainment signal?
Joestac
The problem is, you'll need to wire your phone to the infotainment since you can't be connected to two different wifi points.
So, wire your phone to the truck and connect your phone to Starlink via wifi and you're good. That's one of the main reasons I'm getting it.
I have been hard wiring my phone for Android Auto since getting the Fold 8 though. So won't be any change for me.
Thanks, I was just doing more research, seems with the setup cost and 1 year fee is around $1,200 and $650 a year after that. Seems high to me for 100 gb. And 300 gb is almost a grand a year.
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
To "Occupy Mars" is not going to be cheap... ;)
I've been putting my Mini in between the sunroof (fully closed). No issue at all. Still get highest speed while driving & parking. I run the power to my 1Kw Ecoflow power station so the Mini is on 24/7.
I won't plan for a permanent solution due to the terminal is being shared with other folks in my household when needed. This works for my case!
2025 2026 4runner 6th gen Starlink Roam? Mounting Options 20260921_135550
