Jpr18
Southern California
Why did you use the white plug under the overhead console and not the Y-cable for the driver assist camera?
Van Solo
Van Solo
Van
Calgary / Canada
To get parking mode and do not want to plug into safety for safety
ecornista
Nevada
camry
What do you mean “do not eat to plug into safety for safety”?
do we still have the option to use the Y Cable for installation, right?
Van Solo
Van Solo
Van
Calgary / Canada
Sure you can, I just prefer not to tap into safety equipment myself.
The cable will maintain power to the camera in the event someone hits your vehicle.
Ahmad310
Ahmad
Cincinnati, OH
2025 4Runner Platinum
ex
Not sure I follow
where is that cable on their website ?
https://fitcamx.com/collections/fus...parking-mode-cable-for-toyota-sienna-2021-now
As I understand it, using this cable, allows you to bypass the supplied Y cable and provides limited power when the car is off should there be a impact while parked it will record briefly (FitcamX calls this "Parking Mode").
When using the Y cable, there is no power once the car is turned off, so it will not record anything at that point.
ToYoDaMan
Allan
Bay Area
Larger storage front camera is currently out of stock.
Will wait to purchase once available.
Thanks for the Sienna Wire connection to enable park mode!
Looking forward to install!
Ahmad310
Ahmad
Cincinnati, OH
Which camera is this? I only see option for 64GB front camera (But you can upgrade up to 256mb SD card of your own) I do see one with 128GB but it is for the Front/Rear cam combo kit.
ToYoDaMan
Allan
Bay Area
@Michaelkael post on page 2, his page capture showed the front camera with the bigger storage.
I thought I also saw it a few days ago.
I could be wrong. If what you are saying is true, maybe I will just get it now and upgrade the storage later.
Ahmad310
Ahmad
Cincinnati, OH
Hmm not sure, on this link there are only 3 options. A front 4k camera with 64g, a front 2k/rear 1080p w/64gb, and a Front 4k/Rear 1080p with 128gb. All 3 are showing in stock.
https://fitcamx.com/collections/toy...yota-4runner-2025-2026?variant=44753210212524
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) fitcam
I ordered a 256gb SanDisk MAX ENDURANCE microSD™ Card which is made for applications like a dash cam.
Jadon.lm
Kia Rio 2012
This is my second installation of the Fitcamx for the 4Runner. I had previously been helping with testing their prototypes. This time I asked to receive the additional rear camera. Routing the cable is simple honestly. They give you more than enough, however there isn't a lot of spots to actually mount the camera in the back. And I didn't want to obstruct the window or run the cable through the trunk.
Decided to design a 3D printed plate that can be mounted to the roof liner pin above the trunk. With some velcro on the other side, the plate itself does not move at all once secured back through with the pin. I also designed the plate to align itself with the camera to have it centered perfectly. I have a full view of the back as the camera is extremely wide.
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) IMG_0050
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) IMG_0058
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) IMG_0055
2025 2026 4runner 6th gen FITCAMX dash cam install - step by step how-to DIY (on 2025+ 4runner 6th gen) IMG_0057
deeda
Dee
San Diego
2025 4runner
UPDATED September 21, 2025
It's here at its installed....................FITCAMX 2025 4Runner
Install time 10minutes and neatly cabled
I chose the CLP filter and the oem dash cam plug in from FITCAMX
Step 1. Remove Overhead Console. (One Swift Pull Down the front near windshield)
Locate the White OEM Dash Cam Plug.
Plug in the optional FITCAMX power cable.
Route the power through the headliner toward the mirror.
Step 3. Remove OEM Mirror Housing and remove the two red clips and relocate the to the FITCAMX housing.
Step 4. Slide the FITCAMX housing into place and listen for the Click!
Step 5. Connect the power cables togethers.
And get out there and start recording your Off Road Adventures...... FITCAMX
To order yours Today use the link below in my signature and get fast delivery.
Oh man there wasn’t an option for the OEM cam when I ordered. 😕
