Ahmad310
Ahmad
Cincinnati, OH
2025 4Runner Platinum
Just came across this video this morning.
"We just upgraded this Toyota 4Runner TRD Off-Road with the OEM On-Board Air Compressor which is currently only available on TRD PRO and Trailhunter 6th Gen 4Runners. Easy install but does require a ground re-wire to bypass the parking brake requirement built in the compressors ECU. "
horbit
DFW
Does this require the hybrid version of the off road premium?
Joe Dirt
As an alternative to having to fiddle around with wiring and potentially fry something I did this as an alternative.
I'm not a sponsor and I purchased this from their website. You start your engine you plug into your trailer Outlet and you're good to go. You can share with friends that need to air up that do not have air compressors.
All the specs are on this website to show how quickly a 33 - 35 Tire will inflate. Hope this helps.
2025 2026 4runner 6th gen OEM On-Board Air Compressor DIY install (in non TRD Pro / Trail Hunter trims) Screenshot_20251213_141603_Chrom
gydooya
Eddie
Dallas
6gen TRD ORP
I went down this path with my TRD ORP and was told it couldn't be done. Now I know it can, but I have the question, will this only work with a Hybrid?
Ahmad310
Ahmad310
Ahmad
Cincinnati, OH
He says all trims in the video, I don't see why it wouldn't apply to the entire lineup.
CO/ZA
Denver
25 4R ORP
An even better option is the Maddox 12v compressor sold at Harbor Freight.
https://www.harborfreight.com/12v-125-psi-high-performance-inflator-59624.html
It's the exact same as the Smittybuilt one that is extremely popular here with the off road people.
I did cut off the end and put a continuous flow, quick detach coupler on the hose though.
xp0nex
2025 4Runner ORP
Pretty cool
Someone want to get one and see if it'll install on a non-hybrid? :cool:
gydooya
Eddie
Dallas
6gen TRD ORP
Here is the issue! I had all the parts both the compressor and the computer. The part you can't buy is the trim panel and unless you have a hybrid, the right rear panel is different on a non-hybrid and there is no where to install the this.
Yep - it seems clear from this post: Trailhunter on board air compressor (and the photos of hybrid (TH) and non hybrid (Limited) as well as my photos from Hybrid TRD ORP) that there simply is not a spot for the compressor in the non-Hybrid trims. And my photos show the space and the power connector behind the trim that is there in my Hybrid. and FINALLY I have proof of the part number and what comes in the box - this video removes so much ambiguity (and even helps with the parking brake workaround).
Here I thought I was done with mods and was content to live with my excellent Wolfbox Jump Starter/Air Compressor. But this video has me contemplating this one more mod.... damn.
gydooya
Eddie
Dallas
6gen TRD ORP
Well, I called the guy who did the video and left a message for him to call me or email to let me know if this will definitely work with a TRD ORP non-hybrid. I also spoke to his parts department and they said it will. So since I'm a glutton for punishment...look what I did :)
2025 2026 4runner 6th gen OEM On-Board Air Compressor DIY install (in non TRD Pro / Trail Hunter trims) Screenshot 2026-02-24 at 3.58.06 PM
BruceB
Bruce
Washington
Chevy Silverado, 4Runner
This is a great alternative, especially for the price. Do you know what the amp rating is for the trailer outlet? I am asking because VIAIR says to be sure to check your auxiliary power circuit rating to make sure it supports the max amp draw of the compressor. The 88P's max amp draw is 20 amps. I looked in owner's manual and it mentioned that the tow lighting system is designed for 5 amps per side for brake and turn lights, which I am presuming is for a total of 10 amps. Obviously, you had no issues, but I was curious if I was not looking in the right spot to get the info. Thanks!
Joe Dirt
I recall looking at all that info prior to calling Viair and talked to one of the technicians and told him that I had a 25 4Runner with a trailer output Jack and he said that would fine. But the engine does have to be running. I've used it probably three times. No overheating, no weird effects, it just runs.
BruceB
Bruce
Washington
Thank you!
MrEdofSC
Ed.
Santa Cruz, Ca
2025 4 Runner TRD OffRoad Premium
What is the website for this compressor? I cannot find it on your post --- what am I missing?
Best of luck. I honestly hope I'm wrong but I just don't see the similar trim spot above the right rear wheel on the non-hybrid photos that I see on the Hybrid (including TH where it comes and Pro where it is option - and my TRD ORPH.) I suppose the power connector might be in there somewhere but am not sure where you would mount the compressor and the control panel. To be clear, I am using these photos as reference
Here is the trailhunter and limited rear cargo areas:
And my photos:
.... There appears to be a white connector where the compressor assembly would plug in - and there seems to be space for the compressor behind the hybrid vent pipe.
I am assuming that the photo above of "limited" cargo area is the same as the rest of the non-hybrid trims. Am I incorrect?
Again - good luck. I truly hope you are successful.
