s3lekta
M
ON, Canada
C's6G4RTRDPro
Chuck
NE Ohio
2025 Ice Cap 4Runner TRD Pro
My TRD Pro with 2" Torq lift level kit and 0 offset 18x9 Pro Comp PA34 Rockwell wheels.
Wanted brushed but worried about winter salt.
I think I'm going to get 285/65's or whatever I can run wider without going much taller. These Toyos look a little small.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! TRD Pro with 2%22 Torq Engineering lift level kit and 0 offset 18x9 Pro Comp PA34 Rockwell wh
Henry
Henry
CT
TRD ORP on stock suspension height
RR7-H Flow Formed wheels +25 offset
Falken Wildpeak AT4W 285/70r17 (C Rated)
No rubbing
Slight poke
TxTrdPro
Seth
DFW, TX
2025 4Runner TRD PRO
UPDATE:
Quick update - just got my BFG KO3 tires mounted tonight. Went with 305/65/18 size to give it a much wider and more aggressive look. It definitely worked! Couldn’t be happier right now.
Here’s some more pics from this morning to show the poke.
ORIGINAL POST (before KO3 tires):
New member out of DFW TX, just got my fiancée a 2025 TRD PRO in black and doing a few things to it to make it stand out. Day 2 we installed the Westcott Designs TRD PRO front & rear level kit on it.
We also installed 1” Spidertrax spacers front & rear to give it a better stance with the factory wheels. We may replace them with a different offset wheel down the road but for now we like the way they look but didn’t want a tucked in look once lifted.
It looks so much better now and had a great stance. Got it aligned and it is now ready for new tires which are getting installed tomorrow!
More pics to to come.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Westcott front & rear level collar lift + 1%22 spacers on 2025 4Runner TRD Pro 7
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Westcott front & rear level collar lift + 1%22 spacers on 2025 4Runner TRD Pro 6
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Westcott front & rear level collar lift + 1%22 spacers on 2025 4Runner TRD Pro 5
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Westcott front & rear level collar lift + 1%22 spacers on 2025 4Runner TRD Pro 4
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Westcott front & rear level collar lift + 1%22 spacers on 2025 4Runner TRD Pro 2
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Westcott front & rear level collar lift + 1%22 spacers on 2025 4Runner TRD Pro 1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Westcott front & rear level collar lift + 1%22 spacers on 2025 4Runner TRD Pro 3
Henry
Henry
CT
No rubbing
Slight poke
More:
No rubbing
Slight poke
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! RR7-H +25 offset Falken Wildpeak AT4W 285:70r17 (C Rated) 1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! RR7-H +25 offset Falken Wildpeak AT4W 285:70r17 (C Rated) 3
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! RR7-H +25 offset Falken Wildpeak AT4W 285:70r17 (C Rated) 2
PatJc
Patrick
Eastern Passage
4Runner TRD ORP iForce-Max
- 285/70/R17 Falken Wildpeak AT4W C-Load
- Blackhorn NS5 Coyote wheels (+25 offset)
- RC Rough Country 1.5" Level kit
- Husky Liner low pro visor
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! TRD ORP iforce max build: RC 1.5%22 level, 285:70::17 Falken Wildpeak, +25 offset Blackhorn N
papadop88
Stock Pro Wheels (18x8.5 +20)
295/70/18 Nitto Recon Grapplers in Standard Load (53lbs per tire)
Westcott Designs TRD Pro Lift Kit (Did not install 1" Top Hats in the front)
Slight poke, zero rub, even with the stock ride height.
I will be going up to a full 35x12.5x18 tire (might drop down to a 17" wheel and tire though) for a wider stance.
My numbers (measured from bottom of rim to bottom of fender):
  • Driver Front: 30.88" | 32.25" (1.37" lift)
  • Driver Rear: 31.75" | 32.62" (0.87" lift)
  • Pass Front: 30.88" | 32.62" (1.74" lift)
  • Pass Rear: 32.00" | 32.80". (0.80" lift)
Full Build Thread Here Answers All Questions
Yoosuhhh
Shane
florida
2025 4Runner TRD Offroad premium iForceMax, 2018 4Runner TRD Offroad
Is there anyone in here running A 0 offset wheel on 35's? If so I would deff like to see how it looks
papadop88
TxTrdPro shown above, running 18x8.5 +20 Stock Pro wheels with 12" wide KO3s. While not exactly a 0 offset on true 35s (12.5" wide), it will give you an almost exact look on a Pro. If you have a different trim that doesn't have the wider fender flares, then it will look even more pronounced, and you'll be cutting ALOT to get them to fit. The look of that stance is going to be a whole other discussion. :ROFLMAO:
Gastan
Oregon
Tacoma TRD Pro
pmarohl
Paul
2025 4runner trailhunter
Stock Trailhunter on 35x12.5 tires (Micky Thompson Baja Boss).
Removed crash plates and no rubbing. Full stock setup, and wheels.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4188
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_4191
DangItsDen
Hayden
Toyo AT3 285/70r17 Load C
Method 703 +35 mm offset
Peak Suspension 1.25" front level
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_0985
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_0986
