Fog lights on with high beams?
jimbo285
Jim
Fairbanks
I did a quick search but didn’t find the answer. Can the vehicle be programmed to keep the fog lights on when the high beams are on? I like the low spread of the fog lights and wish I could keep those lit when Im out in the open and also need to see distance. Can that “Clarista” or whatever it’s called, do that?
KD2MYW
Phil
NYC
Falls under that same weird “logic” as not being able to have the light bar on without the brights being on.
BonRunner
2026 TRD Sport Premium / WCP
In the name of "safety", Toyota heavy limits on what & when you can, use your extra lights, which is ridiculous!
I'm glad I went aftermarket route that can turn whatever on as I want!
KD2MYW
Phil
NYC
Definitely a limitation of the Trailhunter.
Built-in light bar and Rigid fogs but you can’t show it all off.
MTN Dew
Dave
DE
Federal law mandated only one set of driving light available at time. Fog lights and high beams are classified as driving lights. Trailhunter language suggests light bar is strictly off road use. Just glad the light bar functions without being in 4WD.
rdibbxsh
Randy
TN
2026 4Runner TRD Offroad Premium
It's illegal by Federal law/regulations. That's why you'll see every cars fog lights go off when you hit the hi beams.
josiahg52
Josiah
Maine, United States
There is no blanket federal prohibition against operating fog lights and high beams simultaneously. Federal regulations require that supplemental lighting not impair the effectiveness of required lighting equipment. That's not the same as prohibiting simultaneous operation.
Also, "driving lights" has a specific meaning to the feds. High beams are upper-beam headlamps, fog lights are supplemental lamps, and auxiliary driving lights are another distinct category. They aren't all legally classified as "driving lights."
If federal law categorically prohibited more than one set of forward-facing lights operating simultaneously, the Trailhunter's light bar would violate the supposed rule regardless of what Toyota calls it or how they describe it's use.
State laws may impose additional restrictions, but the blanket federal prohibition being claimed here doesn't exist.
Mike N
Rochester, NY
You could add the Aspire Auto Brite Box Anytime.
yeah BUT new Tacomas are sold in every state in the US today with the ability to run fogs with brites..so yeah the law used to be no fogs with brites but that must have changed if they can sell tacomas like that now
EDIT: I am wrong, they work with parking lights or low beams
josiahg52
Josiah
I cannot find any evidence of there ever being a federal prohibition preventing simultaneous operation of the upper beams and fog lights, since at least the 80s.
I looked at the 2025 Toyota Tacoma Hybrid owner's manual and it specifies parking lights or low-beam headlights as the conditions for fog-light operation.
sorry for my incorrect post#11, tacoma fogs on with high beams no, but fogs on with parking lights yes
on a tacoma.
tacoma=fog+parking yes
tacoma=fog+low beam yes
4runner=fog+parking no
4runner=fog+low beam yes
Mike N
Rochester, NY
The Aspire Auto Brite Box Anytime allows fog light operation with all headlight and DRL settings. It does not disable or create a conflict with the factory trigger. The factory switch still functions and dash indicator works with the switch too. Just not when using Brite Box only.
I can turn on or off my fogs at will.
The harness install is doable without disassembling the front grill/bumper. Attaches to either light plug/harness and operates both lights. I was able to reach down to the fog light plug on the passenger side.
Affordable solution for DIY'ers who want full control of their fog lights.
ROBERT18452
Robert
Scranton, Pennsyltuckey
25 Gen6 4runner limited
FMVSS No. 108 / 49 CFR § 393.24: Federal regulations govern required headlamps (which must feature selectable upper and low beams). Auxiliary driving lamps must meet SAE J581, and front fog lamps must meet SAE J583.
SAE J583 Standard:
Defines a front fog lamp as a lighting device mounted to provide a wide, low-angle beam pattern with a sharp horizontal cutoff to minimize glare and reflection off fog, rain, or snow. [
High Beam Interaction: Running fog lights alongside high beams is counterproductive and restricted in many jurisdictions because high beams project light straight and upward, which bounces off moisture in the air and creates severe blinding glare for the driver and oncoming traffic. Factory wiring on compliant vehicles typically cuts power to the fog lights the moment high beams are turned on.
