MartyMcFly
Thanks for this. Easy install, noticeable improvement :)
Ahmad310
Ahmad
Cincinnati, OH
2025 4Runner Platinum
Thanks for sharing! I did this as well and do think it makes a noticeable difference in wind noise coming from the doors.
Joestac
Went ahead and ordered today. Was even a tad cheaper, $9, and will be here tomorrow.
Jade4rTx
Bob
Went out while it was drizzling to check for leaks, no leaks and it did have an effect on the noise! Great easy mod, thanks!
hghrup
NC
Joestac
Definitely seemed a bit quieter on the ride to work this morning.
horbit
DFW
For science I ordered the oem tacoma one. Not as cheap as the Amazon but wanted to see if it would work. Fits well Ofcourse since it is oem and it’s 3m all the way down.
the front door Tacoma one would fit as well but you would need to drill out the holes as it gets clipped on or maybe 3m it.
drill out the holes? Also what part number did you purchase.
hghrup
NC
67896-AK010 LH
67895-AK010 RH
Take a look at the link I posted from the taco forum. There’s four holes the 4Runner doesn’t have drilled out compared to the taco, structure is still the same.
horbit
DFW
Hmm I see, don't know how I would feel drilling holes for the front door gaskets. But I want them..
I just installed the amazon ones
BIG DIFFERENCE (I use Michelin ltx ms2 which is a quiet tire)
-the b-pillar inside transmits noise directly to your ears as
your ears are closest to the B than anything else, and
since it is hollow plastic with a seat belt hole at ear level,
it's sorta like a trumpet and amplifying noise to some extent
this helps deaden some noise from front and rear door panels
because they both press on this heavy rubber strip
and it cuts any wind noise in the crack between them.
I now only hear noise from elsewhere around the vehicle but
right where my ears are, a lot more quiet.
at all speeds an improvement, even 5 mph I noticed
a difference and the faster I went and more cars passing by,
I really see the benefits
on highway I can now hear every subtle
spin up of the turbo at 70-80mph whereas
above 50mph wind noise mostly took over turbo noise
blocks noise from other vehicles around you
these dang $9.99 seals are doing a $250.00 dollar job
it has definite effect on cabin noise
quadna71
Delaware
2025 4runner
Which length did you order? Or just order the truck length and trim to fit?
Joe Dirt
I don't know why they stopped installing this on vehicles, but you'll still find it on Lexus and other higher end car. It was a simple install that only took a few minutes. There is a noticable exterior sound dampening differece with wind/air noise. Totol cost of the mod was $11.99 on Amazon. 2 pc 2.62 Ft is all you'll need. You will have to trim a few inches off. Start from the top of the door and install moving downward. Note- the link below says "does not fit 2025-2026 4Runner". But it worked perfectly. Link for Amazon below photo
https://www.amazon.com/dp/B0G33X396H?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Hey thanks for the great tip on this. I just received mine this week and installed them right away. And yes that definitely white noise wind turbulence that you hear on the freeway. Thanks for the tip
horbit
DFW
https://www.tacoma4g.com/forum/threads/installed-oem-front-door-edge-weather-stripping.13759/
edit:
part numbers
67896-AK010 LH
67895-AK010 RH
I just installed the rear door oem tacoma ones like you did, took about 10 minutes. I also have the front door weatherstrip, the 4 push pins are removable so taping it in place should show where the holes need to be drilled. I will play with it this weekend.
