viper2788
Daniel
PG County, MD
2026 TRD ORP
Just finished swapping out my oem JBL sub for a Kicker compRT8 pushing 300W. The goal was to keep it clean and looking 100% oem without losing any cargo space. This took quite some time as there isnt much info online and I had to spend hours on chatGPT, youtube and constant tinkering. Toyota really didnt want people customizing their sound system and made everything much more difficult than it couldve been. Hopefully this can help out others looking to do a similar mod.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6057
Basic parts list:
- Kicker compRT8 (I used the 4ohm version and wired in parallel to achieve 300W @ 2ohms, I'd suggest getting a 2ohm version)
- Audio Control AMC-1.300 (LOC and amp, needed to restore bass dropoff)
- Taco Tunes harness (bought the package but all I needed was harness #1)
- Recoil OFC complete amp wiring kit +40A fuse
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6034
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6035
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6037
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6039
Check out the difference in the magnet sizes! The oem sub speaker is a joke and weighs a small fraction of the kicker.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6046
The oem sub comes out easily as its help on by 4 screws, however, the mounting bracket is built into the speaker. I used a band saw to seperate the two, but you can do so by clipping the arms of it (photo above) just before the slim outer ring. I would also try to preserve the silicone seal around the bracket as mine was damaged in the process. I ended up 3d printing another seal using standard 95A tpu filament and secured it with e6000 rubberized glue. I dont believe there are any brackets that you can buy for this, so if youre unable to fabricate one fromt scratch, def reuse the oem bracket. I thought about 3d printing custom bracket using PA6CF, but figured this would be the path of least resistance.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6048
I figured as I've put so much time into this project, might as well do the extra steps to add dynamat to the oem box and also added 3oz of polyfill. Both should help achieve a deeper, better sounding bass. Dynamat was placed on most flat surfaces on the front and back of the box. I didnt bother doing the sides.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6052
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6051
There is no factory wire passthrough so I had to drill out a hole and place a rubber grommet to pass the speaker wires through. The grommet was further reinforced using JB weld on both sides to keep it aright or from popping out entirely.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6053
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6047
When mounting the kicker sub, the inner diameter of the oem bracket had to be shaved down a pinch to get it to fit. Holes also had to be drilled to accpet the kicker. There was very little tapping surface once the new screws were placed in, so careful pressure had to be used to prevent stripping what little material the screws had to grab on. Other other side doesnt have enough space for bolts and nuts, so instead a liberal amount JB weld was used to reinforce the screw ends.
More dynamat was used to the flat surfaces behind the sub box.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6055
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6056
The speaker wire was wrapped and secured in several places using harness tape. Forgot to take pics but it was routed along the passenger side next to other factory wires. It was then routed underneath the passenger seat carpet and then through the center console to the driver side.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6020
The oem amp sits under the driver seat and the taco tunes harness #1 was installed under the carpet. The ACM-1.300 turns on automatically so I didnt need hanress #2 for the remote turn on cable. I also didnt need the yellow power wire or the black ground wire from harness #1 - those were taped off and folded in. The 8 gauge ground cable, on the other hand, connects directly to the ACM and I found a random hole under the driver seat to secure to.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6067
From top to bottom:
1) Power cable to the battery
2) Ground cable
3) Speaker input cables from Taco Tunes harness #1
4) Bass control knob
5) Speaker output cables connected to Kicker sub
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6066
The bass control knob sure would look nice mounted onto one of those blank buttons... but I'm tired. Velcro it is.
The ACM-1.300 didnt fit under the driver seat, even with the air ducts removed. It currently sits in front of the driver seat but may try to move under the passenger seat.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6024
The power cable was routed through the grommet on the drivers side. Theres a small nipple that can be cut and access is pretty straightforward. Taped a thin aluminum rod to the end of the power cable to push through. Theres another grommet on the passenger side if you want to go that route.
