mfifty5
Scott
Puyallup WA
Only a couple 100 miles in and time to lift. Cali Raised rock sliders on order.
2.5" ReadyLIFT lift kit
ReadyLIFT upper control arms UCA
Raceline Alpha 17x8.5 0mm Offset
Nitto Ridge Grapplers 285/70/17 tires
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20254Runner1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 20254Runner2
mthw1993
mathew
norwalk, ca
2025 T4R ORP
TX4RStormfly
Amanda
Dallas/Fort Worth
2016 4Runner Trail Premium, 2025 4Runner ORP i-Force MAX
This is Stormfly! 2025 ORP iForceMAX I got in July. Looking forward to seeing where it goes!
17" Black Rhino AWOL Wheels (-12 offset)
Originally wrapped with 285/70/17 Fuel Gripper tires - Don’t recommend
Re-wrapped with 285/70/17 Falken Wildpeak AT4W tires - Highly recommend
1.5: ReadyLift level kit
See full build thread: https://www.4runner6g.com/forum/thr...readylift-level-285-70-17-wildpeak-at4w.6561/
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21065-26de1e6da33c5b5bab8a02e4216004ba
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_8391
More pics!!
From beginning to now -
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6123
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_6628
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Resized_20250918_125441
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_8580
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_8520
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21253-88c6c14cc35a27a0efe64ac480e7a596
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21250-01846d9cd709259d9e31b9f8a9a2a024
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21248-c7e8eccd5f237d5927e00a61672ccaff
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 555439650_10234234197210973_6722552563075075819_n
chrismacc
chris
dallas, Ga
2025 4runner
2025 SR5 4wd. Picked it up last Tuesday. We had a 2021 4Runner before this. We love it so far, had the new tires installed yesterday (285/70/17 Nitto Ridge Grappler tires).
Added the tricolor badge to the front today. I purchased it from @StickerFab.
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3707
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3702
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! IMG_3703
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 555678839_10161979037536463_6870552256893506380_n
4Rghostpro
Michael
San Diego
2025 icecap 4runner Pro
Took a slight chance and replaced 285/70/18 Toyo AT3 with 295/70/18 Toyo SL RT trails . Confirm that it fits with no lift. I just had to remove the liner and mudflaps. No touch on crash plate as of yet.
285/70/18 Toyo AT3
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! stock 2025 4runner trd pro 295:70:18 tires (Toyo Open Country R:T Trail)3
295/70/18 Toyo RT Trails Stance and it looks so much better!
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! stock 2025 4runner trd pro 295:70:18 tires (Toyo Open Country R:T Trail)2
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! stock 2025 4runner trd pro 295:70:18 tires (Toyo Open Country R:T Trail)1
ian.web
Ian
Ky, USA
25 4runner SR5
Method 305 wheels: +25 offset | 17x8.5 | 6x5.5 / 5.7" back spacing
285/70/17 KO3 tires
Westcott lift 2.5" front and 0.75" back
Husky liners low profile window vents
Amber stickers on the fogs 🤣
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Upgraded 2025 4Runner SR5 w: Method 305, Westcott lift, 285:70:17 KO3 3
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Upgraded 2025 4Runner SR5 w: Method 305, Westcott lift, 285:70:17 KO3 1
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! Upgraded 2025 4Runner SR5 w: Method 305, Westcott lift, 285:70:17 KO3 2
danimaldaisy
San Bernardino
6th gen trd sport
New wheels mounted up on my wife's TRD Pro.
Toyo Open Country AT3 tires - 285/75/70
Fuel 17x8.5 +10 mm offset
Stock Pro Suspension
Thinking about adding a 1/2" spacer up front. It's not rubbing or anything, but I feel like another half inch in height would look great.
The 10mm offset sits perfect on the Pro in my opinion. The tire bulge pokes, but eh actual tread doesn't.
2025 4runner trd pro Toyo Open Country At3 285:75:70 Fuel 17x8.5  +10mm offset 1.webp
2025 4runner trd pro Toyo Open Country At3 285:75:70 Fuel 17x8.5  +10mm offset 4.webp
2025 4runner trd pro Toyo Open Country At3 285:75:70 Fuel 17x8.5  +10mm offset 3.webp
2025 4runner trd pro Toyo Open Country At3 285:75:70 Fuel 17x8.5  +10mm offset 2.webp
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! {filename}
Based on my last two 4 runners you will need a 1/4 inch spacer to get a half inch.
Henry
Henry
CT
TRD ORP on stock suspension height
RR7-H Flow Formed wheels +25 offset
Falken Wildpeak AT4W 285/70r17 (C Rated)
No rubbing
Slight poke
michael
aliso viejo
2025 toyota 4runner
Here it is!
The 6G is fresh out of the shop running its new 3.5 Long travel kit on 38” Nitto tires!! And man is it driving good!!
Make sure to follow the bill and watch me cut this thing up on the Mammoth4runner YouTube channel!
@wickedcreationsinc 3.5” Long Travel Kit
@locked_offroad 2.5 LT Spec Coilovers
@locked_offroad 2.5 Triple Bypasses
@locked_offroad 2.5 Rears
@dobinsonssprings 3” Rear Springs
@dr_kdss Panhard Correction
@nittotire 38x13.50R17 Trail Grapplers
@lockoffroadwheels Invader Beadlocks
@frontrunneroutfitters Slim Sport Roof Rack
@rigidindustries Adapt Light Bar 🔆
@seiboncarbon Carbon Fiber Hood
@lockoffroadwheels invader beadlocks
#Mammoth4Runner #TrailMammoth #Toyota4Runner #6thGen4Runner #5thGen4Runner #Toyota #Yota #LongTravel #WickedCreations #LockedOffroad #NittoTires #Dobinsons #Beadlocks
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21833-c36b6250e6faf8012ad11659a7332920
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21834-2f1de4670579fc1f18992bbc4417a1b6
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21835-c2738ac271d8fb3bca6a2972c465b6ea
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21837-e4867755b6418feaca5bd3d132260fbc
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 559582964_32237684649180768_7174087688320468052_n
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21836-a1ec0cc449ef885ace41fcba6ea7405
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 21838-ff4d280cb0b73be2262008f3c2ef978f
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 558193044_32237685599180673_4163237707603992220_n
2025 2026 4runner 6th gen Aftermarket Wheels, Bigger Tires, Lift Kits (Compilation) for 2025+ 4Runner 6th Gen -- Add Yours! 556898393_32237684745847425_6451341448127253223_n
VIDEO:
Ty43mm
Terrence
LA
4Runner TRD-Off Road Premium
