Removing Factor Door Edge Guards?
Undefeatable
Kevin
Southern California
Hello,
Has anyone removed their factory door edge guards? Mine came installed even though I didn’t want them, and I’m not a fan of how they look.
Before I take them off, I wanted to see if anyone else has done this and has tips for removing them as cleanly as possible.
I know they’re friction-fit and installed with a rubber mallet at the port. From what I can tell, the official removal method is using a trim tool and tapping them back off with a mallet but I’m open to better suggestions if anyone has them.
2025 2026 4runner 6th gen Removing Factor Door Edge Guards? PO8rGs
2025 2026 4runner 6th gen Removing Factor Door Edge Guards? DhWZmtH
Undefeatable
Undefeatable
Kevin
Southern California
Grab the edge and pull. That's what I did on my 2022 Limited.
I was thinking about doing that, but didn't know if that would work 😅 . I tried doing it half heartedly and it didn't move, so I just assumed it would take more force than that. I am going to give that a go tonight and report back.
Thank you!
Crose1695
seal beach
2026 4runner
It’s one of the easiest things you’ll end up doing. I understand the nervousness though. Just get after it and start pulling it and it will just peel off. If you see any adhesive left, just a little goof off on a towel and you’ll be good to go.
Undefeatable
Undefeatable
Kevin
Southern California
Update, you were 100% right. I was getting into my car this morning and just decided to see what happens if I pulled harder and they popped right off.
Thank you sir!
Crose1695
seal beach
2026 4runner
Thank you sir!
Haha awesome! Looks a thousand times better without them and the only door that the guards are even saving is someone else’s door haha. As long as you open your door like a civilized adult you have nothing to worry about
bakutheleo
2025 4Runner i-Force Max
I am very careful, but it is still easy to open a door into something--and it does not take much to take a tiny chip out of the paint (so I discovered). I purchased a clear film from Amazon (mine did not have anything) that I have yet to install (maybe this weekend, like I say every weekend so far...). I have no experience yet but tiihs is the product:
https://www.amazon.com/dp/B00NPMCB0W?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1
The one I got is 1/2" wide, hopefully sufficient. They do have a 3/4" width as well. If I ever get it installed, and remember, I will try to post back here.
Undefeatable
Undefeatable
Kevin
Southern California
I will probably go this route if I want to get some door edge protection.
Why are you wanting to take them off?
I just didn't like the way they looked. It always kinda looked like the front doors were ajar.
I have seen these on different colored cars and they look a lot less obvious. Like on white, they blend in pretty well, but on the Heritage Blue, it just visually threw me off every time I saw them.
