- First Name
- Ahmad
- Joined
- Jan 22, 2025
- Threads
- 6
- Messages
- 134
- Reaction score
- 100
- Location
- Cincinnati, OH
- Vehicle(s)
- 2025 4Runner Platinum
Ordered, FYI found a 10% off coupon "BFBB" that worked too!
NiceOrdered, FYI found a 10% off coupon "BFBB" that worked too!
Looking great, thanks for the step by step install !FITCAMX Installed,
Step 1. Remove Overhead Console (One swift Pull Down closet to windshield)
Step 2. Locate the White OEM Plug used by Toyota OEM Dash Cam.
Plug the optional FITCAMX plug & play Toyota cable.
Step 3. Remove the Two Red Clips from the Factory Mirror Housing and Add them too the FITCAMX Housing.
Step 4. Route the Power Cable through the headliner towards the Mirror.
Step 5. Slide the FITCAMX Housing into place and Hear the Click.
Step 6. Connect the Power Cables.
Now get out there and record this 4Runner Adventures with FITCAMX!
Get yours now use link in my signature please to order yours Today!
Yes, The FITCAMX Toyota cable supports the Parking mode!Looking great, thanks for the step by step install !
You got the front only I assume ?
Did you ask for the parking mode option too ?
FITCAMX offers a Toyota Plug & Play Cable in the accessories menu.Looks great! When you say you chose oem dash cam plug in, did you originally have the OEM or is the connection already pre wired from Toyota? Did you have to buy anything extra to connect to that?
Looks like they might be able to help ?!Yes, The FITCAMX Toyota cable supports the Parking mode?!
The cable does support parking mode!Looks like they might be able to help ?!
Hi, did they run out of the Plug and Play Cable? All I see is a Toyota Sienna cable is that is similar to yours?FITCAMX offers a Toyota Plug & Play Cable in the accessories menu.
Sienna cableAlso, did you order straight to Canada ? Any import taxes/duties kind of surprise ?!
Sienna cable worksHi, did they run out of the Plug and Play Cable? All I see is a Toyota Sienna cable that is similar to yours.
