CO/ZA
Denver
25 4R ORP
A few photos from off roading around Boulder, on 68J and others.
Very happy with the extra clearance and suspension travel, it's an upgrade I wouldn't hesitate to do again.
On road performance is still great, and definitely takes some roughness out compared to the stock Bilstein set up.
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? IMG_2979
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? IMG_2982
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? IMG_2983
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? IMG_2972
It might be just me, but your attachments didn't go through correctly. Getting a page not found. Please let us know how the ride comfort is after getting it installed.
I edited and dropped phots in (but thought that is what I did before?). Let me know if you still cannot see them.
LostInAZ
Carlos
2026 Toyota 4Runner ORP
For those with this kit, would you mid doing a measurement from the bottom middle of the fender (above the tires) to the ground on both front/rear? I want to compare them to mine.
Thanks.
mfoga
r4unner
So the $4430 price is including the installation? If so that’s not bad and A good starting place. I king of calling the 100000 dealers I have around me and seeing who had best price to install the kit then get the kit from best price dealer. If they ask I will say I bought it but was not sure when I could install it or planned to install myself but decided not to.
CO/ZA
Denver
25 4R ORP
Mine was $3882 out the door, with the parts discount.
$2515 parts + 1367 labor w/t tax
josiahg52
Josiah
Thanks.
I thonl Ed Martin Toyota did a short taking these measurements.
Installation:
mfoga
r4unner
Thanks.
Very unscientific measurements of mine are 23.5" front, 23" rear. From fender flare to center of wheel
not exactly what you asked for but a good idea of lift independent of tire size
LostInAZ
Carlos
That's exactly where mine sits after I installed a much stronger spring and bigger shocks in the back. Mine was sagging a lot in the rear due to the dual swing out hitch mount with the spare tire on it, two jerry cans, and the 1.5ton jack mounted.
Yoli
Yoli
Portland, OR
That's a great price. Is it best just to call around local dealerships to get the best price and/or are there deals/sales to be had right not? Maybe for Fathers Day or 4th of July?
It's happening.....
I asked to measure the parts ahead of install. Photos with tape measure for whatever interest they might be to anyone... Will compare to stock after.
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_081550
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_081703
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_081714
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_081729
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_082121
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_082119
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_082150
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_082211
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_082208
2025 2026 4runner 6th gen Any updates on OEM 2.5" TRD Suspension Lift? 20260619_082419
Joestac
Honestly, a dealer willing to take those kind of pictures for you ahead of time gives some confidence they will do some good work on the install. Good luck! Going to look sweet I'm sure.
To be clear, I took the photos but the service adviser (and one of the techs) helped. And yea - so far I’m very happy with the interaction. Level of knowledge and transparency far exceeds what I’ve experienced at the big dealer where I got the truck.
JD013
New Jersey
2026 4runner
Some more photos. Also noticed today that the brakes feel slightly spongey. Could be because its 1000% humidity in Austin right now, or maybe it's psychological or because of minor nose dive from the lift. Going to keep an eye on it and climb under the truck and see if the brake line got pulled anywhere...
Did you ever get the brakes squared away? I ask because before I bought my 4runner, I had a 25 Tacoma that I lifted on Bilsteins. After the lift, my brakes became very very spongy. Part of me wondered if it was the heavier wheels and tires I added, but I honestly don't think that was the cause. I don't have the truck anymore but I'm curious if you found the issue.
