Why I chose the 4Runner Trailhunter over something like a BMW X5
ls3673
Luis
NYC
I just picked up a 2025 4Runner Trailhunter and figured I’d share my thought process in case anyone else is cross-shopping similar vehicles. I was strongly considering something like a BMW X5 in a similar price range, but ultimately went a different direction based on how I think about long-term ownership.
One of the biggest factors for me was long-term reliability and overall ownership experience. I know the new 4Runner gets some criticism for moving to a turbocharged 4-cylinder hybrid, especially coming from the old naturally aspirated V6. On paper, it sounds like added complexity in a platform that’s traditionally been known for simplicity. But when I looked into it more, I came away with a different perspective.
Toyota has been building 4-cylinder engines for decades, and they’re not new to forced induction either. Between global turbo applications and diesel platforms, this isn’t uncharted territory for them. More importantly, their hybrid systems are some of the most proven in the industry at this point. We’re talking about millions of vehicles over many years with a strong track record. Another thing that stood out to me is that Toyota didn’t chase bleeding-edge tech here—they went with a more proven battery chemistry rather than something newer and less tested. That tells me they prioritized durability and consistency over marketing specs.
Another major factor for me was the body-on-frame construction versus a unibody platform. This is something that doesn’t get talked about as much anymore, but it still matters depending on how you plan to use and keep the vehicle. With the 4Runner, you’re getting a true body-on-frame setup, which inherently brings advantages in terms of durability and real-world toughness. Even though I’m not planning to do hardcore off-roading, living in New York means dealing with rough winters, potholes, and unpredictable road conditions. That added robustness is something I value more than squeezing out a bit more on-road comfort.
It also comes down to long-term ownership and repairability. With a body-on-frame vehicle, you’re dealing with a separate frame and body, which can make certain repairs more straightforward compared to a fully integrated unibody structure where everything is tied together. The X5 and similar SUVs will absolutely have the edge in ride comfort and refinement, but for me, the durability and simplicity of a body-on-frame platform aligned better with how I plan to use and keep the vehicle.
Another big factor was repair costs and ease of ownership. In general, German vehicles tend to have higher parts costs and higher miscellaneous repair expenses. That’s just part of the ownership experience. With Toyota, parts availability and pricing are typically much more reasonable, and there’s a massive ecosystem around them. On top of that, I’m pretty hands-on, and DIY ability matters a lot to me. With something like a 4Runner, a lot of maintenance and even mid-level repairs are still approachable. There’s tons of documentation, community support, and fewer barriers to getting things done yourself.
That’s not always the case with something like a BMW. A lot of systems are more tightly integrated, and in many cases, you’re dealing with software-gated components or procedures that make DIY work more difficult or require specialized tools. That often pushes you back to the dealership or a specialist shop, which adds cost and dependency. For me, having a vehicle I can understand, maintain, and work on myself is a big part of the ownership experience.
The last factor for me was resale value, which I think is often overlooked. Historically, 4Runners and Tacomas have held their value extremely well, and that’s been consistent across multiple generations. I get that the new hybrid setup introduces some unknowns, but I specifically chose the Trailhunter trim because Toyota’s more limited or specialty trims—like TRD Pros—tend to hold their value better over time. There’s usually strong enthusiast demand and lower relative supply.
I also looked at real-world depreciation trends between something like a BMW X5 and a higher-end 4Runner trim, and historically it’s not even close. The X5 offers a ton upfront, but it depreciates significantly faster. The 4Runner tends to retain value much better, especially in more desirable trims. So unless this new generation turns out to be a complete outlier, I feel pretty confident that 8–10 years down the line, I’ll still have a solid amount of value left in the vehicle.
At the end of the day, it just came down to priorities. The X5 is an incredible vehicle—no question—but it leans more toward performance, tech, and luxury. The Trailhunter, on the other hand, felt like a complete, purpose-built system designed for longevity and real-world use. For me, that aligned better with how I think about ownership long-term.
That said, no platform is perfect, and there are a few things I’ve come across in my research that I’m still keeping an eye on.
The first is the move away from a traditional thermostat to a coolant control valve module, which appears to be a more complex, partially plastic assembly. From what I’ve seen on other platforms that use similar designs, these types of components can become wear items over time. I don’t think it’s the end of the world—replacement cost seems to be in the few-hundred-dollar range—but accessibility will matter a lot. If it’s relatively easy to get to, it’s just another maintenance item. If it’s buried, that could be more of a concern. Given that it’s an inline-four, I’m hoping there’s decent access, but I still want to look into that more.
The second thing I came across was mention of polymer components in the oil pump assembly. I haven’t been able to fully confirm whether that applies to this specific engine, so I don’t want to jump to conclusions. In general, I’m not a huge fan of polymer materials in rotating assemblies, but I also understand that modern engineering uses composites in very specific, controlled ways. If anyone has more concrete information on this, I’d definitely be interested to learn more.
