Bizzle
Danny
2025 TRD PRO MUDBATH
Looking mean and clean. Planning on doing the 1” peak up front to level out. But seeing if I should also do 1” in the rear. Did you want to keep a very slight rake?
Cory39744
Cory39744
Cory
Virginia, USA
There is about an inch rake with the rear spacers installed. Maybe slightly less. It works for me because I pull an off-road teardrop trailer so it’s level when I pull it.
Desert_6Gen
Bronco
I'm looking at the same interior and exterior build with the same suspension. +1 tire size with a modest 1" lift. Have you noticed any big hits on what your getting for mpg's? I never owned a hybrid before and curious on how it works. Does the engine completely shut off during some situations like it does with vehicle equipt with start/stop; and turn back on when needed? I might wait until next year when they are easier to find. Even with all the dealers I can't find any with that red interior.
Cory39744
Cory39744
Cory
Virginia, USA
The Recon Grapplers are SL load so they are only just a few pounds more that the factory tires. I didn’t really see much of a difference in MPG. Granted it still isn’t getting the best. My average is 18 city 20 highway. However my single trip mpg city is like 20. Not sure why my average won’t increase.
As for the start stop, yes, it shuts down at red lights and if very little pressure is applied to the gas pedal. Even going down the interstate at 65 it will shut down. You don’t really feel it though like you would in some other engine shut off designs. It’s very smooth.
Icculus
Adam
NC
2025 IC Trailhunter
Nice build. Just curious though if you've looked into changing the gears in the differential. I'm not sure on the 6th gen but my understanding on the 5th get was the diff gearing was 3.83. You could move to "33 inch tires" without to much trouble but to go to 35" you really needed to move up to 4.54 or more likely 4.88 gears to accomodate the tire change. Have you made the change or experienced any issues? Cheers
Cory39744
Cory39744
Cory
Virginia, USA
The 6th gen is a completely different beast than the 5th. It has so much more power. I honestly didn’t notice a difference with the tire change. I don’t think changing the gears is necessary at all.
jayT
john
Louisiana
2025 4Runner TRD Pro in Underground with Cockpit Red Interior
-295/70R18 Nitto Recon Grapplers
-Peak Suspension 1in top shim and 1in rear spacer
-Ceramic Coating
-Screen Protech film for Infotainment
Starting suspension measurements for the Pro was:
Front - 21 3/4
Rear - 22 5/8
After small lift:
Front - 22 3/4
Rear - 23 1/2
I am in love with this truck. I still have my 21 TRD Pro but this one is next level.
this is the "baddest ass" 4Runner i have ever seen; including my own 2025 4R that i have made mods to..gr8 job! i can't stop looking at the pictures of your 4R..i'm jealous😂😉
Cory39744
Cory39744
Cory
Virginia, USA
Thanks man! I am still in love with it for sure. Since these pics, I’ve added a CBI stealth front bumper and a Westcott Designs low pro roof rack with Baja Designs LP8s on it as well as S2 Pro ditch lights. I did change the suspension up slightly as well. Dobinsons rear springs and a Westcott Designs front Collar only lift. Last pic is were I currently am right now in it haha
2025 2026 4runner 6th gen TRD Pro on 35" Tires (Nitto Recon Grapplers) & Peak Suspension 1" lift IMG_0085
2025 2026 4runner 6th gen TRD Pro on 35" Tires (Nitto Recon Grapplers) & Peak Suspension 1" lift 7CA44F81-A2E8-44CF-AC9A-E1990C3F7183
2025 2026 4runner 6th gen TRD Pro on 35" Tires (Nitto Recon Grapplers) & Peak Suspension 1" lift IMG_0192
TurnerXC
Brad
Richmond, VA
Thanks man! I am still in love with it for sure. Since these pics, I’ve added a CBI stealth front bumper and a Westcott Designs low pro roof rack with Baja Designs LP8s on it as well as S2 Pro ditch lights. I did change the suspension up slightly as well. Dobinsons rear springs and a Westcott Deaigns front Collar only lift. Last pic is were I currently am right now in it haha
looks amazing. with the addition of the bumper and winch did you notice the front end dip? or said differently did the front end have more rake? I'm looking at the same bumper and want to avoid any front end rake. Also, did you attempt to put the spare back underneath once you went to 295's?
Cory39744
Cory39744
Cory
Virginia, USA
Thanks! The bumper and winch will lower the front end 1/4in so just plan accordingly . As for the spare, no way it would fit so didn’t even try
3rdRunner
Bill
Looks fantastic! Really curious if you have any significant issues with rub off-road. I have a Trailhunter and I’m trying to decide between 295/70/18 and 285/70/18. I’m going with the Westcott Preload Kit and I know I can fit the 295’s, just concerned about significant rub when I’m articulating over rocks/ditches.. Not worried about minor rubbing, I run into that now on the stock 265/70’s.
Cory39744
Cory39744
Cory
Virginia, USA
If you take the crash brackets off then there will be zero rub through all articulation
