FoozGrind
Well... the screeching noise came back! So I contacted Toyota again! I should have started the buy back option the last time, but I decided to give the 4Runner a try, but here it is again! This would be the 4th time! I already contacted Toyota again and attached a video of the noise. Let's see what happens now...while I ove the 4Runner, I don't think I will settle for another one:mad: Reading this forum I realized thatches is a random issue and who knows if I get lucky again! LOL
Good luck… I’ve contacted them 13 times since April 4th 2025. Plus I filed arbitration and requested a buy back. I spent a month collecting documents…. Every single service record, every chat everything. I sent videoes tons of them. Told them it’s unsafe and will affect my resale value. At the end of the day Toyota only came back said it doesn’t meet Magnuson-Moss Warranty Act.
Toyota dealer only tried to repair the brakes twice and the regional manager refused having them done third time. It didn’t matter that I brought it in 5 times to the dealer…. I had other issues but each time I mentioned brakes.
Good luck to you! I hope you stick it up their ass. I still haven’t written my letter of disappointment directly to Toyota not sure what VP to address the letter to.
Basically the free arbitration service Toyota offers to consumers sided with Toyota. Go figure
ibu66
OSCAR
Miami, Fl
2025 4Runner XP
Wow! Sorry to hear that! Will keep you posted! At this point, after 30 years of owning Toyotas, I am getting closer to switch to another brand. I was very excited for my first 4Runner, but I guess it was not in my path😔
FoozGrind
This is my 3rd. It was so loud today I heard my wife leaving with the 4Runner while I was upstairs in the master bedroom talking to a vendor about window blinds. I even have impact windows lol. But I’ve dealt with it so long now it’s whatever. Wish they would have at least sent me a candy gift basket. I can tell you that from all the reading I’ve seen the only Toyota truck on the new platform that doesn’t squeal is the Tacoma.
RaulP
Raul
Fl
I haven’t had mine fixed the first time yet. Got the run around from Toyota of FWB. I was there last week and finally cornered the service manager. Supposedly, he contacted regional Toyota?, and was told a new bulletin was coming that replaces the rotors as well as pads, however because there are not enough rotors available they won’t release the bulletin until they have them in stock. At this point I really don’t believe them, but that was the latest I was told. He did at least say he would replace the pads under the current bulletin if I wanted but would need to do it again once the new one is released. Any else hearing about a new bulletin being released.
FoozGrind
They just released one that says they can now use two different type of shims…. lol it’s so weird they techs can’t do anything outside of what the Toyota says to do. So I guess 2 tsbs back the had a different shim kit then they changed it now it says use both. As far as rotors I haven’t heard anything but that sounds like what they should have done from the first freaking time. The tundra and sequia get them why don’t the 4Runners or land cruisers?
BonRunner
2026 TRD Sport Premium / WCP
I posted this in another thread but reposting here:
________________
I think I may have solves this issue!
I sprayed CRC Brake Cleaner in my front brake pads earlier this month. Sprayed on the pads, avoiding calipers & on back side. I turned the wheels to get more room to spray them. I use the extended nozzle.
Magically, the squealing has STOPPED right after! I'm not sure it's a fluke or something else but in the morning when backing up from garage to driveway, it's peacefully quiet 🄲 Been 3 weeks now. No other issues at all.
Ambient temp at 7am is ranging from 30° - 50°F. Some time wet, some time dry. It's the 18th of Mar. No squealing when reversing! šŸ™Œ
Will update if anything changes.
con5tant
4runner ORP Max
My dealership said the new TSB is shims, brake pads, rotors AND calipers....which they ordered for me...but will be a 5-6 month wait due to "parts shortage".
FoozGrind
Hrmmm I would check what exactly they ordered. I am attaching the latest tsb I could find and rotors are still not mentioned.
My local dealer over the phone said it was "normal" to hear that in the morning with moisture. To wit I enlightened her and said my car stays in a temp controlled garage and there is no moisture. Also said it happens getting into my car sometimes end of the day, a hot Texas day.
She said they'd do it under the TSB at my 10k change coming up in 3500 miles. Just to call them before to make sure they have the parts.
Now I need to ask what parts they are ordering.
kekecarioca
_CAC_
Yeah "Normal".... dealers..... Let us know how that goes and hope it helps in your case. I 've been dancing with the idea, but really do not want to waste my time at the dealer for the squeal to come back after all as others have experienced.... I've exhausted all my Toyota care visits and really did not like the last experience there, plus outrageous $$ of oil change there too.
BonRunner
________________
1 month update: still no squealing after my quick fix!
ibu66
OSCAR
Miami, Fl
2025 4Runner XP
Well, mine is still screeching. I got a call from Toyota. They advised me to take the car to the dealership to look at the issue. However, the last time I was there, they couldn’t reinstate the noise and nothing was done. Although the noise is still happening, there are no guarantees that there will be able to reinstate it. Therefore, nothing will be done. The humidity excuse is non sense! We have a 2021 4Runner that does not screech at all! So that theory is not valid right there! Will see what the next step is with Toyota. This is simply a defect which might get worse with time, but I won’t risk waiting more time to see if it happens or not. Then the car won’t be under warranty!😔 I trust Toyota to proceed accordingly! Will keep you posted! This is like a bad soap opera🤣🤣 with chapters that make no sense!
FoozGrind
This brake issue has been going on since 2022 with the tundra and the TNGA-F platform from what I can gather looking online. Every Truck and SUV on that platform has a tsb for brake squeals Except the Tacoma which I have no idea why they don’t have an issue. I don’t think They will incorporate a real fix from buying off the lot until they redesign or give it a facelift. I bet the Tundra givin its age will get the facelift or redesign first and brakes will be fixed. They will eventually give us rotors I bet on the tsb but not until they saved every Penny they can buy just replacing brake pads and fixing those who it works for first….. because why spend money on something that isn’t a safety issue so they say…. I’ve just learned to live with it since dealing with it since March 2025 and I can guarantee I’ve put more work into getting them fixed then most of you :) if you haven’t made it to a https://www.ncdsusa.org/clients/toyota.html I got you.
so when I back out and I hear the squeal starting I just start slamming my brakes and backing out couple inches at a time looking like a fool…. No not a safety issue at all….
I got a co worker who has a 2025 tundra just hit 20k and now his is squealing. Didn’t believe me at first when I told him how bad mine was…
ibu66
OSCAR
Miami, Fl
2025 4Runner XP
Update... Took my 4R to the dealership as instructed by Case Manager. Technicians did two test drives and could not replicate the noise. Upon thinking about the ongoing process of claiming a buyback, and the possibility of the noise never going away, I traded in my 4R for a RAV4. It's a really pity that this great vehicle is going through that without a solution being found. Thank you for all your support in this forum, for exchanging what we have gone through and your solutions. Wishing you all that the noise gets fixed!
nighthawk
2020 Rav4 XSE
I took my 4Runner into the dealership about 2 months ago for the squeal noise. They replaced some stuff on the front brakes and I haven't heard the noise since. Hope it stays that way.