The third item is related to piston ring design, specifically the use of thinner, lower-tension rings for efficiency. From what I understand, this is pretty common in modern engines to improve fuel economy and reduce friction, but it can sometimes come with trade-offs in terms of oil control over the long term. Again, I’m not claiming this is an issue here—I just know it’s a general industry trend and something I plan to keep an eye on as more of these engines accumulate mileage.
None of these are deal-breakers for me, but they are things I’ve noted as potential long-term considerations. If anyone has deeper technical insight into any of these points, I’d definitely appreciate the input.
To that same point, I do plan on being a bit more conservative with maintenance than the factory recommendations.
Instead of following the 10,000-mile oil change interval, I’ll likely stick to 5,000-mile oil changes. With modern engines—especially turbocharged ones—it just feels like a safer approach for long-term longevity.
I’m also coming up on about 1,000 miles, and I plan to do an early oil change to get rid of the initial break-in oil. The goal there is simply to minimize any residual metals or debris from the break-in period and start fresh early on.
It may be a bit overkill, but for me it’s cheap insurance if I’m planning to keep the vehicle long-term.
Curious to hear how others are approaching maintenance on these.
Disclaimer: I used ChatGPT to help organize my thoughts, but everything here reflects my own reasoning. Curious to hear what others think.
TL;DR
Chose a 2025 4Runner Trailhunter over a BMW X5 mainly for long-term ownership—prioritizing reliability, durability (body-on-frame), lower repair costs, DIY-friendliness, and strong resale value. While the new turbo hybrid setup is different, Toyota’s track record with 4-cylinders and hybrids gave me confidence.
I’m aware of a few potential long-term concerns (coolant control valve, possible polymer components, modern piston ring design), but none were deal-breakers.
Plan is to maintain it conservatively (5k oil changes + early 1k break-in change) and keep it long-term. Curious how others feel about the platform and how they’re approaching maintenance.
NotApplicable
WA, USA
4Runner, IONIQ 9, Sprinter
A little confused after investing the time in reading this. You put a huge focus on resale value, yet also dedicate many words to concerns of very-long-term ownership. You talk about the importance of being purpose-built, but then mention you picked up the Trailhunter trim to never venture off-pavement.
Not trying to be a d*ck, ultimately you do you, and if you’re happy with it that’s all that matters. Just pointing out that for a “here’s how I applied logic to my purchase decision” post, the reasoning is a bit… muddled.
ls3673
ls3673
Luis
NYC
I get what you’re saying, and that’s fair feedback.
For me it’s not really a contradiction as much as layered priorities. Resale value and longterm ownership go hand in hand. I’m planning to keep the truck for a long time, but I still care about what it looks like on the back end when I eventually move on. Strong resale is just part of minimizing total cost of ownership. It also allows for an easier exit if things get tough in life.
As for the “purpose-built” point, I probably could’ve worded that better. I don’t mean I’m going rock crawling every weekend, I mean I value a platform that’s overbuilt for real-world conditions, even if I don’t fully maximize its use. Living in NY, dealing with winters, potholes, and general abuse, that kind of durability matters more to me than on-road performance or luxury.
And on the Trailhunter specifically. yeah, I may not use 100% of what it’s capable of, but I like the idea of buying something that’s already a complete, well-engineered package from the factory rather than needing to modify it later.
I appreciate the feedback.
ls3673
ls3673
Luis
NYC
It’s the same thing as people buying supercars or track cars and never tracking them. You’re paying for the capability, even if you don’t use all of it every day. Never really understood why people hate on that.
1. had a 2014 4R, had 120k miles and dealer paid me 19k for trade in. i drove it with the back window down every chance i could, the interior was dirty at trade in with 5-7 yrs of window down use
2. been thru a lot of rwd,fwd/awd vehicles and even had a legacy 3.6R with a locking center torsen diff (just like the 4R limited/platinum)
3. ultimately went with a used 4R back in 1998 (highlander version, then a 2004 sport v8, 2014 limited, 2025 platinum)
4. needed the clearance for ND winters and the ft4wd. subdivision doesnt get plowed until 1-2 days after major snow storms and i need the ft4wd for getting to work (usaf air base 15 miles 1-way). i am on the road at 5am before the city/highway plows usually (had 33in in april once, that was fun)
5. i tend to ignore the road harshness more so since we have BoF vehicles, it can take the beating better than unibodies.
6. in the 12 yrs i had my 2014, i only replaced a single item (oil sending unit). funny part, 2 days after trade in, the water pump failed (go me)
7. (remember all the replacements were oem from the factory) i did chemical flush on cooling system somewhere in the 80k range, spark plugs at 106k, front brake pads and rotors around 100k, rear pads and rotors around 106k, all 3 diffs around 80k. trans fluid will still original at 120k trade in, brake fluid also (toyota tech said it didnt need replacing since it was within specs for moisture content)
i have had toyota's since my first one in 1984 and have slowly gone thru a few models. you can see all the vehicles my family has gone thru in my sig (M)e (W)ife (D)aughter (S)on
Salukidawg
Houston, TX
2025 Toyota 4Runner TRD Off-road Premium IForceMax
Just came here for the BMW X5/4Runner comparison. That I can honestly say is two vehicles that most 4Runner owners don’t cross shop. I’m glad you’re happy with your decision though.
