Rear camera issue?
KD2MYW
Phil
NYC
Hello. I am noticing the rear camera on my 2025 Trailhunter seems really awful. I really never paid much attention to it but I can't imagine it was always this bad. The front camera seems very sharp in comparison. Is this normal? Do i need service?
Thanks so much in advance!
Front camera
2025 4runner 6th gen Rear camera issue? IMG_1130
rear camera
2025 4runner 6th gen Rear camera issue? IMG_1129
look dirty. but then again the location where the camera is the worst spot to be in vs our 23 tundra.
that rear end attracts dirt/dust/etc like a magnet so unless you stay on paved roads or away from water puddles/rain, you will have to constantly clean the rear cam lens.
4RunnerTony
Tony
Venice Florida
I will have to look. I did not know that I had a spray function.
Joestac
Does look a little dirty but I have also noticed that lighting is really important with the rear one. The further I back into my garage the worse it can get depending on the lighting. I think the reverse lights can add a little bit of washout to the camera if the rest of the environment is dark.
KD2MYW
Phil
NYC
I saw the spray function..... It's a real sloppy feature.
I wiped it down too. There is only 1 camera back there, right? Closer to the driver side.
Joestac
There are two. The one closer to the driver side is for the 360 camera. The one more in the middle is what you see when reversing.
Edit: Sorry, that is wrong. The 360 uses the same as the reverse. The other camera is for the digital rear view.
adwightm11
Alex
Ontario, Canada
2025 Toyota 4Runner, 2022 Subaru Forester
Try it again during the day. Camera will adjust ISO (light sensitivity) so you can see more at night. Higher ISO will mean more light being let in, but will also make image more grainy. Same thing would happen if you tried taking a picture/video on your smartphone at night VS the day.
My guess is the Rear camera will have to increase the ISO o more than the front because the front has the headlights to help with light levels.
adrestaino
Dave
Bucks County PA
2025 TRD Off-Road Premium
You can also clean the rear camera by pushing the wiper control forward while in reverse. Similar to cleaning the rear windshield.
what he said^
SR5 has spray function but no icon on the headunit, it just automatically sprays camera if
you are (a) in reverse and (b) hit rear window washer while in reverse
KD2MYW
Phil
NYC
OK. Confesssion, when i was testing this last night I physically cleaned the camera lens several times but i was actually cleaning the wrong lens! I never picked up on there being 2 lenses back there. I just wiped the passenger side camera and it made a deffinete improvement! I will retest in better light when it's not snowing :(
I really remember beign impressed with the cameras when I first got the truck.
THANK YOU, ALL!
KD2MYW
Phil
NYC
Confirmed. I was cleaning the wrong camera and the washer fluid cleaning is crappy.
Thanks!!!
2025 4runner 6th gen Rear camera issue? IMG_1136
2025 4runner 6th gen Rear camera issue? IMG_1135