2025 2026 4runner 6th gen OEM Subwoofer Upgrade Finished! (Kicker Sub Replacement) IMG_6061
So, the kicker speaker sticks out just a bit and makes contact with the rear quarter trim. Its mostly the speaker bezel that makes contact so I dont believe it'll affect the sound much, but I'd either chose another sub with a thinner bezel or make a thinner mounting bracket if I had to do it all over again. But in any case, everything closed up for the most part. Theres only one or two clips near the top that doesnt quite clip in, but structurally its still held in secure by bolts.
Thats about it... I'm still trying to fine tune the accubass on the ACM-1.300, but it sounds amazing on certain songs. Need to adjust the threshold to a smooth transition once the factory bass rolls off. I like having the amp where it is now (in front of drivers seat) as I can easily adjust turning, but thinking of eventually moving under the passenger seat where theres more room.
If you have any advice as to making this project a little easier or cleaner, please chime in!
update (7/20/2026):
Finally figured out my bass settings (sort of)
I've been having issues tuning the ACM-1.300 as I've had threshold way too high. Bass was good on certain songs but often times it seemed I had made a huge gap between my mids and lows. Subwoofer only played certain bass frequencies and the door speakers sounded wimpy... a lot was missing in between. I found that having both the threshold and level knobs at the 12 oclock position gives me plenty of restored bass and its actually very well integrated with the factory door speakers and the rest of the system. I've increased my bass setting on my head unit equalizer to the max as well as the aftermarket bass knob, and adjusted the gain setting on the ACM to where the max light only flickers a bit on heavy bass songs. This seems to cover most songs perfectly and I'm still able to quickly lower bass using the knob when needed.
That being taken care of, I think I'm just going to cut way some of the carpet under the drivers seat (where the vent used to be) to secure the ACM. Theres actually room for it but I didnt want to suffocate the amp as it does build up some heat. With part of the carpet cut away and some additional heat sinks added to the amp, it should be good to go. Will update again once properly installed.
TRD_Alex
New York
2025 4Runner TRD Off Road Premium iForce Max, 2014 Jeep Wrangler JKU Willys
Great work! Was the juice worth the squeeze? Can't wait for JL or someone to make a drop in stealth box replacement.
horbit
DFW
Phew that was a lot of work! Congrats.
viper2788
Daniel
PG County, MD
2026 TRD ORP
Always worth it when theres no current alternative lol I could do this again fairly easily but the first time around was a hell of a squeeze!
  • Like
Reactions: L-2
Dead Horse
Oklahoma
Doin the lord's work here LOL
I'm waiting for somebody to get the whole thing ironed out for the hybrids and I'll hop in. I had enough heartburn with the Trailhunter light bar, I'm not being a trail blazer for the stereo too :D
Cartierusm
Carter
San Francisco
2025 4Runner i-Force Max Off Road Premium
Yeah I've got the upgraded JBL and it's soooo lack luster. Just don't have the capacity to tackle a custom audio solution and hate having other people, audio shops, work on my stuff.
viper2788
Daniel
PG County, MD
2026 TRD ORP
Give it a shot! At one point I even went to an audio shop to see if they'll install it for me since I had all the parts. They insisted I'll have to buy everything from them except my Kicker sub and with labor I was quoted $1700... just for a single subwoofer install. And then I remembered a quote from The Edge - "what one man can do, another can do!"
I took my time and took small steps here and there. I'm no electrician and I didnt know squat about audio systems lol
bphansen04
Brody
Kansas City
Nice work, I may try this myself. Are you hearing any rattles or anything from the new sub now that it has real power? Also are you hearing rattles from the doors with the bass turned up max? My 4runner rattles pretty noticeably with any bass at volume 20+.
viper2788
Daniel
PG County, MD
2026 TRD ORP
Yea those are my next steps… I’m getting some rattles at the subwoofer at certain frequencies… may be the speaker bezel making contact with the speaker mesh/trim, or may be some other areas near that. The doors have been rattling since day 1 so I gotta address those as well. I believe it’s mainly a rivet of some sort but going to try to tape up other wires and such as well.