FoRunna
Atlanta, GA
Man I can't read all this.
All I'm gonna say is that the X5 is a completely different SUV compared to the X5, so it's strange to cross-shop a purpose-built body-on-frame off-roader with a luxury unibody SUV.
Coming from someone who owned an X3M Comp, and C7 Z06, and Xterra (Offroady as hell) at the same time.
CO/ZA
Denver
25 4R ORP
Controversial opinion:
If you do not off road, you should not buy a 4Runner.
4Runner is great relative to other high clearance 4x4 vehicles, but that's not saying much when your two main comparisons are Jeep and Ford Bronco.
X5 is better is every single metric, from performance to build quality.
It is a better 'mom car' as it has a more spacious back seat as well as trunk area.
Far, far nicer to drive long distance on pavement in total luxury with sporty character to boot.
Gets double the MPG while delivering double the horsepower, the B58 is a far finer engine than any conventional engine that Toyota/Lexus produces.
Sorry, but you're quite wrong on this one in my opinion.
ls3673
ls3673
Luis
NYC
You’re glossing over my points. Saying the X5 is better in every metric only works if you ignore the ones the 4Runner is actually designed for. durability, simplicity, and longterm ownership. They’re built for completely different priorities.
Your point on not buying a 4Runner if you don’t off road is narrow in my opinion.
By that logic:
Nobody should buy a Porsche unless they track it
Nobody should buy a pickup unless they haul/tow daily
Nobody should buy an M car unless they hit redline every drive
People don’t buy vehicles purely based on how often they use 100% of their capability. They buy them for what they value, whether that’s performance, durability, flexibility, or just the overall experience of owning something built a certain way.
CO/ZA
Denver
25 4R ORP
By that logic:
Let's simplify:
If you go on walks/errands, and your destination is the mall - you're going to look a bit silly when the shoes you're wearing are La Sportiva Nepal Cube GTX boots instead of some nice leather shoes or comfortable tekkies.
This is what you're doing, but in an automotive sense.
xDrive X5 would have been perfect for your New York lifestyle, but you bought a Trailhunter of all vehicles.
The current Tacoma / 4R generation is every bit as 'advanced' or 'electonic' as the G05 or later X5, and with that the same potential for electrical problems or what have you are present.
Sure Toyota parts are cheaper, but I would argue they are somewhat lesser quality than the Euro parts bin sources like Mann+Hummel, Mahle, Bosch, etc. Still, $5 vs $15 for an oil filter.
Longevity isn't a purely Toyota quality, there is an entire fleet of grey market Mercedes C/E/S class cars in the Balkans with 999,999,999km on every example.
ls3673
ls3673
Luis
NYC
Let's simplify:
I think we just have different priorities, and that’s completely fine. I’ll keep wearing my hiking boots to the mall.
the 4R is just not only for off roading
4Everest
Michigan
'04 Acura TSX, '25 4Runner
I did the exact same (1k oil change, just did a 5k, and will do every 5k hereafter). The dealer service people look at me like I'm crazy every time they see me, but my reasoning aligns with yours. Also:
  • My engine was broken in during an unusually cold Michigan winter. Every cold start was as far out of tolerance as possible.
  • 0 weight oil isn't going to be as forgiving, in general.
  • Turbos are hard on oil, and the fact that this engine shuts itself down periodically may make that worse.
I'm also looking to keep my 4Runner a long time, and as cheap as oil changes are for this vehicle (the filters cost like $6!), it's well worth the peace of mind of a shorter interval. Good luck and enjoy your TH!
Evergreen104
Joe
Oregon
2025 4Runner i-FORCE MAX TRD Off Road
TL;DR
Very different vehicles having owned both. I had my 5th gen 2016 4Runner for 4 1/2 years and 53k miles. Sold it for $2700 under what I paid new. It was trouble free though an archaic V6 & 5 spd auto with dreadful mileage. I bought a new '21 X5 MSport and drove it 4 1/2 years and 48k miles. It was a wonderful vehicle with great acceleration, stout handling, not a tick or rattle, and averaged 23 mpg with at times hitting 30 on a highway trip. It was trouble free. That said, it was past its warranty and looking at long term ownership the potential expense of a high mileage German car (it is a crossover) put me back into a 4Runner 6th gen TRD OR. My dogs always love the rear window that goes down.
yeah you definitely are a BOT or using BOTs to speak
you mentioned chatgpt.
I don't trust like that
Verdict: account is Likely AI-Generated
